so seriously... what are the bugs in this build? i cant find any... except by some little little minor graphic bugs that if you blink you will miss.. in my opinion this is more stable than 4.3
[ROM][4.4][Kit-Kat[PURE AOSP][XT907]{Updated 12/9/13}
#81
Posted 10 November 2013 - 09:28 PM
- Noigel and jco23 like this
#82
Posted 10 November 2013 - 09:46 PM
I think the issues that people are running into are related to install methods, etc. Honestly, it was the same kind of stuff that they were running into on 4.3.
- jco23 likes this
#83
Posted 10 November 2013 - 11:57 PM
Okay so i might be in over my head, but i just flashed my phone with TWRP 2.6.3.0 with flashify and it says Device is LOCKED, Status Code 0, Battery OK, Failed to Hab check for recovery: 0x56 , Fastboot Reason: Boot Failure.
my phone will boot but only stays on for about 30 seconds
#84
Posted 11 November 2013 - 12:15 AM
was your phone unlocked to start with? or you trying to do this with an out of the box phone?
#85
Posted 11 November 2013 - 12:33 AM
My phone was already unlocked.
#86
Posted 11 November 2013 - 01:15 AM
i mean if the phone come on.. you still can fix it.. either by going into fastboot and reflash the recovery from there.. or doing a full wipe and start over.
- Billyraytrey likes this
#87
Posted 11 November 2013 - 01:45 AM
Thanks, i got it! just had a little freak out, sorry about that.
#88
Posted 11 November 2013 - 01:50 AM
We all been there no worries... we always glad t help.
#89
Posted 11 November 2013 - 02:03 AM
The same is here. Laggy as 4.3.
The problem started after September 10. At least I'm using CM10.2 build from this date and it's snappy/
All later versions are laggy. Some changes in kernel? And very strange that no one else noticed that..
Does anyone see slight 'lag' present like on the 4.3 Roms? I wonder if it is a hardware issue or just because this is an alpha. Either way, Dhacker been doing this for some many legacy Moto devices, much respect.
#90
Posted 11 November 2013 - 04:07 AM
#91
Posted 11 November 2013 - 05:36 AM
Running buttery smooth, Only thing is I don't have a Camera app anymore. It's gone...
are you sure you installed the GApps? try rebooting to recovery and wiping cache/dalvik.
also, for those that don't know, the flashify app allows you to reboot and reboot recovery - a nice alternative since the framework for this ROM does not have the extended power menu (yet).
ROM: OSE KitKat 4.4.2
#92
Posted 11 November 2013 - 06:49 AM
ok update on battery on normal use (phone calls, text and not turning google voice off..) not bad if you ask me.
#93
Posted 11 November 2013 - 06:59 AM
I just flashed this rom and two things:
1. Wi-Fi not working - When I turn on Wi-Fi, the phone just says "Wi-Fi turn on" and just sits there. I noticed in Settings/AboutPhone/Status Wi-Fi mac address shows "Unavailable"
2. I lost root when I installed this rom. Root checker closes down when I try and bring it up. SuperSU said I need to update binary and then a screen to boot into recovery (TWRP) and when I push ok, it does not reboot.
The rom really seems good so far, of course I need Wi-Fi and root
#94
Posted 11 November 2013 - 07:17 AM
do you install the supersu update file per the OP?
no problems with wifi here.
#95
Posted 11 November 2013 - 07:20 AM
yep same here, lost the camera, no camera app in drawer/home
flashing :
build 11-Nov-2013
gapps
super su
wipe
restart
i look into /system/app/ it has "camera2.apk"
n also i try instal moto camera it say " Camera error" Camera is unable to initialize
#96
Posted 11 November 2013 - 07:22 AM
My mistake on the SuperSu - I had not installed the SuperSu zip file I downloaded from the first page of this topic. I manually booted in fastboot, into recovery and used TWRP and installed the zip. Now if SuperSu comes up allright - does that mean I did not lose root? Rootchecker still closed when I try to bring it up.
#97
Posted 11 November 2013 - 07:34 AM
flashing :
build 11-Nov-2013
gapps
super su
wipe
restart
are you able to get to it from the gallery app? how about a 3rd party camera app?
correct, if it comes up, then you should still have root.
i would try the process again:
reboot recovery
wipe cache/dalvik/system/data/internal storage (making sure that you have the files saved to your external SD)
reboot recovery
install ROM
install GApps
install supersu update
reboot
no need to mount system
#98
Posted 11 November 2013 - 07:37 AM
something positive I noticed is that the stock e-mail app now allows you to combine all of your e-mail accounts (gmail, verizon, yahoo, etc). in JB, it could not.
also, battery life has been fine thus far (with bluetooth and google now off).
#99
Posted 11 November 2013 - 07:57 AM
reboot recovery
reboot recovery
install ROM
install GApps
reboot
Did the above and Wi-Fi is working great! Now another question - Checked the phone and I have no camera. Is there a way to get it??
Many thanks for all the help!!
#100
Posted 11 November 2013 - 07:58 AM
Just reread the post and caught what it said about camera - going to try that
