[{ROM}] GZR Presents Validus13 (jfltevzw) 4.3.1
8 replies to this topic
#1 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 16 October 2013 - 11:30 AM
  • Latest CM Bells & Whistles
  • Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
  • Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
  • Turn screen on when plug/unplug the USB cable as an option in settings;
  • Reboot Menu Enable by default;
  • Brightness control sliding through status bar;
  • Custom Carrier Label;
  • Status Bar Transparency and Custom Colors;
  • Status bar network speed indicator with option to custom colors;
  • Option to auto hide network speed indicator when there is no traffic;
  • Status bar quick peek;
  • Notification drawer + Notification row Transparency, custom Colors and custom image;
  • Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
  • Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
  • Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
  • Appbar from ChameleonOS;
  • Lockscreen based on gestures from ChameleonOS;
  • HALO 2.0 by ParanoidAndroid;
  • BlackUI (Darkness), TRDS from Slim Roms;
  • LCD density changer
  • Option to enable notifications light even with screen on;
  • Option to enable lock screen rotation;
  • Open tiles in floating window;
  • QS tile fast charge;
  • Powerwidget toggle fast charge;
  • Speed up statusbar / notification drawer;
  • Alternate default app picker;
  • Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
  • Floating window from notification drawer (Long press);
  • Option to show Wifi name in notification drawer;
  • Option to flip tiles in simple press;
  • Listview Animation;
  • Listview Interpolator;
  • SlimRoms Nav bar
  • SlimRoms PIE
  • Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
  • Custom Boot Animation (JaeKar99) You are the man
  • dustinb for allowing us to use his cobalt themes
  • More to come........
      1. Follow normal flashing rules
      2. Use only 4.3 Gapps
      3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
The Titanic
Vtwinbmx
JaeKar99
dustinb
CM Moto team
SlimRoms
Satman80.... Don't even question why
DOWNLOAD LINK:
http://www.drdevs.co..._1-jfltevzw.zip
GZ GAPPS:
http://www.drdevs.co....3_10302013.zip
Link for custom wallpapers:
http://www.drdevs.co...alidus13_Walls/
#2 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 18 October 2013 - 03:23 PM
rom updated with latest cm commits and added lock ring battery gauge
#3 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 21 October 2013 - 05:43 PM
Update coming tomorrow
#4 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 22 October 2013 - 11:34 AM
Build updated 10/20
Removed Greenify in settings (caused a few conflicts when trying to upgrade still imbedded in rom)
Added Omni's Multi-Window granted still WIP but i liked it  :)
And yes MMS is working
#5 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 27 October 2013 - 03:40 PM
rom updated get it
#6 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 27 October 2013 - 05:42 PM
10/27
Building with -03 Flags for a lil extra linaro smoothness
Traffic Meter in Statusbar option
Misc. Fixes
Dunno about mms i'm trying and i dont wifi tether so your guess is as good as mine
All the latest cm commits
#7 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 01 November 2013 - 03:24 PM
11-1-2013
It's the first of the month get your fix rom has been updated:
Latest cm commits
Updated trebuchet launcher
#8 jpcalhoun
jpcalhoun
  • 178 posts
  • LocationCentral PA
  • Current Device(s):Galaxy S4 Dev Edition
Posted 02 November 2013 - 05:31 AM
11-1-2013
Latest cm commits
Anyone running this ROM?  If so how about sharing your experience with it.
#9 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 16 November 2013 - 06:26 AM
With the transition to 4.4 I myself am taking a break from building which means I will not be releasing any more updates for this rom. Hang tight and great things should be coming soon.
