[ROM][4.4.2][Official][OSE Rom][mb886]
26 replies to this topic
#1 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 23 October 2013 - 05:57 AM
__________________________________________________________________________________________________
OSE Nor Anyone @ DroidRZR.com Are Responsible For What You Do With Your Device.
* Based On Slim
* DarkUI Toggle Theme
* Multi-Window
* PIE Navigation
* Custom Navbar Options
* Custom Clock Options
* Custom Battery Options
* CRT Animation Control
* Init.d Support
* Init.d Tweaks
* All Features in
* HALO
* System App Remover
* OnTheFly DensityChanger
* App Ops
* OmniSwitch
* Lockscreen Notifications
* Build Prop Mods
* Suspend Actions
* Wake Lock Blockers
* & Much More...
* Download The Rom
* Download OSE GApps
* Wipe System, Data, Cache & Dalvik
* Install Rom & OSE GApps
* Reboot
* Enjoy
  • lolhandsup and Timothy like this
#2 deoli12
deoli12
Posted 23 October 2013 - 05:57 PM
i have a motorola atrix hd, i want to know if hdmi works
#3 vstar64
vstar64
  • Current Device(s):atrix hd
Posted 23 October 2013 - 06:42 PM
sorry for being a newb but can anyone direct me to a step by step guide to install a rom on the atrix hd (this one)
i have unlocked bootloader and root with motocopter and motocoplse (misspelled more than likely)
i dont know how to proceed from here, like i said im a total newb. im having a hard time understanding
i cant seem to install cyanogen recovery or fastboot method.
sorry for asking here, having a hard time finding a device specific thread, and figured i might be able to get the best result on the most recent thread that would have knowledgeable people who would be able to help me
my apologizes if this is the wrong place to ask this
and many thanks to any who might be able to provide answers that assist me
#4 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 23 October 2013 - 07:53 PM
You will need to Install a custom recovery such as twrp or cwm look at the how to for that first then please try to install the rom after :) message me on hangouts if needed zooyork0721@gmail.com
  • vstar64 and Timothy like this
#5 vstar64
vstar64
Posted 24 October 2013 - 04:27 AM
Thank you I'll do that after work.
And more than likely I'll have to message you later today.
#6 RPalomo
RPalomo
  • LocationGuatemala
  • Current Device(s):Motorola Atrix HD - MB886
Posted 24 October 2013 - 04:46 AM
I have noticed that when no one answers questions about hdmi, this is a great feature that you do not have to disposition in this rom. the question is, because it has been developed? or are not important?
Enviado desde mi MB886 usando Tapatalk
#7 DSC_Cons
DSC_Cons
  • 6 posts
  • LocationSeattle, WA
  • Current Device(s):Atrix HD MB886
Posted 24 October 2013 - 09:23 AM
This should show you everything you need to know on how to root the Atrix HD MB88.
OSE--Hands down the smoothest ROM I've installed on my phone.  Very nicely done...Thanks
  • lownslow200sx, zooyork0721, timpohladthomas and 1 other like this
#8 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 25 October 2013 - 12:59 PM
Quick update: We have had reports of issues with Google play services and also swiping the keyboard causing a force close, so I have completely rebuilt our Gapps and have found no issues. I just uploaded the latest version so they should be available soon.
  • DSC_Cons likes this
#9 vstar64
vstar64
Posted 25 October 2013 - 06:07 PM
@dsc_cons
Fleeing the Link you provided, reading it and getting the gist, I stumbled across to different links by the same author.
Well one was a link he provided straying to utilize ROM manager + photon cwm.
Then I found
Which says I can use ROM manager and the cwm touch through the same method if I read it correctly. Once I do that I can follow the directions in the link I provided to install this ROM.
Is that right?
Is there a better method?
I still need to set up the proper PATH with to follow the link you provided.
I also have myth tool downloaded, buy needs to be set up. Some threads I have read require/suggest using that.
My problem so far is that I think I an either reading to much into it or getting confused by the over abundance of information. (rarely do I ever come across this issue)
I use to be an iPhone guy however, I can no longer stand them, I prefer Android however on stock ROM the Atrix HD seems to be lacking.
#10 DSC_Cons
DSC_Cons
  • 6 posts
Posted 25 October 2013 - 10:11 PM
I tried that link but it never worked out for me, touch is paid for software, for some reason I couldn't get it to flash....this is all I did....
Download Motochopper/Motopocalypse.  This will unlock the bootloader and root your phone with super user with the click of a button.
You're rooted now...your phones open, use fastboot in Command prompt on your PC to load up CWM recovery file and you should be golden.
  I found this page after the motochopper root and this is all I've referenced to root my Atrix.
Good luck man....Welcome to the revolution
#11 Darhood
Darhood
  • Twitter:dsillydude
  • Google+:dsillydude
  • Locationtz
  • Current Device(s):Motorola droid razr XT912
Posted 26 October 2013 - 08:45 AM
can i flash it on my razr xt912
#12 vstar64
vstar64
Posted 26 October 2013 - 11:30 AM
so did this, but im getting stuck on step 6 of
Install CWM Recovery by Epinter
  1. Please Login or Register to see this Hidden Content
  2. Please Login or Register to see this Hidden Content
  3. On stock rom, navigate to /system/etc and rename install-recovery.sh to install-recovery.sh.bak
  4. Reboot into fastboot -- use "adb reboot bootloader" from Terminal\Command Prompt
  5. Wipe the existing recovery -- "fastboot erase recovery" !
  6. Flash the recovery with "fastboot flash recovery cwmrecovery6028-xt925_20130219-epinter.img"
  7. That's it, CWM is installed.
it tells me that the:
variable is not supported. target reported max download size 31457280 bytes
error: cannot load  'cwmrecovery6028-xt925_20130219-epinter.img': no error
im sorry for being a noob. also i should probably stop hijacking this thread. apologies to the op.
#13 DSC_Cons
DSC_Cons
  • 6 posts
Posted 27 October 2013 - 03:17 AM
XT912's a different breed bro.....
Go here.....
#14 DSC_Cons
DSC_Cons
  • 6 posts
Posted 27 October 2013 - 03:49 AM
vstar.....tried like three times before my root CWM finally flashed but this is the only thing I can think of that I did different and I left this step out...my bad
I started from the beginning which is to re-install fast boot which takes everything back to stock 4.1.1 with fast boot weather your JB or ICS.  If you're ATT MB88six(my six key is broke).
Download whatever xml fastboot file fits your phone.  Extract that file to the fast boot folder right click and open as a notepad document...it will look like this.  Delete the two lines "Getvar" files that I've highlighted, don't leave spaces, re-align everything back up after deleting the line, and then save as what ever name you want .xml.  Then use this "New" .xml as your foundation for fastboot and CWM recovery not the original you downloaded in step 1 of install stock fastboot.
 <steps interface="AP">
    <step operation="getvar" var="max-download-size" />
    <step operation="flash" partition="partition" filename="gpt_main0.bin" MD5="F36E6FB37E6BD0066FAF56688603DDD0" />
    <step operation="flash" partition="sbl1" filename="sbl1.mbn" MD5="3F91C106A878810B0AE8132F3FB8EACC" />
    <step operation="flash" partition="sbl2" filename="sbl2.mbn" MD5="6A4BF8E8480F3A14EB22A932314B430F" />
    <step operation="flash" partition="sbl3" filename="sbl3.mbn" MD5="AC66902C8721200A2FC08E485D4510D2" />
    <step operation="flash" partition="rpm" filename="rpm.mbn" MD5="919D0B340CFDD5FC7C541803DB65C2D6" />
    <step operation="flash" partition="tz" filename="tz.mbn" MD5="ED1C505E36E769CCF0BB3C10E46DD62B" />
    <step operation="flash" partition="aboot" filename="emmc_appsboot.mbn" MD5="15F98BAFB7C4853C2582465EEB7A3522" />
    <step operation="reboot-bootloader" />
    <step operation="oem" var="fb_mode_set" />
Install Stock Fastboots JB
  2. Extract the zip
  3. Open a terminal to the extracted zips directory
  5. Type the following commands in this order
  6. fastboot flash boot boot.img
  7. fastboot flash devtree device_tree.bin
  8. fastboot erase system -w !
  9. fastboot flash system system.img
  10. fastboot -w
  11. fastboot erase cache !
  12. fastboot reboot
Install Stock Fastboots ICS
  2. Extract the zip
  9. fastboot flash system system.img.ext4
  10. fastboot erase cache !
  11. fastboot -w
  12. fastboot reboot
Install Alternate Radio
  1. Reboot into fastboot
  2. fastboot flash modem NON-HLOS.bin
NON-HLOS.bin is found inside a fastboot zip.
Don't forget to Install the Alternate Radio right after the fastboot install.
Download your CWM file...name it whatever you want .img and make sure its in the fastboot folder when using fastboot.
Hope this helps man....I've been using ROMS with G2 and G3 for years....I broke my G3 and a buddy gave this Atrix that performs great with the OSE ROM.  Way quicker, battery last, smooth as silk for me, no glitches.  Out of all the ROMS I've Downloaded for my Atrix this is the only one that has been pure and glitch free.  Rooting newer phones is much easier than this...I'll try to help you the best I can, but I'm rather new when it comes to the Atrix root myself.  Good luck.
#15 DSC_Cons
DSC_Cons
  • 6 posts
Posted 27 October 2013 - 04:13 AM
I never did step #3 either....I rebooted into adb wiped the original recovery and then flashed the CWM recovery.  I also read along the line that you should open and run all the .exe files for fastboot before using it in command prompt on your pc.  So the fastboot folder you made on your pc with the .exe files in it....right click and run on you pc...you'll see a command prompt flash real quick.  Hope that makes sense.
#16 lollercoaster
lollercoaster
Posted 19 November 2013 - 02:29 PM
So I tried flashing CM 11 on my atrix, which was already running CM 10.2. I absent-mindedly forgot a few things, and it got bricked.
I first tried flashing ATT-4.1.1 firmware with RSD lite 6.1.5, but that didn't work like the last time I bricked the phone. I'm guessing because it's impossible to downgrade firmware.
Then I tried flashing CM 10.2 and some roms from here, but they didn't have an XML file like the stock firmware does, so it won't work.
What should I do?
#17 DSC_Cons
DSC_Cons
  • 6 posts
Posted 24 November 2013 - 04:53 AM
Your answer is right above.  Install fastboot on your Atrix and follow the steps.  I took mine from ProBam 4.3 back down to 4.1.1 using the method above and took it right back down to factory.  Been out of town for a couple weeks, sorry about the extended reply.  I'm not a big fan of RSD...Fastboot is like basic DOS, faster and more evasive...meaning you're totally re-programming the phone with fastboot where as RSD you're relying more so on the program.
#18 jacobc6
jacobc6
Posted 24 November 2013 - 05:30 PM
I have recently downloaded and applied this rom i now have no play store on my phone Help????
#19 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
Posted 24 November 2013 - 06:11 PM
you need to flash gapps like said in the directions sir.
#20 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 December 2013 - 06:01 PM
Updated for 4.4.1
