- Latest CM Bells & Whistles
- Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
- Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
- Turn screen on when plug/unplug the USB cable as an option in settings;
- Reboot Menu Enable by default;
- Brightness control sliding through status bar;
- Custom Carrier Label;
- Status Bar Transparency and Custom Colors;
- Status bar network speed indicator with option to custom colors;
- Option to auto hide network speed indicator when there is no traffic;
- Status bar quick peek;
- Notification drawer + Notification row Transparency, custom Colors and custom image;
- Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
- Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
- Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
- Appbar from ChameleonOS;
- Lockscreen based on gestures from ChameleonOS;
- HALO 2.0 by ParanoidAndroid;
- BlackUI (Darkness), TRDS from Slim Roms;
- LCD density changer
- Option to enable notifications light even with screen on;
- Option to enable lock screen rotation;
- Open tiles in floating window;
- QS tile fast charge;
- Powerwidget toggle fast charge;
- Speed up statusbar / notification drawer;
- Alternate default app picker;
- Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
- Floating window from notification drawer (Long press);
- Option to show Wifi name in notification drawer;
- Option to flip tiles in simple press;
- Listview Animation;
- Listview Interpolator;
- SlimRoms Nav bar
- SlimRoms PIE
- Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
- Custom Boot Animation (JaeKar99) You are the man
- dustinb for allowing us to use his cobalt themes
- More to come........
1. Follow normal flashing rules
2. Use only 4.3 Gapps
3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
The Titanic
Vtwinbmx
JaeKar99
dustinb
CM Moto team
SlimRoms
Satman80.... Don't even question why
DOWNLOAD LINK:
http://www.drdevs.co...pha_1-d2spr.zip
