[AP Fastboot] Fastboot Reason: Flash Failure
fastboot flash failure ap fastboot
Best Answer SamuriHL , 01 October 2013 - 06:19 AM
Send it on a trip through the House of Moto.  Use the KEEP DATA script.
Go to the full post
41 replies to this topic
#21 Songbyrd
Songbyrd
  • 8 posts
  • Current Device(s):Droid Razor HD
Posted 09 February 2014 - 10:39 AM
What does that mean?
#22 SamuriHL
  • 44,375 posts
Posted 09 February 2014 - 10:41 AM
It means you didn't read the warning and bricked your phone.  Now you need to go read and learn how to use an FXZ to restore it.
#23 Songbyrd
Songbyrd
  • 8 posts
Posted 09 February 2014 - 10:49 AM
my phone is working fine. I talked to my boyfriend this morning and my daughter is playing a game on it now...I am new at this, but from my understanding, a bricked phone wouldn't be able to do any of that. what else could it be?
#24 SamuriHL
  • 44,375 posts
Posted 09 February 2014 - 10:51 AM
I keep getting the pre flash validation failed; remote failure. On a different post regarding the Root Script/Utility (July 24, 2013), there are rooting instructions w/ links for the zip files needed. The instructions call for an item to be extracted from the zip and then "...flashed using the AP flash mode: fastboot flash boot boot.img." I have read several threads and been on google for 2 days and I have no idea how to "flash" anything. HELP!!!! Por favor!
Where are you getting the message in bold then?
#25 Songbyrd
Songbyrd
  • 8 posts
Posted 09 February 2014 - 01:17 PM
That's what I'm trying to figure out. I think when I downloaded the zip file I was supposed to extract the first file (boot.image) from it and, per the instructions, "...flash the file using AP flash mode: fastboot flash boot boot.image ". Then reboot and run motochopper. Only I didn't bc I have no idea what that means.
#26 SamuriHL
  • 44,375 posts
Posted 09 February 2014 - 02:36 PM
Well if you can't even tell me where you're receiving the message you said you were getting, I don't think I'm able to help on this one.
#27 Songbyrd
Songbyrd
  • 8 posts
Posted 09 February 2014 - 06:26 PM
The failure message happens during rooting. It starts fine, then point where it says something about a boot file not recognized or found then I get error message "pre flash validation failure". It waits for device, reboots, deamons then it's done. I would try it again & get a pic of the screen, but I don't want to try again and mess up something. But the failure message is what made me think I was supposed to flash that file. It's the only step I skipped bc I didn't know how.
#28 SamuriHL
  • 44,375 posts
Posted 09 February 2014 - 07:19 PM
What system version are you on?  4.1.2 is not the answer I want.  The specific build.  9.18..... what?  Check system settings, about phone.
#29 Songbyrd
Songbyrd
  • 8 posts
Posted 10 February 2014 - 10:25 AM
9.18.94.XT926.Verizon.en.US
#30 SamuriHL
  • 44,375 posts
Posted 10 February 2014 - 10:39 AM
SIGH.  So what I said about you ignoring the warning completely applies.  The method you are attempting to use, had you been "able to follow the directions completely", would have bricked your phone because it DOES NOT APPLY to your version of Android.  Which is why there is a very big warning on that page.  IOW, stop what you're doing and use a root method that works for that specific version of Android before you do end up with a bricked phone.
#31 SamuriHL
  • 44,375 posts
Posted 10 February 2014 - 10:47 AM
I'm guessing you'll probably ask for how to root that version next.  In the interest of being done with this thread:
#32 chabs
chabs
  • LocationUnited States
Posted 01 July 2014 - 07:19 PM
Im having a similar issue when i try to boot my Maxx HD. it goes straight to the fastboot screen and the only way to boot normally is to use the volume buttons and use the "normal boot" option and boot that way. this would be an acceptable workaround, except for the fact that once android boots, about twenty seconds after it shows the lockscreen, it powers itself off and restarts back into fastboot.... is there anything i can do to repair my phone?...hopefully without having to loose any data?
-Ive also tried booting into safe mode with no success and all the other options available through the volumes menu..except "factory"... any help would be greatly appreciated
#33 SamuriHL
  • 44,375 posts
Posted 01 July 2014 - 07:25 PM
Rsd Flasher (search for it in my house of moto forum) with the keep data option.
  • chabs likes this
#34 chabs
chabs
Posted 01 July 2014 - 08:21 PM
Thanks, Samuri. Worked like a charm
  • SamuriHL likes this
#35 Krishna
Krishna
  • LocationIndia
  • Current Device(s):Motorola Razr HD (XT925), HTC One M7
Posted 10 October 2014 - 02:08 AM
fantastic...
I thought my phone is bricked and is a gone case...
had exactly same problem as the OP with status 3 and got it fixed.
kudos to Samurai
#36 djkadosch
djkadosch
Posted 24 March 2015 - 08:58 AM
Guys
Im stucked on
Second try
#37 livinginkaos
Posted 24 March 2015 - 10:10 AM
You are using the wrong fastboot .  It needs to parse the system due to it's size.
  • djkadosch likes this
#38 djkadosch
djkadosch
Posted 24 March 2015 - 11:04 AM
livingkaos, where can i take the correct for RAZR I XT890?
I think I have the correct Rom.
Friends, I Found the correct Files! Problem Solved!!! Thanks!
#39 livinginkaos
Posted 24 March 2015 - 11:37 AM
#40 uthkarsharaj
uthkarsharaj
Posted 15 January 2016 - 03:10 PM
I am unable to dwnld the image files..the links don't work.. is there any other way? My razr hd is rootd and unlocked.. Tia
Also tagged with one or more of these keywords: fastboot, flash, failure, ap fastboot
