[ROM][4.4][Kit-Kat[PURE AOSP][XT926]{Updated 12/09/13}
rom 4.4 kit kat aosp xt926 razr hd razr hd maxx
188 replies to this topic
#141 brian199
brian199
  • 11 posts
Posted 02 December 2013 - 07:41 PM
Anyone's MMS working?
#142 tucstwo
  • Google+:tucstwo@gmail.com
Posted 02 December 2013 - 09:06 PM
I will see whats posted in the thread, but heres a link to my dropbox for 2.6.1
2.6.1. whatever is a NO GO go for 4.4. Nothing south of 2.6.3.3 will flash 4.4 so yea :p
I dont know where Tucs version came from, he probably compiled it himself, so @blametucstwo :)
Seriously tho, you have something odd going on since you are the only one having issues like this that I know of.
The one I've got came from...err..I don't remember but it's the same 2.6.3.3 everyone else has and the ONLY version of TWRP that is 4.4 friendly. So THERE! :p
Hi! Please, build this rom for xt925 too! :)
Enviado desde mi XT925 mediante Tapatalk
I will look into doing this for you! :)
MMS has been working just fine for the last 2 increments.
  • RikRong and Joseberga like this
#143 brian199
brian199
  • 11 posts
Posted 02 December 2013 - 10:39 PM
Is there anything I can do? I can receive just fine, but I cannot send an MMS. I've tried the Messaging app, Hangouts, and Handcent without any luck of sending. 32gb XT926
#144 boscocosta
boscocosta
  • 10 posts
Posted 03 December 2013 - 02:30 AM
external sdcard write problem solved:
See the OP and post 2 since the OP forgot the detail but you can see it in his jpg of the file edit.
This didnt work for me. Anyone else get this to work? I get invalid path error message when trying to browse with esfile explorer and others
#145 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
  • Twitter:@BionicMan_69
  • LocationCookeville, TN
  • Current Device(s):Motorola Droid Razr Maxx HD, Motorola Droid Bionic, Motorola Xoom, HTC Flyer
Posted 03 December 2013 - 02:33 AM
So where are you finding TWRP 2.6.3.3 ??? All I'm finding is TWRP 2.6.3.0
#146 cmh714
Posted 03 December 2013 - 06:35 AM
That sounds like user error my friend. Not sure what youre doing but it does work. I fixed CM11, Validus, AOSP etc.
Are you sure youre rooted and that your file explorer is set to mount the system as rw?
#147 cmh714
Posted 03 December 2013 - 06:37 AM
Not true. I am using 2.6.1.0 from Hashcode and have no problems whatsoever flashing 4.4 based ROM's. of course, YMMV :)
#148 boscocosta
boscocosta
  • 10 posts
Posted 03 December 2013 - 08:56 AM
yes across the board.
i've tried both copying the modified file over and editing it - no go
#149 cmh714
Posted 03 December 2013 - 09:00 AM
Well I know for myself and others this works, so its something odd on your end. This is it in a nutshell:
You need to edit the /etc/permissions/platform.xml file and add to the section WRITE_EXTERNAL_STORAGE the line:
<group gid="media_rw" />
Save and reboot.
#150 boscocosta
boscocosta
  • 10 posts
Posted 03 December 2013 - 09:43 AM
Save and reboot.
thats what I show. But even in storage it doesnt "see" the external card. I can post my copy of the file later tonight when i get home
#151 cmh714
Posted 03 December 2013 - 03:29 PM
if you cant read from it, well then you definitely cant write to it ;)
sounds like you have a different problem. I had some drive issues before like that, and a re-format worked
#152 boscocosta
boscocosta
  • 10 posts
Posted 03 December 2013 - 03:48 PM
works fine with other 4.x roms
#153 cmh714
Posted 03 December 2013 - 03:51 PM
Mine did to..... :) I had to copy about 40GB to my PC and then back again....but it worked.
#154 tucstwo
Posted 03 December 2013 - 04:01 PM
Um, in the OP :p
Sent from my LG-VS980
#155 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
Posted 03 December 2013 - 04:41 PM
Checked the op... leads to TWRP 2.6.3.0
#156 tucstwo
Posted 03 December 2013 - 04:44 PM
Oh, I understand, you asked for 2.6.3.3. Idk? The op has 2.6.3.0 which is the required version afaik. Who said 2.6.3.3?
#157 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
Posted 03 December 2013 - 07:48 PM
Right here.... there is a 2.6.3.3 for some phones. Thought might been for the xt926 why I was asking where found it at cause I never could.
#158 animez
animez
  • 59 posts
Posted 04 December 2013 - 01:30 AM
I'm in the same boat, can receive MMS but can't send. I have tried multiple apps as well.
#159 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
Posted 04 December 2013 - 01:52 AM
Have ya tried the 8sms messaging app from the play store. I've read some have had luck using it.
#160 animez
animez
  • 59 posts
Posted 04 December 2013 - 06:00 AM
Save and reboot.
I can confirm that this worked for me as well. I was not having trouble reading from the card, only writing to it.
  • cmh714 likes this
Also tagged with one or more of these keywords: rom, 4.4, kit kat, aosp, xt926, razr hd, razr hd maxx
