Assert Failed Apply_Patch_Check
1 reply to this topic
#1 siddyboy21
siddyboy21
Posted 01 July 2012 - 08:05 AM
Good all,
ok so i have a motorola droid razr xt910 and it was running a latin america build of 2.3.6, so i used the ics brasil leak to upgrade to ics and everything worked fine. so i decided to try out anothera new build that i saw online but it didnt work. So i reverted to the blur_version.651.167.3370.xt910.brasil.en.br.zip
the fastboot file flashed fine but now when trying to re-apply the update i am getting an error:
assert failed apply_patch_check (MTD:boot:8388608:f7b...blah blah
E: Error in /tmp/sideload/package.zip
status 7
and then the installation aborts, i searched everywhere possible and i am not getting and information to help so this is literally my last resort.
i read that there some mismatch in the preinstall the fix is to boot into android and remove what ever the error is but i can boot into GB because i was on ics.....please is there any advise anyone out there can give to maybe help solve this issue i have been going none stop at the issue for 14hrs now.
Thank you very very much!
#2 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 01 July 2012 - 11:29 AM
I think he is fixed now... :)
