[ROM][4.4][Kit-Kat[PURE AOSP][XT926]{Updated 12/09/13}
rom 4.4 kit kat aosp xt926 razr hd razr hd maxx
188 replies to this topic
#101 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 19 November 2013 - 03:09 PM
I posted the fix for the sdcard in an earlier post. Edit the /etc/permissions/platform.xml and add the line to fix the problem.
I didn't see the fix.... sorry I'm new at this. what do you mean by add the line? I found the platform.xml document but I don't understand what I'm adding or changing. Thank you for your help, appreciated.
#102 cmh714
Posted 19 November 2013 - 03:18 PM
external sdcard write problem solved:
See the OP and post 2 since the OP forgot the detail but you can see it in his jpg of the file edit.
See this ^^^
#103 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 19 November 2013 - 03:43 PM
See this ^^^
Sweet! Will do. Thanks again.
#104 marellz
marellz
  • Current Device(s):Motorola Droid RAZR HD XT926
Posted 24 November 2013 - 09:13 AM
thanks for this. It installed but I'm just getting the black screen. I saw on xda this is a common thing though. Are you able to use this?
did this app work?? only my camera has issues..it doesnt work.. otherwise the rest is really awesome!!
#105 marellz
marellz
Posted 24 November 2013 - 09:14 AM
#106 tucstwo
  • Google+:tucstwo@gmail.com
Posted 24 November 2013 - 12:04 PM
Rom updated today :)
  • cmh714 and semiconformist like this
#107 darrenbanks_mk
darrenbanks_mk
  • 9 posts
  • Locationsouth Ga
Posted 24 November 2013 - 01:01 PM
Awesome news! Changelog?
#108 tucstwo
Posted 24 November 2013 - 01:35 PM
Well, for starters
over the last ten days is going to be included. :)
This is pure AOSP, so it's not as though "features" are added. It's all platform stuff, bugs removed, fixes things like that.
#109 semiconformist
semiconformist
  • 18 posts
  • Google+:plus.google.com/+AustinDennis
  • LocationChapel Hill, NC
  • Current Device(s):iPhone 6 (iOS 8.4.1 - Jailbroken)
Posted 24 November 2013 - 02:57 PM
Woot! Working camera with this version!
Tapped via Tapatalk
- Insert witty and/or advertisement filled signature here. -
#110 TjNaps27
TjNaps27
  • 80 posts
  • Twitter:tjnaps27
  • Current Device(s):"Dan" Edition Razr Maxx HD
Posted 24 November 2013 - 05:55 PM
Hey all. First I want to apologize if this has been answered already.
I used flashify to update twrp on my girls 16g HD which is currently running 4.3 cm and I want to put kk on it. But in twrp when I chose to make a backup of 4.3 on the SD card it fails saying it fails to write the folder twrp/backups,.... Any suggestions? Thanks in advance
#111 cmh714
Posted 25 November 2013 - 07:06 AM
I dirty flashed over the 11/8 build and I lost my keyboard....got it back by going into Settings and just changing some things and the keyboard was back
#112 stp2001
stp2001
  • 45 posts
  • Current Device(s):razr hd
Posted 25 November 2013 - 10:38 AM
check the memory make sure you have enough left. I can't think if anything else. What Twrp did update to.. 2.6.3 i am assuming.
#113 TjNaps27
TjNaps27
  • 80 posts
  • Twitter:tjnaps27
Posted 25 November 2013 - 10:39 AM
Yes 263 and there is memory left. Someone in the twrp thread suggested changing the auto generated backup name because it may be too long. Haven't tried that yet tho
#114 johnthehillbilly
Posted 25 November 2013 - 10:41 AM
There has been name length issues .... if you shorten the backup name / directory it may work.....
#115 Sleehrat00
Sleehrat00
    Moot Consumer
  • 90 posts
  • LocationNorth Carolina
Posted 25 November 2013 - 12:45 PM
Downloaded the newest AOSP build.  Unlocked RAZR MAXX HD xt926, running TWRP 2.6.3.
I am wiping the davlik, cache, system, and data.
Then when I try to install downloaded aosp zip package, I am getting Flash Failure every time.  Anyone else having this problem?!?
After the flash failure, I am not able to restore, until I reboot back into recovery where I can then recover from backup.
I have tried this about 3 times, and it just won't flash.
Current consumer, but hopefully one-day purveyor, of high quality moot products.
#116 cmh714
Posted 25 November 2013 - 01:38 PM
Flashed fine for me, maybe you have a bad download
  • tucstwo likes this
#117 Sleehrat00
Sleehrat00
    Moot Consumer
  • 90 posts
Posted 25 November 2013 - 01:40 PM
Interesting... I downloaded it twice.  I'll try again later tonight once I get home.
#118 Sleehrat00
Sleehrat00
    Moot Consumer
  • 90 posts
Posted 25 November 2013 - 02:26 PM
Okay, here's what I am seeing when the flashing fails:
Installing /external_sd/***.zip
Checking for MD5 file...
Skipping BD5 check: no MD5 file found.
set_metadata_recursive: some changes failed.
E: error executing updater binary in zip '/extern
Error flashing zip 'external_sd/
Updating partition details...
E:/ unable to mount '/system
Any thoughts/suggestions?
#119 stp2001
stp2001
  • 45 posts
Posted 25 November 2013 - 04:37 PM
make sure the mount system isn't checked. The zip will do it for you. That was my problem one time
#120 stp2001
stp2001
  • 45 posts
Posted 25 November 2013 - 04:38 PM
We have a Hangout that pretty moto specific if your interested send me your email mail
Also tagged with one or more of these keywords: rom, 4.4, kit kat, aosp, xt926, razr hd, razr hd maxx
