Best Answer SamuriHL , 01 October 2013 - 06:19 AM
Send it on a trip through the House of Moto. Use the KEEP DATA script.
Go to the full postBest Answer SamuriHL , 01 October 2013 - 06:19 AM
Go to the full postPosted 30 September 2013 - 12:06 PM
Hello beautiful people! :
I'm having a bit of a problem... well, more of an inconvenience really.
I'm using the XT926, rooted with CMR. I made the mistake a couple months ago to flash back to stock firmware and the root again. Then i tried to do the over-the-air update. Then my phone... exploded. To make a long story short, I managed to throw LiquidSmooth and CMR back on there after some troubleshooting, but first I ran the unroot/factory software flash utility from Motorola and... it failed. Now every time I hit the power button while the device is powered off, I go directly into AP Fastboot with the following message:
AP Fastboot Flash Mode (S)
10.9B(*) (sha-1e9f557, 2013-05-30 19:08:40) // I'm assuming this is the time and place that the error occurred, because it never changes.
eMMC Info: Size 32GB
Device is UNLOCKED. Status Code: 3
Battery OK
Connect USB
Data Cable
Fastboot Reason: Flash Failure
or if I'm connected to the computer via USB:
Battery OK
Transfer Mode:
USB Connected
usb connected
Now the phone still boots up and runs just fine, but I have to do the three button press bull crap to get to the menu and then select "Normal Startup"
This happens regardless of connection to a PC or power source and what's worse is that I cant seem to flash anything through AP Fastboot anymore.
Any ideas on how to fix this? It's soooooooooo annoying.
Thanks! Free BJ's for whomever solves my problem! : (Not actually. I'll just really appreciate it.)
- Insert witty and/or advertisement filled signature here. -
Posted 30 September 2013 - 12:10 PM
You just need another successful flash. You could flash a simple boot logo or something and you will be good.
Edit: Use these
. Follow the 2nd method in the OP that uses scripts to fastboot flash the logo
Posted 30 September 2013 - 12:23 PM
Yes, that's what I thought too, but I can't flash a boot logo.
I tried using MonkeyMouth 2 to flash a logo in, but it came back with:
sending 'logo.bin' (854 KB)... OKAY [ 0.077s]
writing 'logo.bin'... INFOInvalid partition name logo.bin
FAILED (remote failure)
rebooting...
I'm probably doing something really dumb and simply flawed, but I'm a little out of my comfort zone on this one haha. You were really fast to respond BTW. I mean, damn!
Posted 30 September 2013 - 12:32 PM
extract the stock firmware file.
edit xml and remove the getvar line.
extract the contents of the file i.ve uploaded into the folder in which stock firmware has been extracted.
put device in fastboot mode.
execute fastboot_flash_erase_userdata.bat.
sit back and relax..
Posted 30 September 2013 - 12:40 PM
Edit: Use these
Either I'm doing something wrong, or I can't flash a boot logo.
Posted 30 September 2013 - 12:42 PM
extract the contents of the file i.ve uploaded into the folder in which stock firmware has been extracted.put device in fastboot mode.
I'd rather not, but as a last resort, I'll consider it.
Posted 30 September 2013 - 04:52 PM
edit the script from MonkeyMouth and change the lines that say:
moto-fastboot flash logo.bin logos/whatever_image_here
to
moto-fastboot flash logo logos/whatever_image_here
Posted 30 September 2013 - 04:53 PM
Also, why the heck are you posting in the 925 forum?!?!?!
I am moving to the 926 forum....
Posted 30 September 2013 - 05:30 PM
to
hope that helps I know it will....
Well, it worked... sort of. No more fastboot error, but now it only boots into recovery mode. However, I can get it to boot the proper way by holding down all three of the buttons and selecting "Normal Powerup" So, net zero haha.
My mistake! Thanks!
Posted 01 October 2013 - 06:19 AM Best Answer
Posted 01 October 2013 - 07:45 PM
I have no idea what that means. Can you dumb it down a smidgen?
Posted 02 October 2013 - 03:35 AM
Posted 07 October 2013 - 08:15 AM
Edited
Posted 11 November 2013 - 12:02 PM
Worked like a charm! :
Sorry I took so long to try and reply, got really busy with college stuff. Amazing tool by the way. Thanks so much!
Posted 11 November 2013 - 12:07 PM
You're very welcome. Glad it helped you out!
Posted 17 December 2013 - 09:53 AM
mine is the same but the code is 0. i am really bad at understanding this and my phone is locked. can anyone help me i have the razr m
Posted 17 December 2013 - 12:35 PM
What were you flashing prior to have this happen?
Posted 05 January 2014 - 10:46 AM
You sir are a genius lol I have been stuck with this same problem for like 3 hours, I messed up the flash while trying to root my Droid Razr Maxx HD on jelly bean 4.1.2 (9.18.9 build), for some reason razr blade doesnt have the required access I need to root it. I have failed so much with this..........Does anyone else have the same problem??
Posted 09 February 2014 - 01:04 AM
I keep getting the pre flash validation failed; remote failure. On a different post regarding the Root Script/Utility (July 24, 2013), there are rooting instructions w/ links for the zip files needed. The instructions call for an item to be extracted from the zip and then "...flashed using the AP flash mode: fastboot flash boot boot.img." I have read several threads and been on google for 2 days and I have no idea how to "flash" anything. HELP!!!! Por favor!
Posted 09 February 2014 - 10:35 AM
I'm new. What does that mean?
