446 replies to this topic
#261 Quie2Droid
Quie2Droid
  • 7 posts
  • Twitter:@quie2droid
Posted 06 July 2012 - 05:07 PM
Its hard to beleive to have over 9 hours and still at 80%. Unless you not using it and running on 3G and wifi. Or the 9 hours is after an 8 hour nap........lol
No, actually I am on the phone with text messages, twitter, Facebook, email from two accounts and 4g all day.
Make sure you wipe cache. I wiped cache before and after install. By the way, I'm on a maxx.
#262 bluex
bluex
  • 98 posts
Posted 06 July 2012 - 05:26 PM
dang i need a maxx bad, this phone might as well stay attached to the wall.....
  18.06KB   35 downloads
Guess I will try .214 but doubt it will make a huge difference....Screen on time is 1 hr 17 mins
#263 (TSON)
(TSON)
  • 529 posts
Posted 06 July 2012 - 06:02 PM
been on 100% for an hour on my OG RAZR. wtf
#264 tuarmeN
tuarmeN
  • 103 posts
Posted 06 July 2012 - 06:42 PM
Just to clarify after reading this thread (sorry im a little under the weather and this may have been answered already) if we are on stock 211 no root no custom rom just stock OTA 211 do we still need to use the kernal utility or can we just update zip file from moto recovery? thank you in advance.
#265 BUMMERX
BUMMERX
  • 11 posts
  • Twitter:BuMMeR_X
  • LocationGoose Creek, SC
Posted 06 July 2012 - 06:58 PM
Just use correct file and install from moto recovery, that's what i did and it worked perfectly.
#266 topdog031382
topdog031382
  • 131 posts
Posted 06 July 2012 - 06:59 PM
read the instructions in the OP you will be fine
#267 kmss1
kmss1
  • 17 posts
  • LocationBeautiful Sunny SoCal
Posted 06 July 2012 - 07:59 PM
You can just go straight to MotoRecovery with the .214 zip file on your sd card. Quick and easy, be sure to wipe the phone (facory reset) AFTER to clear everything.
#268 jimgfitzgerald
jimgfitzgerald
  • 277 posts
Posted 06 July 2012 - 08:18 PM
I'm at 70% after 15+ hours with my Maxx on .214 and light to moderate use. It's discharging at about 2% per hour. About 1/2 of that is on WIFI and 1/2 on 4G.
#269 Guest_BDH_*
Guest_BDH_*
Posted 06 July 2012 - 08:33 PM
Lost 5% in 15 minutes lol.
#270 just lou
just lou
  • 37 posts
  • LocationNew York
Posted 06 July 2012 - 08:37 PM
FWIW, I didnt wipe anything other than cache, and everything is fine. IMO, a complete factory reset for a minor update isnt necessary.
#271 thaijunk
thaijunk
  • 109 posts
Posted 06 July 2012 - 08:51 PM
4hrs in. At 88%
Sent from my pager using Tapatalk.
#272 jonwgee
jonwgee
  • 301 posts
  • Twitter:JonWGee
  • Google+:jonwgee
  • LocationDekalb IL
Posted 06 July 2012 - 09:15 PM
If you're worried about battery life, get Lux auto brightness from the play store. Works way better than moto a/b...
Maxx
  • karenct likes this
maxx
#273 utekking
utekking
  • 65 posts
Posted 06 July 2012 - 09:54 PM
Stop surfing Porn!!!!
Droid Razr upgraded to Maxx!!!
#274 GeXX
GeXX
  • 65 posts
  • Twitter:gexx
Posted 06 July 2012 - 09:55 PM
Here's the speed that I remembered on gb. Maybe this should have been the ota.
#275 thaijunk
thaijunk
  • 109 posts
Posted 06 July 2012 - 10:04 PM
Unplug it from the charger :D jkjk
  • clintro likes this
#276 Guest_BDH_*
Guest_BDH_*
Posted 07 July 2012 - 03:29 AM
No!!!!!!!!!!!!
#277 AngelRyux
AngelRyux
  • 45 posts
Posted 07 July 2012 - 03:33 AM
Not sure how 211 was but on 214 it uses 300mhz more than 1.2ghz so guess it is saving battery.
Thanks for leak!
#278 bluex
bluex
  • 98 posts
Posted 07 July 2012 - 05:52 AM
Thanks Matt the utility worked perfect to flash just the kernel for me. I also used the regular file and Motorecovery to update a coworkers phone last night. No problems/issues with either. I'm definately still a newbie at this too.......
#279 willmiii
willmiii
  • 55 posts
Posted 07 July 2012 - 06:47 AM
For those like me who were nervous about updating here are the exact steps I took to success. First I'm coming from stock rooted 211. I downloaded option 1 from OP page and copied update to external sd card.
1. Download ota rootkeeper and make a backup of root.
2. Unfreeze all apps that i previously froze in titanium backup. (Bloatware)
3. Open ota rootkeeper app and temporarily unroot.
4. Power down phone.
5. Hold both volume buttons as well as power button to enter bootloader menu.
6. Scroll down to recovery option using volume down button.
7. Enter recovery by pressing volume up button.
8. Once android with exclamation point shows up, press both volume up & down buttons to enter moto stock recovery menu.
9. Wipe cache only
10. Choose install update from external sd card and let it update.
11. After update completes click reboot.
12. Once phone reboots go to settings>about phone, and now listed is 214 and kernel date is the 29th.
13. Open ota rootkeeper and click restore root.
14. Enjoy the new leak update.
Hopefully this helps anyone who wants to upgrade.
#280 Badger50
Badger50
  • 241 posts
  • Google+:badger50@gmail.com
  • LocationKansas City
Posted 07 July 2012 - 07:09 AM
Hey Matt: Just want to say thanks for all the utilities you have provided for all of us Razr owners over the past few months. Your latest one for the .214 leak is no exception, worked like a charm as usual. So, I thought I'd send you a bunch of beers :-) Enjoy my friend, and thanks again for all your hard work :-)
10 user(s) are reading this topic
0 members, 10 guests, 0 anonymous users
