[{ROM}] GZR Presents Validus13 (d2vzw) 4.3.1
15 replies to this topic
#1 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 06 October 2013 - 12:00 PM
  • Latest CM Bells & Whistles
  • Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
  • Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
  • Turn screen on when plug/unplug the USB cable as an option in settings;
  • Reboot Menu Enable by default;
  • Brightness control sliding through status bar;
  • Custom
     Label;
  • Status Bar Transparency and Custom Colors;
  • Status bar network speed indicator with option to custom colors;
  • Option to auto hide network speed indicator when there is no traffic;
  • Status bar quick peek;
  • Notification drawer + Notification row Transparency, custom Colors and custom image;
  • Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
  • Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
  • Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
  • Appbar from ChameleonOS;
  • Lockscreen based on gestures from ChameleonOS;
  • HALO 2.0 by ParanoidAndroid;
  • BlackUI (Darkness), TRDS from Slim Roms;
  • LCD density changer
  • Option to enable notifications light even with screen on;
  • Option to enable lock screen rotation;
  • Open tiles in floating window;
  • QS tile fast charge;
  • Powerwidget toggle fast charge;
  • Speed up statusbar / notification drawer;
  • Alternate default app picker;
  • Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
  • Floating window from notification drawer (Long press);
  • Option to show Wifi name in notification drawer;
  • Option to flip tiles in simple press;
  • Listview Animation;
  • Listview Interpolator;
  • SlimRoms Nav bar
  • SlimRoms PIE
  • Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
  • Custom Boot Animation (JaeKar99) You are the man
  • dustinb for allowing us to use his cobalt themes
  • More to come........
      1. Follow normal flashing rules
      2. Use only 4.3 Gapps
      3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
The Titanic
Vtwinbmx
JaeKar99
dustinb
CM Moto team
SlimRoms
Satman80.... Don't even question why
DOWNLOAD LINK:
GZ GAPPS:
Link for custom wallpapers:
  • mnp116 likes this
#2 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 10 October 2013 - 03:59 PM
build 3 coming soon
  • jamminjon82 likes this
#3 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 13 October 2013 - 04:38 PM
OP updated
10/13
Cleaned up the interface
Took out Active Display till I can get some bugs worked out
Compiled with SaberMod Linaro 4.7
No Custom Kernel try it you'll see why  :)
Builds will be a lil Slower with updates taking my time with this one
New Bootanimation (designed by RinkleMcbally and JaeKar99)
Builds for other devices are coming soon thanks and enjoy
Recommend clean flash
Not the same rom your used too but its sombers baby
Be gentle
#4 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 15 October 2013 - 04:05 PM
UPDATED
10/15/13
The original v13 is back  :)
Integrated xposed and greenify
Thanks to dustinb v13 now includes 3 of his awesome cobalt themes
I tested mms after build worked fine for me
Updated with the latest cm commits
Smooth and dependable.. Enjoy
Link is live get it
#5 james
james
  • 620 posts
  • Locationsouthern cali
  • Current Device(s):LG G2 Verizon
Posted 15 October 2013 - 05:09 PM
so gapps are not included in the rom
#6 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 15 October 2013 - 05:38 PM
No they are not I use slim gapps personally
#7 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 15 October 2013 - 06:29 PM
New build will be out some errors in themes sorry for the inconvenience
#8 james
james
  • 620 posts
Posted 15 October 2013 - 06:32 PM
ok thank you
#9 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 16 October 2013 - 03:42 AM
Link is good to go do fresh install
#10 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 18 October 2013 - 03:21 PM
rom updated with latest cm commits and added lock ring battery gauge
#11 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 21 October 2013 - 05:43 PM
Update coming tomorrow
#12 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 22 October 2013 - 11:34 AM
Build updated 10/20
Removed Greenify in settings (caused a few conflicts when trying to upgrade still imbedded in
Added Omni's Multi-Window granted still WIP but i liked it  :)
And yes MMS is working
#13 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 27 October 2013 - 03:39 PM
rom updated
#14 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 27 October 2013 - 05:41 PM
10/27
Building with -03 Flags for a lil extra linaro smoothness
Traffic Meter in Statusbar option
Misc. Fixes
Dunno about mms i'm trying and i dont wifi tether so your guess is as good as mine
All the latest cm commits
#15 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 01 November 2013 - 03:25 PM
11-1-2013
It's the first of the month get your fix rom has been updated:
Latest cm commits
Updated trebuchet launcher
#16 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
Posted 16 November 2013 - 06:27 AM
With the transition to 4.4 I myself am taking a break from building which means I will not be releasing any more updates for this rom. Hang tight and great things should be coming soon.
