446 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 04 July 2012 - 04:39 PM
POPULAR
Thanks W0017roid for the video!
It's that time again folks... leaked updates! (Yay~!)
This time I got a special treat. I did not want to leave my comfortable place with safestrap installed and booted on Arctic Rom on 211 to fastboot the 6.12.181 files, re-upgrade to 211 stock, upgrade to 214 just to see a small difference in the kernel. Therefore. I pulled and patched the biggest part of this leak update which is the boot.img (New ICS 4.0.4 kernel, hopefully fixing issues with battery life people have on 211 now!).
So two things today:
  • Update zip to install in MotoRecovery from stock 6.16.211
    MD5: 715AD085D246105EB9101F872CE4B604
    File Size: 6.7 MB
  • Utility to flash the new kernel, and the ability to flash 211 kernel back + root if you want to.
    MD5: CBA714069ABCAFF145610D8EDD33D81B
    File Size: 15.5 MB
To root using the little utility, choose the option to flash the 6.14.85 boot.img, boot normally (have USB Debugging Enabled from Settings>Developer Options and the USB Mode set to MTP or Camera with latest moto drivers installeddrivers installed).
Then choose the root option in the utility, then go back to AP Fastboot and choose the option for 214 or 211, your choice. I suggest 214 since its newer :)
This will NOT get you stuck on an ICS leak and can be downgraded to 211 if you choose (or even 6.14.84 if you really wanted too.).
NOTE: To confirm it worked. Under Settings>About Phone the Kernel build date will show June 29th on the 214 kernel.
Thanks topdog031382 for the instructions to average people:
ok listen if you are on a custom ROM, you can use the utility that Matt has created which is the second link in the OP. So if you are on a custom ROM download the utility unzip it to your computer run the bat file and flash the .214 img with your phone in AP Fastboot Mode, this will give you the .214 kernel. If you want to go back to the .211 kernel then put your phone back into AP Fastboot Mode flash the .211 kernel then reboot and you are back on the original kernel. You DO NOT have to be stock .211 if you use the utility. If you choose to use the zip file (the first link posted in the OP) then use the 1.7 utility and run option 2 do a factory reset install the .211 zip (will be named 181). Once installed reboot. Once it reboots, shut the phone off and boot into the moto recovery and install the OTHER zip file which will be named .211 and should also be placed on your SD card (going to .214). After installation reboot and you will be on the .214 leak with the new updated kernel. It is much easier to just use the Utility and flash the img though. Does this sound about right Matt? Hopefully this will help a little lol
(This is a screenshot from ArcticRom214)
  • OldBaldy, tshow84, mugsy77 and 44 others like this
#2 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
  • Twitter:xlightwaverx
  • LocationEast Coast
  • Current Device(s):XT912, Kindle Fire HD
Posted 04 July 2012 - 05:01 PM
Oh boy.
  • Xobertbrups, LhomasDic and MeighJeoda like this
#3 jb_alphamale
jb_alphamale
  • 251 posts
Posted 04 July 2012 - 05:03 PM
Ohhh man. Not again. :D
Oh boy.
#4 jrkruse
jrkruse
  • 14 posts
  • Twitter:https://twitter.com/jrkruse
  • LocationArizona But Always On The Road
Posted 04 July 2012 - 05:04 PM
If I have safestrap and a custom rom installed all I need to do is use the utility to flash 214 boot image? Is this all I need to do?
#5 blueizee
blueizee
  • 35 posts
  • LocationFlorida
Posted 04 July 2012 - 05:13 PM
do you wipe data and everything before flashing this zip ? or keep the original sideload
#6 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 04 July 2012 - 05:18 PM
yup.
#7 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 04 July 2012 - 05:19 PM
must be on stock 211 without debloat or custom recovery. Root only is ok. No need to wipe data
#8 blueizee
blueizee
  • 35 posts
  • LocationFlorida
Posted 04 July 2012 - 05:23 PM
im sorry, what i meant was...do i delete the old zip that i used to sideload .211 or just simply drop that zip on my sd and use your program to flash and reboot ??
#9 Geezio
Geezio
  • 42 posts
  • Twitter:gsmtz7r
  • Google+:gsmtz74@gmail.com
  • LocationAngleton Texas
Posted 04 July 2012 - 05:32 PM
Matt ...you rock dude ,thank you for this and i know more is to come!!:D
DROID RAZR MAXX..
#10 blueizee
blueizee
  • 35 posts
  • LocationFlorida
Posted 04 July 2012 - 05:33 PM
i went through recovery and applied update from sd.......and installation abortedd. Error in /tmp/sideload/package.zip (status 7) installation aborted...why is this ?
#11 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 04 July 2012 - 05:41 PM
Sweet! And here I thought we were done for awhile.
Thanks Matt.
#12 zephyrus14
zephyrus14
  • 216 posts
  • Twitter:@johnmarciniak
  • LocationThe Region
Posted 04 July 2012 - 05:44 PM
Ohhhhh boy!
#13 Nnnnr12
Nnnnr12
  • 418 posts
  • Google+:hairstont14
  • LocationLagrange, Ga
Posted 04 July 2012 - 05:54 PM
-_- Motorola
Sent from my .211 leak razr do you wanna get cut?
#14 alexh037
alexh037
  • 69 posts
  • LocationWoodland Hills, CA
Posted 04 July 2012 - 06:02 PM
Woohoo!! :-)
#15 quangtran1
quangtran1
  • 243 posts
Posted 04 July 2012 - 06:06 PM
Woohoo is right....
#16 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 04 July 2012 - 06:13 PM
You come through again man. Just one quick question : I have the. 79 leak on my non-safe side & Hashcode's flashable .211 on my safe side so can I use the utility to flash the boot.img?
#17 trekie4ever
trekie4ever
  • 285 posts
Posted 04 July 2012 - 06:33 PM
Just when I thought we were safe! Ugghh... I'm resisting
#18 graydragon2
graydragon2
  • 32 posts
Posted 04 July 2012 - 06:37 PM
I'm running Ikream on the nonsafe side. So do I flash this on the safe side or over Ikream.
#19 zachjeep
zachjeep
  • 172 posts
Posted 04 July 2012 - 06:44 PM
Anyone take the plunge?
#20 beaton3344
beaton3344
  • 29 posts
Posted 04 July 2012 - 06:48 PM
Just updated... Seems quicker but could just be me... Tried Google Now still no luck with that... Going to try tether next to see if it fixes my problems or makes in worse... LOL... Thanks Matt.. Your the man...
