[Q] [HELP] Motorola NOOB! Mount point information for XT925?
2 replies to this topic
#1 rjhellel
rjhellel
  • LocationLondon, UK
  • Current Device(s):Motorola Razr HD XT925
Posted 30 September 2013 - 12:26 PM
Hi there, I seem to have messed up my mounting partitions while trying to deodex Stock JB Central Europe. I basically used xultimate to pull the files and deodex then tried using adb shell to mount the system partition and copy them over. After I rebooted the phone, it would get stuck on unlocked bootloader warning or on the motorola logo. I hard reset into recovery and restored a nandroid backup and once booted into android found so many folders under the Storage folder such as "asec", "obb", rfs0" and so on. Now, when I try to wipe dalvik-cache in recovery, i get the following error: "E: unknown volume for path [/sd-ext]". Also, when i try flashing custom rom's and reboot, it gets stuck on the unlocked bootloader warning and wont load - while in recovery after flashing, i also get another error something like this: "E: cant load /cache/recovery.log" or similar. I also sometimes have issues mounting system, cache partitions, data and internal storage, all depending on which custom recovery i am using. I read on another site that downgrading to ics might solve mounting problems so I forced a downgrade to ics but that didnt work either and am still on ics.
Is there a way to restore the partitions correctly or are they stuck this way? Would mounting and remounting solve this problem? Any help would be much appreciated and would very much appreciate it if someone could upload their mount point info so i could use to try and fix it.
Many thanks in advance.
#2 cmh714
Posted 30 September 2013 - 05:00 PM
I think my advice is step away from the device :)
Heres partition info: http://batakang.com/XT925.php
You have a lot of junk going on so I have no idea where the hell to start. Basically I would say you need to start over from the beginning. But you should know that already if your deodexing.
sd-ext isnt any big deal, it doesnt see the external sdcard
#3 rjhellel
rjhellel
Posted 02 October 2013 - 01:21 AM
Thanks for your reply and the link. I know I messed up badly but can't figure out how and where to start over again.
I did manage to flash Slim Bean 4.3 Official as well as GAPPS for 4.3 so will keep it at that for now until I find a proper solution.
Some things see the external card and others don't like for example Go Backup & Restore Pro does not see the external card and so can only backup to the internal memory.
Thanks again for your help.
