Also, are you using ART or dalvik for runtime?
Posted 04 December 2013 - 06:04 AM
Posted 06 December 2013 - 10:38 AM
Posted 06 December 2013 - 11:32 AM
Try going to mobile network. Access point. And try selecting Verizon internet. Then toggle airplane on/then off
Posted 06 December 2013 - 11:57 AM
''Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.'' - Albert Einstein
Posted 07 December 2013 - 09:24 PM
I love kitkat on my razr hd maxx!
Here's my review of the ROM so far...
1.) installed without a hitch- using newest TWRP
2.) a little laggy to boot and get started, as with most fresh installs. had a nerdgasm with the boot animation.
3.) couldn't send mms until a reboot, then fine after that
4.) gallery app wouldn't show my auto upload folder, and was fc'ing my google plus
-solved this by uninstalling the gallery and installing the 4.3 camera/gallery apk
5.) bluetooth works on my motorola sd-10 headset and MB car audio
6.) GPS locked quick and without a problem
7.) persistent charging LED, which i killed with liteflow LED
8.) car dock mode when plugged into the car- any way to kill that?
9.) otherwise very smooth, snappy, and bug free
10.) can't speak to battery yet, i'll update after a full charge/discharge tomorrow... battery life is always inconsistent after a new rom installation and messing around with it for five hours straight.
11.) "OK Google" didn't work with nova launcher, only stock launcher
12.) new dialer configuration is going to take some real getting used to
13.) always love love love the native quiet hours and linked ringtone/notification volume
bottom line- this is definitely daily driver material in my opinion. thank you devs!
Posted 07 December 2013 - 09:26 PM
For the people who can send MMS, is your phone number and MIN showing up as unknown under "About phone"?
i had this after installation, but it went away after a reboot.
Posted 08 December 2013 - 09:41 PM
Updated Tonight!
Everyone Enjoy!
Posted 08 December 2013 - 10:14 PM
What is the new change log? 4.4.1 maybe?
Posted 09 December 2013 - 06:03 PM
Any luck with your MMS?
Posted 09 December 2013 - 07:07 PM
The Camera app in the 12/09 update is force closing if you use the front camera. The back camera is working fine.
Posted 09 December 2013 - 07:39 PM
Just try my mod and it should fix that
Flash it through recovery and enjoy.
That mod should work on any kitkat rom for Motorola
Posted 09 December 2013 - 08:31 PM
Posted 09 December 2013 - 08:35 PM
Thanks, it worked for me.
Posted 09 December 2013 - 08:36 PM
To anyone who has flashed this. 4.4 or 4.4.1 ? Thanks
4.4
Posted 10 December 2013 - 01:27 AM
No, a few comments that it started working after a reboot from a few people. I've rebooted, no luck.Any luck with your MMS?
Posted 10 December 2013 - 04:31 AM
Updated Tonight!
Everyone Enjoy!
Seems that on ANY rom, "OK Google" ONLY works on the stock launcher. Just sayin'
Posted 11 December 2013 - 08:10 PM
Posted 12 December 2013 - 07:18 AM
I had no wifi on several different AOSP versions so its an inherent problem it appears from source
Posted 12 December 2013 - 03:02 PM
on the GApps page, should I get the 4.4 or the 4.4.2 GApps?
Posted 12 December 2013 - 03:16 PM
