{ROM}(GZRoms)Validus 13 (XT1060)
7 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 17 October 2013 - 12:09 PM
  • Latest CM Bells & Whistles
  • Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
  • Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
  • Turn screen on when plug/unplug the USB cable as an option in settings;
  • Reboot Menu Enable by default;
  • Brightness control sliding through status bar;
  • Custom Carrier Label;
  • Status Bar Transparency and Custom Colors;
  • Status bar network speed indicator with option to custom colors;
  • Option to auto hide network speed indicator when there is no traffic;
  • Status bar quick peek;
  • Notification drawer + Notification row Transparency, custom Colors and custom image;
  • Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
  • Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
  • Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
  • Appbar from ChameleonOS;
  • Lockscreen based on gestures from ChameleonOS;
  • HALO 2.0 by ParanoidAndroid;
  • BlackUI (Darkness), TRDS from Slim Roms;
  • LCD density changer
  • Option to enable notifications light even with screen on;
  • Option to enable lock screen rotation;
  • Open tiles in floating window;
  • QS tile fast charge;
  • Powerwidget toggle fast charge;
  • Speed up statusbar / notification drawer;
  • Alternate default app picker;
  • Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
  • Floating window from notification drawer (Long press);
  • Option to show Wifi name in notification drawer;
  • Option to flip tiles in simple press;
  • Listview Animation;
  • Listview Interpolator;
  • SlimRoms Nav bar
  • SlimRoms PIE
  • Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
  • More to come........
     Known Issues
report here do not have phone to test, but has been tested boots and runs
so far: mms is borked no sound on phone ringer and video playback
Big Thanks:
Cristiano Matos(for his wonderful concept)
dustinb
DrDevs
JaeKar99
Dhacker
Hashcode
CM Moto team
Team Liquid
SlimRoms
And everyone that enjoys our work :)
Download:
http://www.drdevs.co...roms/Validus13/
Custom Wallpapers:
http://www.drdevs.co...alidus13_Walls/
  • shane1 likes this
#2 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 October 2013 - 04:37 PM
And I'm sure a safestrap version will be soon to follow ;)
sig made by
Rinkle McBally
#3 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 17 October 2013 - 06:45 PM
Quit trolling with your SS device. :D
#4 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 October 2013 - 07:03 PM
sig made by
Rinkle McBally
#5 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 17 October 2013 - 07:30 PM
I heart you.
  • shane1 likes this
#6 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 18 October 2013 - 01:45 AM
We'll see bud just waiting for a better kernel source
#7 BladeRunner
BladeRunner
    Chatroom Tech Support
  • 347 posts
  • LocationMaine
Posted 27 October 2013 - 05:12 AM
Booted and running on an xt1080 DE. Looking good so far. Hard keys don't work but no biggie with the soft keys working.  GPS is iffy, not really sure as I am inside right now. It gets me in the general area which tells me its working off the cell towers and not GPS
satellites. Camera works but taking a video seems to break the camera and forces a reboot after a couple of minutes.  Data and wifi work fine.
This actually a really good start compared to some devices as most things work.
#8 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 27 October 2013 - 05:31 AM
All goes well I'll have an update with some fixes very soon
