[ROM][XT1060][Unofficial][4.3]Cyanogenmod 10.2 {Updated 11/6/13}
moto x cm 10.2 cyanogenmod 4.3 jellybean
1 reply to this topic
#1 tucstwo
  • Google+:tucstwo@gmail.com
Posted 17 October 2013 - 07:51 AM
Attached File  cm.png   49.41KB   12 downloads
Cyanogenmod 10.2
for the Moto X (ghost) VZW/CDMA variant
This is just a self compiled CM 10.2 build based on the kernel and device trees offered by the Razr QCom Dev-Team. I haven't done anything special to it, just a sync and build. I didn't see it posted here, so I figured I'd share. Time to get show some love to the new moto's. All credit goes to the CM team and the Razr QCom team.
Installation Instructions (First time):
Download zip
Download GApps
Put zips on SD Card
Reboot into TWRP or CWM
Wipe(!) Data, Cache, Dalvik Cache
Flash the zip
Flash GApps
Reboot
Installation Instructions (Update):
Download zip
Put zip on SD Card
Wipe Cache
Wipe Dalvik Cache
(if you don't wipe system, the updater script will do it for you and you will not have to reflash gapps)
Flash Zip
Reboot
Is Root not working?
Go to Settings>About
Click on "Build Number" 7 times to enable Developer Options
Go to Settings>Developer Options
Enable USB debugging and set Root Access to ADB + Apps
What Works/Don't Work?:
You tell me, I don't even have a Moto X
Sources:
Cyanogenmod
Cyanogenmod Gerrit review
Razr Qcom Dev-team
DOWNLOADS:
Rom
10.2 GApps
*Disclaimer* I nor Droidrzr.com/DRDevs.com/Cyanogenmod or anyone else is reponsible for what you do with your device. It is your understanding that by flashing this rom or any other zip provided is fatal for your device. I do not have a Moto X to test this rom on. You're the tester! If you can not agree to these terms, DO NOT Flash this. Your device, your consequences.
ENJOY!
  • Memnoch73 and shane1 like this
#2 tucstwo
Posted 06 November 2013 - 04:21 PM
updating tonight
Also tagged with one or more of these keywords: moto x, cm 10.2, cyanogenmod, 4.3, jellybean
