[{ROM}] GZR Presents Validus13 (d2att) 4.3.1
6 replies to this topic
#1 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 01 November 2013 - 03:29 PM
  • Latest CM Bells & Whistles
  • Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
  • Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
  • Turn screen on when plug/unplug the USB cable as an option in settings;
  • Reboot Menu Enable by default;
  • Brightness control sliding through status bar;
  • Custom Carrier Label;
  • Status Bar Transparency and Custom Colors;
  • Status bar network speed indicator with option to custom colors;
  • Option to auto hide network speed indicator when there is no traffic;
  • Status bar quick peek;
  • Notification drawer + Notification row Transparency, custom Colors and custom image;
  • Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
  • Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
  • Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
  • Appbar from ChameleonOS;
  • Lockscreen based on gestures from ChameleonOS;
  • HALO 2.0 by ParanoidAndroid;
  • BlackUI (Darkness), TRDS from Slim Roms;
  • LCD density changer
  • Option to enable notifications light even with screen on;
  • Option to enable lock screen rotation;
  • Open tiles in floating window;
  • QS tile fast charge;
  • Powerwidget toggle fast charge;
  • Speed up statusbar / notification drawer;
  • Alternate default app picker;
  • Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
  • Floating window from notification drawer (Long press);
  • Option to show Wifi name in notification drawer;
  • Option to flip tiles in simple press;
  • Listview Animation;
  • Listview Interpolator;
  • SlimRoms Nav bar
  • SlimRoms PIE
  • Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
  • Custom Boot Animation (JaeKar99) You are the man
  • dustinb for allowing us to use his cobalt themes
  • More to come........
      1. Follow normal flashing rules
      2. Use only 4.3 Gapps
      3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
The Titanic
Vtwinbmx
JaeKar99
dustinb
CM Moto team
SlimRoms
Satman80.... Don't even question why
DOWNLOAD LINK:
http://www.drdevs.co...pha_1-d2att.zip
#2 rsel
rsel
  • LocationCanada Ontario
  • Current Device(s):Samsung Galaxy S3
Posted 03 November 2013 - 08:00 PM
Hi new here. Love this rom but about 5 mins after running updated to a cm10.2  snapshot any idea why should i have ignored the update ??
#3 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 04 November 2013 - 04:15 AM
I'm glad you like the rom and as far as update goes cm just released a update yesterday. We will get around to updating just have to find time
#4 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 04 November 2013 - 07:47 AM
I have a few more edits to make prolly gonna get rid of the cm updator script as well. It is cm based but if you update you'll lose all v13 and be straight cm
#5 rsel
rsel
Posted 04 November 2013 - 09:21 PM
Awsome thanks guys had revert back though my data wasnt working seems my apn settings were also lost in the flash tried to set it up but fail lol still a little green here ... definatley want to get this rom working at full functionalaity if any suggestions for the data let me know    thanx in advance
#6 paulb
paulb
Posted 05 November 2013 - 06:12 AM
Great Rom.  I think I tried every 4.3 rom on XDA before finding this site, but now I have a new favorite.  I have been running it for less than a day, but everything has been rock solid so far and I can't think of a feature that I'm missing.
rsel, I lost my APN's when I flashed this too.  These settings are working for me.  Make sure to hit menu and save before backing out of the edit screen.
APN: phone
Proxy: ~Not set~
Port: ~Not set~
Username: ~Not set~
Password: ~Not set~
Server: ~Not set~
MMSC:http://mmsc.mobile.att.net
MMS Proxy: proxy.mobile.att.net
MMS Port: 80
MCC: 310
MNC: 410
Authentication type:
APN type: default,mms,supl
#7 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 16 November 2013 - 06:25 AM
With the transition to 4.4 I myself am taking a break from building which means I will not be releasing any more updates for this rom. Hang tight and great things should be coming soon.
