{ROM}{UNOFFICIAL)Dirty Unicorns 4.3-Droid Razr HD (GZRoms)
99 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 08 October 2013 - 01:29 PM
This ROM is based on the Android Open Kang Project (AOKP). The idea to start a ROM based off AOKP with added features for us was started out of curiosity and boredom. We started compiling ROMs for personal use and later started sharing them. After sharing it with a few people, we decided to take it a step further and fine tune the way we do things. Since then, is been nothing but fun and a true learning experience for all of us involved. We've received high praise from not only users but fellow developers of other ROMs that enjoy seeing things done the right way. Our 4.2.2 version made it onto various devices to include the HTC One, Galaxy Nexus, HTC EVO 3D, HTC EVO LTE, Nexus 4 and some other devices. We hope to do the same with our 4.3 version.
"Give credit and thanks where is due!" That's something that has fuel the way we do things! With that said, we would like to go ahead and credit those individuals and groups that have made this ROM possible with their original code and contributions to the Android community.....
AOKP / Team Kang | CyanogenMod | Paranoidandroid | Preludedrew | JMZtaylor | iBlowpot |ChaOS Team Liquidsmooth |
CarbonROM | Rohan32 | LorDClockaN | Dastin1015 | Bajee11 | SlimROMs | Daxxmax | Beerbong | Sammyycakes | Team BAMF |
Believe it or not, we are human and we do forget things. If we have left someone out of the credit/thanks list, just PM us and we'll gladly add on to the list.
- Facebook Sync Hack
- Expanded desktop
- Hot Reboot Option
- Ribbons (AOKP)
- Customizable Quick Settings
- Custom "BAMF" Theme engine
- Customizable power menu (Torch, Profiles, etc)
- Customizable lockscreen buttons and sliders
- Missed call breathing notifications
- App Ops access in Settings
- CM Powerwidget
- CM Profiles
- CM apps (Apollo, DSPManager, CMFileManager, etc)
- SlimROMs TRDS (built in theme in settings)
- SlimROMs Statusbar Clock options
- Transparent Statusbar and NavBar Options
- Halo from Paranoidandroid
- Halo bubble color changer
- Halo size changer
- Multi-user support
- Customizable Softkeys
- 24+ Battery options
- Network speed indicator in statusbar
- Koush Superuser
- Nav Bar customizations
- Host file switcher (ad-free switch)
- Build Propper
- Active Display (Moto X notifications)
- Wakelock blocker
- Suspend Actions (power saving mod)
- ListView Animations
- Custom System Animations
- Swipe to Switch in RC (toggle)
- Lockscreen Tint Color Mod
- Weather Panel
- Change lockscreen wallpaper
- OTA updates via DU Updater
- Custom BusyDialog
- Advanced Low Battery Indicator options
- Music/Halo toggle/tiles
- ScreenShot QuickTrash
- MIUI-like carrier in statusbar
- Much More, just look in Settings and ENJOY!!!
- Much more customization (just flash and get Dirty)
Download:
  • vtwinbmx likes this
#2 bjoostema1933
bjoostema1933
  • 122 posts
  • LocationNorth Carolina
  • Current Device(s):Razr HD Maxx /Nexus 7
Posted 08 October 2013 - 02:18 PM
dammit...every time I promise myself I'm going to stay on a rom for a while, you devs go and put out something awesome to check out :ph34r:
  • somber73 likes this
#3 timd
timd
  • LocationCharlotte NC
Posted 08 October 2013 - 02:51 PM
Are gapps included?
#4 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 08 October 2013 - 03:19 PM
Are gapps included?
Nope i use slim aio but its your choice
#5 asilentcivilian
asilentcivilian
  • 28 posts
Posted 08 October 2013 - 03:28 PM
getting the "android keyboard stopped working" after first boot. am i the only one?
#6 jtommyj
jtommyj
  • 181 posts
Posted 08 October 2013 - 03:52 PM
No I'm getting the same AOSP keyboard FC's too.
#7 asilentcivilian
asilentcivilian
  • 28 posts
Posted 08 October 2013 - 03:58 PM
i did try fixing permissions after first boot and then tried mounting system and flashing, etc. same results. thought i'd provide feedback. i'm pretty excited about this though!
#8 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 08 October 2013 - 03:59 PM
what gapps are you guys using?
#9 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 08 October 2013 - 04:01 PM
just wipe flash and boot all you need i'm using build 1 slim gapps  not the 1.x
#10 jtommyj
jtommyj
  • 181 posts
It happens even if I don't install Gapps also but using 4.3 Gapps
#11 asilentcivilian
asilentcivilian
  • 28 posts
Posted 08 October 2013 - 04:03 PM
i'm using the official 4.3 from 8/13. i did try installing the rom first without flashing gapps afterwards but was still getting the keyboard FC's.
#12 jeff0r3
jeff0r3
  • 55 posts
  • Current Device(s):xt926
Posted 08 October 2013 - 04:30 PM
Really wanna try this rom but not if Keyboard isn't working..
#13 chdwrk
chdwrk
  • 36 posts
  • Twitter:workca
  • Locationnear Buffalo, NY
  • Current Device(s):Razr, Razr HD
Posted 08 October 2013 - 05:13 PM
Keyboard FC'd once then worked fine until I installed my normal keyboard
Sent from my Razr HD using Tapatalk 2
#14 cmh714
Posted 08 October 2013 - 06:26 PM
I used paranoid gapps and it was working fine for a while. Then during play store updates of my apps it started giving me play store rpc errors that I havent resolved yet. But will keep trying :)
Keep up the good work somber!
#15 trebills
trebills
  • 73 posts
Posted 09 October 2013 - 01:58 AM
I used slim gapps works fine as long as you don't swipe. I just downloaded the Google keyboard from play store because i wanted the swype feature and everything works great so far. Tons of features thanks.
Sent from my Nexus 7 using Tapatalk 4
#16 asilentcivilian
asilentcivilian
  • 28 posts
Posted 09 October 2013 - 03:12 AM
I tried doing this but still kept getting FC's. Guess I'll wait for it to get fixed
Sent from my XT926 using Tapatalk 4
#17 bigdanmeys13
bigdanmeys13
  • 31 posts
  • Current Device(s):Motorola Droid Razr Maxx HD
Posted 09 October 2013 - 06:55 AM
Slim AIO GApps 4.3 build beta 5 worked great for me; swipe and all. Give it a shot. Great ROM! Keep it up!
#18 asilentcivilian
asilentcivilian
  • 28 posts
Posted 09 October 2013 - 09:02 AM
sweet this worked for me. thanks!
#19 bjoostema1933
bjoostema1933
  • 122 posts
Posted 09 October 2013 - 09:43 AM
Before I give this a go, can anyone confirm that mms is functioning ok?
#20 trebills
trebills
  • 73 posts
Posted 09 October 2013 - 11:00 AM
I can confirm MMS is not working for me.
Sent from my Razr HD using Tapatalk 4
