[{ROM}] GZR Presents Validus13 (MB886) 4.3.1
48 replies to this topic
#1 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 07 October 2013 - 12:53 AM
  • Latest CM Bells & Whistles
  • Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
  • Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
  • Turn screen on when plug/unplug the USB cable as an option in settings;
  • Reboot Menu Enable by default;
  • Brightness control sliding through status bar;
  • Custom
     Label;
  • Status Bar Transparency and Custom Colors;
  • Status bar network speed indicator with option to custom colors;
  • Option to auto hide network speed indicator when there is no traffic;
  • Status bar quick peek;
  • Notification drawer + Notification row Transparency, custom Colors and custom image;
  • Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
  • Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
  • Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
  • Appbar from ChameleonOS;
  • Lockscreen based on gestures from ChameleonOS;
  • HALO 2.0 by ParanoidAndroid;
  • BlackUI (Darkness), TRDS from Slim Roms;
  • LCD density changer
  • Option to enable notifications light even with screen on;
  • Option to enable lock screen rotation;
  • Open tiles in floating window;
  • QS tile fast charge;
  • Powerwidget toggle fast charge;
  • Speed up statusbar / notification drawer;
  • Alternate default app picker;
  • Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
  • Floating window from notification drawer (Long press);
  • Option to show Wifi name in notification drawer;
  • Option to flip tiles in simple press;
  • Listview Animation;
  • Listview Interpolator;
  • SlimRoms Nav bar
  • SlimRoms PIE
  • Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
  • Custom Boot Animation (JaeKar99) You are the man
  • dustinb for allowing us to use his cobalt themes
  • More to come........
      1. Follow normal flashing rules
      2. Use only 4.3 Gapps
      3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
The Titanic
Vtwinbmx
JaeKar99
dustinb
CM Moto team
SlimRoms
Satman80.... Don't even question why
DOWNLOAD LINK:
GZ GAPPS:
Link for custom wallpapers:
  • satman80 and somber73 like this
#2 slugfanatic
slugfanatic
  • 18 posts
Posted 09 October 2013 - 06:51 AM
Thanks a lot for the rom, is stable and fantastic, you are a very good Programmer, thanks.
#3 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 09 October 2013 - 08:35 AM
I'm glad you like it let is know if you have any issues or suggestions. I'm just the guy who put the rom out somber73 is the man who whipped it all up. I'm part of a team and we are gzroms
  • slugfanatic likes this
#4 slugfanatic
slugfanatic
  • 18 posts
Posted 10 October 2013 - 02:06 PM
Only I have an issue.
When I call, the screen goes black and sometimes will not start until you lock and unlock the phone.
But this problem had already noticed in the official rom from cyanogen.
#5 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 10 October 2013 - 04:00 PM
hopefully in build 3 the issue will be solved.... it will be out soon
#6 slugfanatic
slugfanatic
  • 18 posts
Posted 11 October 2013 - 04:47 AM
I'll wait for this.
Will be on this same page????
#7 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 11 October 2013 - 08:58 AM
I'll wait for this.
Yes all updates will be posted here. We should have something out hopefully by the end of the weekend
#8 slugfanatic
slugfanatic
  • 18 posts
Posted 15 October 2013 - 05:17 AM
Another question, which recommended method to change the fonts.
#9 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 15 October 2013 - 07:55 AM
[FONTS] Full Font Packs
I've been using this on 4.3 ROMs my other methods have failed
#10 slugfanatic
slugfanatic
  • 18 posts
Posted 15 October 2013 - 10:36 AM
To late i brick my rom :( whit iFont, but thanks i´ll try this later.
#11 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 15 October 2013 - 10:58 AM
This won't brick it I've used it... All other methods have
#12 slugfanatic
slugfanatic
  • 18 posts
Posted 15 October 2013 - 12:47 PM
Thanks, it result helpful.
#13 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 15 October 2013 - 05:39 PM
I have a new v13 build going right now should be out tonight
#14 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 15 October 2013 - 06:28 PM
Will have to be tomorrow had some theme errors sorry to keep you waiting
#15 slugfanatic
slugfanatic
  • 18 posts
Posted 16 October 2013 - 06:20 AM
Hell yeah, i'll wait for it.
#16 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 16 October 2013 - 11:24 AM
10/15/13
The original v13 is back  :)
Integrated xposed and greenify
Thanks to dustinb v13 now includes 3 of his awesome cobalt themes
I tested mms after build worked fine for me
Updated with the latest cm commits
Smooth and dependable.. Enjoy
GET IT!!!!!!!!
#17 slugfanatic
slugfanatic
  • 18 posts
Posted 17 October 2013 - 04:59 AM
Donwloading.....!!!!
After work i´ll try it.
  • Rinkle McBally likes this
#18 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 18 October 2013 - 03:22 PM
rom updated with latest cm commits and added lock ring battery gauge
#19 slugfanatic
slugfanatic
  • 18 posts
Posted 19 October 2013 - 11:45 AM
i really liked the rom, more stable, faster, and better use of the battery but there is a problem, I suffer from forced closed the lock screen application. and I can only set it up on security.
#20 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 21 October 2013 - 05:42 PM
I'll have a update out tomorrow
