Stock Kernel
Stock Kernel Jbx
2 replies to this topic
#1 toymachine234
toymachine234
  • 18 posts
Posted 30 September 2013 - 10:29 PM
I have been trying to return to stock kernal .16 from Jbx how do I do that? I want to go on Rage. PLEASE HELP! I have been raging all night pun intended
  • jl90 likes this
#2 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 01 October 2013 - 03:03 AM
Read the first link.
Try the second. :)
#3 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
  • Current Device(s):droid razr
Posted 01 October 2013 - 05:45 PM
Or simply flash the rom u want stock kernel in. Re flashing rom restores which ever roms stock kernel you are needing. Or you can also extract jbx_kernel.zip and replace jbx_kernel/modules with stock, zip, sign .zip(zip signer free from playstore) and flash. I know the restore.zip included in link above never worked for me with ss but i guess does with bmm..
XT912 RaZR SpYdEr CDMA
hit ThAnKs if I was helpful!!!
  • jl90 likes this
Also tagged with one or more of these keywords: Stock, Kernel, Jbx
