Serious help! major problems
3 replies to this topic
#1 droidub
droidub
Posted 23 October 2013 - 07:33 PM
Hello all,
I am new to the whole rooting process, but I discovered a problem after rooting. Now when I try to call my phone begins to freeze but will dial out but I cannot here it ring nor can I talk to anyone. (No audio through my headset) and the same thing happens for incoming calls. I tried to use my voice search and it is saying it can't find a mic. I'm also no longer able to play videos or Pandora. I also have no sound coming from the phone and no alerts work.
I need help!!!
#2 lowvolt
lowvolt
  • 478 posts
Posted 23 October 2013 - 07:40 PM
All you did was root?
Try rebooting. Also download a root checker app and see if you do in fact have root.
If that all fails search this forum for the fastboot files for your device and restore to factory.
Sent from my XT1060 using Tapatalk
  • neckchop and RikRong like this
#3 LDubs
LDubs
    Pawn In Game of Life
  • 9,726 posts
  • Twitter:lew_bklyn
  • LocationBrooklyn, NY
Posted 24 October 2013 - 11:53 AM
Agreed, none of these issues would (should) be caused by simply rooting the device...
#4 livinginkaos
Posted 24 October 2013 - 03:22 PM
Rooting a device by itself affects none of the system that handles phone function. Something else is going on.
Sent From My DEV X
