Bionic running slow
4 replies to this topic
#1 r1028
r1028
  • 38 posts
  • Locationarizona
  • Current Device(s):motorola droid bionic
Posted 04 November 2013 - 10:27 AM
I hope this is the correct section, if not, my apologies in advance.
I have noticed my Bionic is very slow, and unstable. I am rooted, currently on CM 10.3. I have tried (from memory) avatar, liquid, raging jelly, blurry etc, Im pretty sure I have tried every custom rom available. All of them with certain problems, be it lag, or camera not working, or connection problems etc. Is there anything left to do to try to fix my issue? I didnt realize just how slow my phone was until I got a nexus tablet. Is this normal?
I dont want to upgrade, I love the phone overall. Just wish it was still performing well like it did originally.
#2 livinginkaos
Posted 04 November 2013 - 10:33 AM
Sometimes, you just need a fresh start- I suggest reviving it with an FXZ flash.
  • r1028 likes this
#3 r1028
r1028
  • 38 posts
  • Locationarizona
Posted 04 November 2013 - 11:28 AM
You may be right, i was hoping to avoid this, but it may be the only option
#4 King Howie
King Howie
    Minister of Jackbooted Thugs
  • 882 posts
  • Current Device(s):Galaxy S4 GPE, Nexus 7 (2013)
Posted 04 November 2013 - 11:46 AM
Install app cache cleaner (infolife), fast reboot (great bytes) and seeder (lcis). I was running them on my bionic and they helped a good bit. Seeder runs in the background to keep things rocking. I believe fast reboot can be set to automatically fast reboot the phone.
Also, periodically clearing cache in TiBu helps a great deal
  • livinginkaos likes this
#5 rp201
rp201
  • 7 posts
  • Current Device(s):bionic
Posted 15 November 2013 - 10:14 PM
make sure your internal memory is not full or near capacity. (8gb internal memory referred to as sdcard because your pysical-SDCARD is referred to as sdcard-ext)
