446 replies to this topic
#281 bacon225
bacon225
  • 9 posts
Posted 07 July 2012 - 07:32 AM
Is this leak hosted anywhere else. I am on a company computer and drop box is blocked.
#282 digdug1
digdug1
  • 89 posts
Posted 07 July 2012 - 08:03 AM
I thank matt for the leak and the utility it worked great! But, this kernel was horrid on my battery. It hung on 1200 mhz. It would drop briefly but hang again. I tried reflashing wiping all a no go. Im back on. 211 now battery is back to normal.
#283 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 07 July 2012 - 08:12 AM
Og Razr Stock .214 non-safe side
Eclipse Razr ICS v1.1 safe side
#284 prh
prh
  • 9 posts
Posted 07 July 2012 - 08:17 AM
Here is my battery experience so far. I'm on vacation in Montana with no 4G, so I've turned that off. I'm finding wifi connected or 3G don't matter much. My MAXX drains about 1% an hour on its own. When I'm on it with the screen on, it drains 1% roughly every 7-9 minutes. I had auto brightness on, and just turned it off a bit ago, and see no negative effect. It is now brighter than before, which I like. It seems the biggest thing is 4G and screen time, so when we discuss our battery life, specifics regarding those two should be given.
Here is all my information:
MAXX
214 kernel
Arctic 214 ROM
It seems to me that this kernel is better with screen off, and slightly worse with it on. I haven't been on Arctic long enough to say for sure though.
#285 bacon225
bacon225
  • 9 posts
Posted 07 July 2012 - 09:17 AM
Never mind I was able to sneek my phone in long enough to tether and down load it.
Trying it out now.
#286 CptSashimi
CptSashimi
  • 22 posts
  • LocationAtlanta, GA
  • Current Device(s):Moto X & Nexus 7
Posted 07 July 2012 - 09:30 AM
thanks a million matt. i'm as current as can be and confident that i can return to .211 with one of your utilities should the need arise.
also, thanks to all who offered pointers and clarifications in the thread. yes, i read the op and the whole thread before asking any questions. and guess what, all my questions were answered and the process was a breeze. ;)
thanks again
#287 just lou
just lou
  • 37 posts
  • LocationNew York
Posted 07 July 2012 - 10:11 AM
I finally had to charge my Maxx. I installed .214 two days ago with 80% battery left. My battery life is now back to being as good as it was on GB, if not better.
#288 Guest_BDH_*
Guest_BDH_*
Posted 07 July 2012 - 11:07 AM
So here's my opinion on the 214 kernel "fix."
Does it fix the "idle battery drain?" Yes
Does it still suck if you're actually using your phone? Yes
As long as I'm not using my phone, I get excellent battery life, but as I use my phone for checking tapatalk, I can literally watch my battery drain 5% every 15 minutes. I have an OG RAZR so obviously battery life is something that concerns me, also when I go to work I'm not around anything to plug my phone in for about 14 hours. The battery life on this phone is completely unacceptable and something needs to change. Regardless if it means me getting a different phone or whatever. I need a phone that lasts at least 16 hours on charge. I could easily get this with Black Widow ROM back in the Gingerbread days. Not anymore. As of now I get about 7 hours of battery with LIGHT usage, when before ICS I could get 21 hours with moderate usage. Unacceptable Moto.
Edited by spc_hicks09, 07 July 2012 - 11:08 AM.
  • ktraub likes this
#289 saycbone
saycbone
  • 68 posts
Posted 07 July 2012 - 11:26 AM
Thanks Matt,
Worked just fine. I rooted my RAZR as well and have no rom on it (any suggestions..I see talk of arctic..)
My question is do i need to add Safestrap or Bootstrap from 1.7 even though I don't have a ROM yet?
And if I do use a ROM which of these do you recommend..
Thanks!!
#290 wyld
wyld
  • 845 posts
Posted 07 July 2012 - 11:59 AM
Battery life really isn't that important to me. I drive a truck for a living. I always have my car dock an charger with me.
#291 portscan
portscan
  • 277 posts
  • Twitter:@JasonCollins23
  • LocationClarksville, TN
  • Current Device(s):Samsung Galaxy S4- Stock Rooted on 4.3/Samsung Galaxy Note 10.1- Redemption Rom v6.1
Sounds like you're going to need the Maxx, Hicks.. I too use my phone heavily for work purposes and people generally aggravating the $!#7 out of me with texts. I posted my battery stuff in this thread after .214, and I can say that .214 has helped me when using heavily, but I do have a Maxx. I busted 19 hours yesterday before she shut off completely. 13 hours was beating the piss out of it. As long as I can make it from 6AM until I get ready for bed, I am pleased. This leak seems to be better for that v/s .211. .209 in my opinion had the best battery life out of all the leaks.
#292 Tbizzy
Tbizzy
  • 37 posts
Posted 07 July 2012 - 12:02 PM
Does it matter if we're in USB Mass storage or Media when we root .214?
#293 Guest_BDH_*
Guest_BDH_*
Posted 07 July 2012 - 12:04 PM
Does it matter if we're in USB Mass storage or Media when we root this time?
Yes it will always matter. Same method as always.
#294 Tbizzy
Tbizzy
  • 37 posts
Posted 07 July 2012 - 12:11 PM
Cool, thanks!
#295 corrsfan99
corrsfan99
  • 41 posts
  • Twitter:corrsfan99
Posted 07 July 2012 - 12:12 PM
So do we need to use the market fixer to find apps missing from the market? I can find the full version of med minder.
#296 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 07 July 2012 - 12:35 PM
SPC, do you think it's a 4G thing? Did you try battery life using CDMA Auto PRL only? I've noticed my battery life is awesome on CDMA only =/
On a side note, just donated to you Matt. Thank you!
#297 Guest_BDH_*
Guest_BDH_*
Posted 07 July 2012 - 12:40 PM
I only use 3G and wifi. No 4G unless I drive a few miles down the road.
#298 bilbobaggins
bilbobaggins
  • 124 posts
Posted 07 July 2012 - 04:24 PM
HMM, I'm getting a sideload error for the /system/apps/browser.apk
any ideas on how I can fix that without reinstalling 211 all over again? I have installed Dolphin browser but that never got in the way of updates in the past.
#299 Guest_BDH_*
Guest_BDH_*
Posted 07 July 2012 - 04:36 PM
Did you freeze or remove the stock browser?
#300 bb12489
bb12489
  • 42 posts
Posted 07 July 2012 - 04:56 PM
Using this kernel with the interactiveX governor = WIN
