For some reason, I cannot write to my external sdcard anymore, permissions are different than on other rom's so need to mess around with that a bit. but not being able to write to my 64GB card is definitely a showstopper.
[ROM][4.4][Kit-Kat[PURE AOSP][XT926]{Updated 12/09/13}
#81
Posted 15 November 2013 - 08:17 AM
#82
Titanium works fine as long you aren't using art. I have restored every with titanium the only thing that did restore correctly was sms.
Correct, my comment was based on ART not Dalvik
#83
Posted 15 November 2013 - 08:49 AM
I, too, had no camera apk. I downloaded the one linked in post #73 with a black screen shown on first open.
Rebooted to try again and same results.
- semiconformist likes this
#84
Posted 15 November 2013 - 09:40 AM
I've tried a couple of different cameras and got the same results.
#85
Posted 15 November 2013 - 10:29 AM
my bad i missed that sorry.Correct, my comment was based on ART not Dalvik
#86
Posted 15 November 2013 - 10:37 AM
All good, no need for apologies. My comment wasnt necessarily that clear
#87
Posted 16 November 2013 - 11:29 AM
I love 4.4 and I can't wait for everyone's issues to be fixed! :-)
32gb xt926
Cwm touch 6.0.4.4 recovery
#88
Posted 16 November 2013 - 01:59 PM
STUPID QUESTION ALERT!!! lol how do I update my Cwm to 6.0.4.4??
#89
Posted 16 November 2013 - 06:18 PM
external sdcard write problem solved:
See the OP and post 2 since the OP forgot the detail but you can see it in his jpg of the file edit.
- livinginkaos likes this
#90
Posted 16 November 2013 - 10:02 PM
You will have to flash it in a command prompt...
-Download the recovery
-Change name to "recovery.img"
-Make sure you have the android SDK
-Copy the recovery image to the
-platform tools section of the SDk
-connect phone(USB debugging)
-power off and place into fastboot
-open command window inside the platform tools folder of the SDK file
-type "fastboot", "fastboot devices"
- now flash the recovery
- type "fast boot flash recovery recovery.img"
-reboot and profit:-)
#91
Posted 17 November 2013 - 05:28 AM
Any timeline on the mms and camera not working problem fix? That is the only thing keeping me from rocking this ROM.
#92
Posted 17 November 2013 - 07:24 PM
I didn't flash the SuperSU root file. Can I flash it and still have root?
#93
Posted 17 November 2013 - 07:28 PM
yes you can it should work just fineI didn't flash the SuperSU root file. Can I flash it and still have root?
- brian199 likes this
#94
Posted 19 November 2013 - 06:20 AM
#95
Posted 19 November 2013 - 07:38 AM
Is everyone just having issues with the camera on the 11/13 build? My camera worked fine before hand on the build b4 that. I still have that build on my sdcard IMA unzip both when I get home and compare, see if its something simple like a broken/missing permission
#96
Posted 19 November 2013 - 09:06 AM
yes camera broke in 11/13 build but works with the 11/8 build I think is what it was. That is what I am running since I always keep the previous version handy.
#97
Posted 19 November 2013 - 09:09 AM
So far this is one of the smoothest fastest feeling Roms. Problems I've noticed, no camera and or not working, caller id buggy coming up as unknown, SD card not accessible. I would love to help out. Thanks for this awesome ROM! Let's get er 100% :-)
I posted the fix for the sdcard in an earlier post. Edit the /etc/permissions/platform.xml and add the line to fix the problem.
- Slickademo likes this
#98
Posted 19 November 2013 - 09:14 AM
#99
Posted 19 November 2013 - 09:21 AM
I did it on the phone and it worked fine. But yes, you can do it on a PC.
#100
Posted 19 November 2013 - 02:46 PM
What about the MMS? Is that still not working as well?
Also tagged with one or more of these keywords: rom, 4.4, kit kat, aosp, xt926, razr hd, razr hd maxx
