Phone being sluggish?
black widow dalvick cache razr droid
3 replies to this topic
#1 buckeyestilidie
buckeyestilidie
  • 288 posts
  • Twitter:buckeyestilidie@yahoo.com
Posted 14 October 2013 - 08:34 PM
My phone is currently running BW HD V2. It is running real laggy and sluggish at times, but when I wipe the dalvick cache it runs fine for a couple days then goes right back to being slow and annoying. I think it may be an app that just isn't playing nice with the rom, but how do I check what the problem is or are there a system of protocols to run to diagnose a problem? Much thanks to anyone who takes the time to help.
#2 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 15 October 2013 - 10:55 AM
Download this Cleaner...Its Awesome
The App is: CacheCleaner NG...Set it to Clean Every 12 hours....this will help tremendously with Performances and Lag Issues...Try this first
#3 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 October 2013 - 11:49 AM
Downloaded and will test it and get back in about a week. Thanks again for the help.
#4 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 October 2013 - 12:05 PM
You're Welcome...
You can also Ramp up CPU Setting...
* Set your Min settings...800 & Max 1200 for starters...
It will be faster in Performance but Battery Life might be shorter than usual...
Also tagged with one or more of these keywords: black widow, dalvick cache, razr, droid
