[Rom - Stock][Razr - Cdma] De-Odexed & Zipaligned 6.16.211 Base (7-1)
6.16.211 deodexed razr 4.0.4
85 replies to this topic
#1 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 28 June 2012 - 09:10 AM
Deodexed and Zipaligned 6.16.211 base
So I am slowly learning how to make roms and thought this
would be a good contribution. It is a deodexed and zipaligned
6.16.211 Base that I modified off of Hashcodes base 6.16.211 rom.
I have not debloated anything, the only things that are removed
where the few apps that could not be deodexed. I have made a
odex-files.zip with the odex files in it that could not be deodexed.
I added in a 1% mod, credit to the Artic team, since that is one of the
reasons people are going to be using this. This is rooted and has
busybox installed. I hope some people can put this to
good use and hopefully It will save them some time.
If you use this please give credit where credit is due.
Enjoy~
I would like this to stay on droidrzr.com, please do not re-post this to
other places. If you want to share just post a link to this thread.
DO NOT INSTALL THIS WITH BOOTSTRAP! If you do
I will not be able to give you support and help with any problems you have with it.
Mattlgroff: For always answering my questions no matter how ignorant :)
spc_hicks09: Answered my questions about random stuff
Artic Team: 1% battery mod
STiK: For getting a new link to Hashcodes Base
Thanks to Hashcode for his 6.16.211 base
Pictures:
  229.39KB   335 downloads
  240.11KB   335 downloads
  77.14KB   285 downloads
Prerequisites:
Be rooted on 6.16.211
Have Safestrap v2.00 installed
Install Instructions:
DO NOT INSTALL THE 1% MOD ON FIRST BOOT
1. Put the rom and any other files you want to flash on your phones sdcard
2. Reboot phone into the Safestrap recovery
3. Wipe Data/Factory reset
4. Install the rom you want
5. reboot phone
If you want 1% mod continue
6.setup the phone or just exit setup
7. reboot into safestrap
8. install Stock Battery 1% zip from external sdcard
9. reboot phone and Enjoy!
Downloads:
Safestrap v2.0:
Deodexed 6.16.211:
odex files:
1% Stock Battery-Artic:
1% Battery mods by superrelaxx:
Change log:
7-5-12: removed deodexed Zumocast- sorry nitro didn't
realise this was not to be released!
7-4-12: Added link to new 1% mods done by superrelaxx
7-3-12: Added a mirror for Deodexed 6.16.211
7-1-12: Added deodexed Zumocast, fixed odex-files.zip, uploaded to dev-spot,
Changed titles to Deodexed 6.16.211, added 1% mod link and Instructions
  • mike_augie, bpm1055, XCellFoneSalesRep and 2 others like this
#2 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
  • Twitter:https://twitter.com/XCellFoneRep
  • Google+:http://goo.gl/XgDaW
  • LocationThe Joisey Shore, Nu Joisey
Posted 28 June 2012 - 09:29 AM
Do you know if your version of this "lighter" .211 build requires activation to get to the home screen? I have been unable to find a work-around for the activation on any of the ICS leaks other then booting with another carrier's SIM, which isnt always available to me. The original 4-corner press from GB builds doesnt work, FYI...
Thanks in advance!
#3 SlammedDime
SlammedDime
  • 43 posts
Posted 28 June 2012 - 09:42 AM
The 4 corner tap should work, someone in chat was able to get it done successfully the other day.
#4 Kebob
Kebob
    Dev
  • 246 posts
Posted 28 June 2012 - 09:47 AM
Well if you go into the build.prop there is a option for having that startup. I think it would be easier to just try the 4 corner trick though.
#5 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
Posted 28 June 2012 - 11:22 AM
I have tried the 4-point multiple times in the MotoICS ROMs and have been unsuccessful.
was the person that told me about using a SIM card from another carrier because i dont think the 4-point worked for him either...
Thanks anyway!
#6 Kebob
Kebob
    Dev
  • 246 posts
Posted 28 June 2012 - 11:52 AM
Hmm let em check the build.prop I may be able to find something to not require activation.
  • XCellFoneSalesRep likes this
#7 xlehmannx
xlehmannx
  • Validating
  • 8 posts
Posted 29 June 2012 - 03:16 PM
Anybody have a link to the wallpaper in the op,? i can't find one that fits the razr.
#8 Kebob
Kebob
    Dev
  • 246 posts
Posted 01 July 2012 - 12:01 AM
Yes. This is the exact same one I use.
#9 Guest_BDH_*
Guest_BDH_*
Posted 01 July 2012 - 12:12 AM
Nice job deodexing and zipaligning this! This will help a lot of starters that want to get their own development up and running. If it's not already done, I'm going to sticky this. Bravo!
#10 Kebob
Kebob
    Dev
  • 246 posts
Posted 01 July 2012 - 12:46 AM
Thanks! I really appreciate it. This is the reason I decided to make it because I thought it may be helpful for all the people creating roms as well as the people who just need a deodexed base for 1% mods.
#11 Guest_BDH_*
Guest_BDH_*
Posted 01 July 2012 - 01:03 AM
Well it's pinned at the top, also make sure you have your link to this thread handy in case you run in to anyone that might need it. Again thanks for making and posting this!
#12 olegausany
olegausany
  • 24 posts
Posted 01 July 2012 - 01:50 AM
Thanks a lot for your work. But i have just one question: Can i use the following steps to get it to my phone 1. Use utility 1.7 to get back to official GB .181 2. Use same utility to root GB 3. Copy the file you created to root folder of external SD card 4. Reboot into motorola recovery and do wipedata/factory reset first and wipe cache partition next . 5. Return back to motorola recovery and use update from sd card optipn to flash.
Than use the same procedure to flash 1% charge mode plus battery icon of my choice from R3D thread
Maybe you should add 1% charge mod inside your rom
#13 claps1775
claps1775
  • 596 posts
Posted 01 July 2012 - 07:18 AM
This is what type of rom I have been looking for. Stock with a little finness. Thank you kindly.
  • mikelikesbikes likes this
#14 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 01 July 2012 - 08:42 AM
Nice work man!
#15 Kebob
Kebob
    Dev
  • 246 posts
Posted 01 July 2012 - 12:10 PM
Thanks for all the great comments! olegausany, what is your android version? If you are on .181 already or are on .75 or .79 then there are a few choices for you here. You can fastboot back to .181 and install 6.16.211 OTA. After that you can get safestrap v2.00 and flash this with that according to the instructions I will have posted above. If you for some odd reason want to stay on gingerbread(or at least have the option) I would suggest for you to go to the this thread:
#16 crpp2401
crpp2401
  • 40 posts
Posted 01 July 2012 - 01:31 PM
Hey guys in this link you can find YouTube apk from JB is Amazing and working just use root explorer and put this one on system/app before has to eraser the other one is Amazing the new look and futures only thing that I don't like is that can play HD someone can make this HD
#17 crpp2401
crpp2401
  • 40 posts
Posted 01 July 2012 - 01:52 PM
Hey guys hear is the apk HD I fundit lol enjoy JB YouTube Amazing and HD
#18 wabmorgan
wabmorgan
  • 236 posts
Posted 02 July 2012 - 08:19 AM
Works AWESOME. No problems thus far.
#19 olegausany
olegausany
  • 24 posts
Posted 02 July 2012 - 06:34 PM
Thank you very much but those instructions were not here when i asked my question and I already was on .211 OTA leak at that time. So since I got no replay fast enough i decided to try it. So my results are as follow. I tried utility 1.7 several times getting 'preflash verification failed' error while writing cwt, devicetree, boot, system and recovery. I also tried version 1.6 of utility instead and got the same results until ny battery got almost dead. So i had to use battery charge only mode to charge battery. After battery was 90% charged i tried utility 1.7 one more time with the same result but when i tried to boot into recovery i was successful and i did wipe data and wipe cache. Than i tried to flash from external SD your rom dated 7-1 first but it stopped with 'Signature verification' error after package got unpacked but successfully flashed OTA leak i started from which is require per your instructions.
Also i have few questions about instructions. #4 means flash your or any other rom ? #7 means boot into recovery phone had before installing safestrap not safestrap recovery? #8 means install from external SD pointing to 1% stock battery zip?
#20 Kebob
Kebob
    Dev
  • 246 posts
Posted 02 July 2012 - 06:44 PM
yes, no, yes. recovery is safestrap now. i changed that in the instructions now. other then that your other 2 questions are correct.
Also tagged with one or more of these keywords: 6.16.211, deodexed, razr, 4.0.4
