[ROM][4.4][Kit-Kat[PURE AOSP][XT907]{Updated 12/9/13}
315 replies to this topic
#161 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 15 November 2013 - 04:52 PM
Still no go for a camera apk, its in the app directory, but reflashed rom, superu.zip, and PA gapps, still no camera.
Don't use the PA gapps.. for some reason they didnt work for me either.. and i lose camera with them.. use
Yes I tried the new radio, still the same old song and dance.
I can force it to use the VZWINTERNET 4g apn but then i lose all text and mms.
only time i lose 4g is when they decide i have used enough of their 4g and they start Throttling me but it never last more than a day or so.. i seem to get it back when i go to a heavy 4g and than go back home.
#162 aokifay
aokifay
  • 22 posts
Posted 16 November 2013 - 03:26 PM
can not flash
#163 PantherVT
PantherVT
  • 17 posts
  • Twitter:RaiderVT
Posted 16 November 2013 - 03:45 PM
can not flash
if you want help you will need to be a lot more specific
  • RikRong likes this
#164 aokifay
aokifay
  • 22 posts
Posted 16 November 2013 - 06:37 PM
I am a Chinese,my english is poor。
I flash this rom   with  twrp2.6.3.0,but i get a fail。。。。。
#165 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 16 November 2013 - 07:50 PM
do not mount system
#166 cmh714
Posted 16 November 2013 - 08:04 PM
No external SD :(
FIX HERE:
external sdcard write problem solved:
See the OP and post 2 since the OP forgot the detail but you can see it in his jpg of the file edit.
  • livinginkaos and jco23 like this
#167 jco23
jco23
  • 414 posts
Posted 16 November 2013 - 09:01 PM
FIX HERE:
That fix worked for me, thx!
ROM: OSE KitKat 4.4.2
#168 TheCheeze
TheCheeze
  • 25 posts
Posted 16 November 2013 - 09:07 PM
Follow-up: Went back to 4.1.2 and still didn't have any 4G. Replaced my sim card and it turned out that was the main problem (it seems). So on the downside I lost all of my internal-saved backups when i RSD'd but on the plus side it wasn't the rom's fault.
Still went back to OSE rom because we use a lot of group texting at work so I need functioning MMS. Loved the look/feel and hope for more to come of this soon though!
#169 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 16 November 2013 - 09:44 PM
FIX HERE:
would it help you guys if i make this into flashable.zip?
and to recap this rom has
Front facing camera recording bug
Ext-SD bug
Dhacker Gapps sync
MMS bug ( i heard reports of being fix or working of some people)
Little Graphical bugs
what other bugs am i missing?
  • jco23 and Calbrs04 like this
#170 aokifay
aokifay
  • 22 posts
Posted 16 November 2013 - 09:51 PM
do not mount system
let me  try again
#171 hecksagon
hecksagon
    Was a newb once...
  • 48 posts
  • LocationFreeport, IL
  • Current Device(s):Galaxy Note 3
Posted 16 November 2013 - 11:33 PM
Ext-SD bug
After running several benchmarks, GPU performance is less than half of what it is in CM 10.1. In tests that normally max out at 60 fps, I am seeing around 30. This seems to give the GUI a slight lag, since most of the heavy lifting is now done in the GPU.
On the plus side, with ART enabled, CPU performance is about 2x what it is in CM 10.1.
#172 jco23
jco23
  • 414 posts
Posted 17 November 2013 - 06:49 AM
Ext-SD bug
I have not found any "real bugs" yet.  however, i have noticed on 2 occasions during this week that the battery performance seemed to have been going well, and then when it hits around the 30% mark (regardless of screen time), it just drains at an exponential rate.  it could be the battery stats building back up again, but I have yet to pinpoint the issue.  i suspect that it could be kernel related - does anyone know if another kernel would/could work with this ROM?
#173 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 17 November 2013 - 06:58 AM
Or it might just be a battery reading bug... so maybe your phone wasnt at 30% but it was really at 14% because all phones usually should lose the first 10% of battery when fully charges in a matter of mins due to over charge protection which allows to charge battery to about 90 to 95%... if you notice when charging when it hits 90% the LED light will turn green signaling full charge...and this rom i seen reports of people losing only about 2% overnight... so that might be it... i might be extremely wrong but its not a big deal to me...
#174 jco23
jco23
  • 414 posts
Posted 17 November 2013 - 07:08 AM
agreed and understood.
just thought of 2 other things - they may or may not be bugs (and certainly not deal-breakers):
1.) I used to be able to copy a copy ringtone (mp3 format) from my external_sd to the system/media/ringtones directory, and use that ringtone.  however, when applying this ringtone on 4.4, the sound is just a blip rather than the full soundbyte.
2.) e-mail/text notification LED is white instead of green (facebook is normal at blue, and battery is normal at red) - so I'm not sure if this is intended (since the status bar icons have changed from blue to white), or if the color code was not setup properly (not really sure where to change it without using a 3rd party app).  also, I would like to be able to figure out how to turn off the LED while charging - don't really need that constant notification
otherwise, thanks to your format camera fix, the ext-sd card writing fix, adding in the official kitkat boot, and adding in the accurate battery mod - I'm at good spot (so long as the battery is able to hold up).
  • Calbrs04 likes this
#175 Rob626
Rob626
  • 87 posts
  • LocationRoswell, GA
  • Current Device(s):RAZR M, Nook HD+
Posted 17 November 2013 - 07:40 AM
So at this point, is this Tim's OSE build or DHacker's?
MMS does not work but video does?
With the patches, camera and SD card do work?
Tethering does work?
Nothing else doesn't work?
#176 Calbrs04
Calbrs04
  • 12 posts
Posted 17 November 2013 - 07:53 AM
So at this point, is this Tim's OSE build or DHacker's?MMS does not work but video does?With the patches, camera and SD card do work? Tethering does work?Nothing else doesn't work?Sent from my XT907 using Tapatalk
On the Cm 11 build, mms does work but you can't playback videos. It's a catch 22. Hopefully there is a fix soon. Loving aosp 4.4.
  • Rob626 likes this
#177 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 17 November 2013 - 08:03 AM
ok to answer your multimple questions.. MMS some people say works other say doesnt.. i dont use it so i dont really know.. i only use text and works fine. camera has always worked but patched to record with front camera, SDcard now mounts and is pretty much fixed it could be better but it works... tethering works and has always worked... and so to summarize all your questions into an answer... only thing that isnt working on the things you ask is the MMS try it.. im sure you will love it.
  • Rob626 likes this
#178 Rob626
Rob626
  • 87 posts
Posted 17 November 2013 - 08:18 AM
Thanks for the quick responses guys.
I ran Somber's CM11 when it dropped but had a few problems so I went back to 10.3.1. But I'm having similar freezes with that now,so it may be independent of the ROM.
I'm excited about the 4.4 development.
#179 shiftman
shiftman
  • 11 posts
  • Current Device(s):droid x
Posted 17 November 2013 - 09:19 AM
MMS works but video doesn't. Everything else works
#180 Rob626
Rob626
  • 87 posts
Posted 17 November 2013 - 09:57 AM
MMS works but video doesn't on Pure AOSP? I thought it was like that on CM11.
