[Rom] Simplex-V1.3 | Ics4.04 |10/1/2012 | The Revival!
ics roms deodexed init.d modded
1861 replies to this topic
#1 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 24 June 2012 - 04:58 PM
POPULAR
Safestrap is the is the only supported install method!
-Intro
I present Simplex Revival!
It is still deodexed, debloated, and blur stripped! If you like blur... This ROM is not for you!! I cannot stress that enough. I'v not personally noticed a single FC or issue as of yet. I tend to spend a good bit of time working on these because I cant stand bugs! So I try to take care of as many as I can. Where possible Blur items have been replaced with AOSP compiled from source by myself. Its been a while since an update due to my computer issues... But Simplex is back! So give it a run and as always.. feedback welcome!
DISCLAIMER:
DroidRZR, myself, or any other party CANNOT be held responsible for what you decide to do. Modifying system files can lead to a damaged or comletely bricked device!!! Your phone! Your choice! Your responsibility!!!!
Credits:
Google - For the Android we play with.
Motorola - For fantastic hardware!
Dhacker29 - always listening to my bickering on Gtalk!!! lol
Hashcode - for the Safestrap compatible 211 build ROM - on which this is based
Nitroglycerin33 - Awesome pull down toggles on a 211 build and quad lock with sound toggle!
SparkyMan - Amazing tweaks scripts!
Whirleyes over at XDA - Overclock support.
St3rdroids - Custom Simplex wall papers!
OFFICIAL Statement: I have updated my credits to include the Quadlock with sound toggle credit to Nitro! He politely reminded me. I did a lot of bouncing around getting it ready and forgot to credit properly. :-/ ... so I apologize! Blame it on the akakakalcohol! Lol
-The Goods!
Besides being deodexed this ROM is zipaligned at boot. It also has a great tweaks script put together by Sparkyman which makes this thing fly! There are currently 7 notification toggles with possible plans for further modification. The Blur lockscreen has been replaced with the AOSP modded to include the Blur sound toggle. You will also find the built-in Tethering & Hotspot fully functional from first boot! Blur camera is still in place but has been patched for AOSP Gallery2 support. It includes the Beats Mod, Cpu OC/Stock/UC controls, and Spare Parts. All additional settings can be found in system settings "Simplex Settings". Last but not least on this latest update I decided to go another direction with the UI of the ROM. You'll now experience more of an inverted feel with a good bit of semi-transparency! You know you're curious! ;)
Installation:
To install this ROM you must be on ICS with Safestrap installed! Safestrap is the only tested method! I always recommend doing a full wipe! For those on an older version of Simplex simply flashing the update may be ok without data wipe... The updater script will take care of wiping cache for you.
->Download and place on SDCard. Reboot to recovery. Wipe data/cache!!!. Install from SDCard. Reboot! Allow time for the ROM to boot completely then let it sit for a little while.
New!! - Download SimplexROM-v1.3 - Safestrap - 10/1/2012 -
- Gapps included.
Support:
Though I don't require it by any means... its always nice! So if you'd like buy me a beer! --->
Known Issues-
Quad lock is set up for using MMS messaging app! Removal of MMS and selecting it from the lock screen will cause a hot-reboot.
-Change Log
10/1/2012 - Update v1.3 "The Revival"
- Changed default launcher - Removed Trebuchet and replaced with Apex(free)
- The ever so requested Advanced power menu is here! I don't think more explanation is needed here.
- Updated Framework to build .215
- Revamped UI - Clean, Minimal, and Semi-transparent!
*Themers contact me if you wish to know which apps in particular needed special attention over framework mods*
- Revamped Init-d scripts.
- Updated G-apps. If you don't find a Gapp its in the Play Store. (to keep Download time down)
- Included Google Now!
- Included TeamHaters Wallpaper app w/ custom walls by St3rdroids.
- Included my Modded LatinIME(keyboard). Go to Keyboard/Input settings to select a Keyboard theme! Default is the best... lol
8/4/2012 - Update v1.2
- Incorporated blur sound toggle into AOSP lockscreen.
- Replace aosp Launcher with Trebuchet (compliments of CM)
- added Cpu Control Modules.
- Simplex Settings incorporated into System Settings!
. - CPU control - Overclock to 1.325Ghz, Stock - 1.2Ghz, or Underclock to 1.0Ghz to save some juice! ;)
. - Spare Parts - Advanced android settings.
. - Trebuchet Launcher settings.
. - Beats Audio - Just felt it looked cleaner incorporated into settings vs a separate app.
- A bit of house cleaning.
note : for cpu settings to take affect you will need to reboot.
7/1/2012 - Updated to v-1.0.1(Dropped Beta!)
- Updated AOSP lockscreen - 4 hotseats. Unlock, SMS, Phone, and Camera.
- Updated build.prop - fix some logcat issues - probably unnoticed by most.
- Included Beats Audio!
- Fixed issues with MyVerizon Market app.
- Cleaned up apps and updated as needed.
- Included Gapps! mainly to fix some reporting multiple Galleries. Fixed Picassa Sync.
- Updated Default Wallpaper! Credit to Dubs_X!
- if I missed anything, I'll fill you in later! lol
6-24-2012 - Initial release! :)
  • jmp485, mugsy77, mattlgroff and 28 others like this
#2 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 24 June 2012 - 04:59 PM
Mods and Other Downloads!
Stock Signal Cluster Mod -
Current MODS are for V1.2 ONLY! Will update as time permits.
Simplex Inverter Duty
As promised! This is the Start of an inverted theme for SimplexROM. For those that don't know what Inverted means.. Basically the stock apps with white background/black text have been swapped(or inverted). It makes for a darker and IMHO Cleaner experience. I have also themed Framework and SystemUI to match!!
ITEMS Themed:
Framework-res.apk | SystemUI.apk | Contacts.apk | Mms.apk | Email.apk | Calendar.apk
I do suggest the Installation of Inverted GApps as well available ->
Credit to Aixelsyd!!!
note: This will overwrite the battery mod if you have it installed! You should be able to flash the BatteryMOD after flashing InverterDUTY to have the best of both worlds.. ;)
note2: ScreenShots show a different font. I do not include font's in my builds due to everyone has their own taste! There are plenty of resources available to install on of your choice!
Installation:
Download theme and place on your SDCard. Flash as normal update. No wipes required!!! My script wipes /cache as needed during install.
Download Inverter Duty - SimplexROM - v0.1 -
LatinIME - MOD - MultiTheme:
All Info available on MOD Thread -
Simplex Battery MODS
Posted Imagean
-Solid Text Battery -
-Gradient Text Battery -
-Stubby Style Battery -
-Stock Style Battery(REVERT) -
-Round Style Battery -
Credit for Solid and Gradient Text Battery Images goes to Superrelaxx!
Others:
Install stock DeOdexed VVM app -
- Thank Kebob and 24v for this when I was being lazy! lol Great work!!
-old builds
Download SimplexROM-v1.2 - Safestrap - 8/4/2012 -
- Gapps included.
Download - SimplexROM-v1.0.1 - Safestrap ONLY! 7/1/2012 -
Gapps included!
Download - SimplexROM - RC1.1 - ICS[4.0.4] - Safestrap ONLY! -
Gapps for RC1.1! -
  • mugsy77, beyedup, dillanshives and 1 other like this
#3 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 June 2012 - 05:01 PM
Looking good man.
#4 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 24 June 2012 - 05:06 PM
Woooo hoooo. More crackflashing
#5 Instien
Instien
  • 9 posts
Posted 24 June 2012 - 05:07 PM
Looking forward to trying. Waiting on my install of .211 to finish as we speak. Can't wait to give this a go!
#6 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 24 June 2012 - 05:09 PM
Looking good man.
thanks man!
#7 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 24 June 2012 - 05:10 PM
I think you're bound to see more crack flashing possibilities as the OTA lands ;)
#8 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 24 June 2012 - 05:12 PM
Does the AOSP lock screen allow you to select what options it shows? How many options can you add?
#9 Bmplekan
Bmplekan
  • 27 posts
  • Twitter:@plekanb
  • LocationNY
Posted 24 June 2012 - 05:19 PM
Is there a 3G/4G toggle? Wifi tether?
Sent from my DROID RAZR using Xparent Cyan Tapatalk 2
#10 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 24 June 2012 - 05:23 PM
AOSP lockscreen... is just that for now. as the screenshot shows. This doesn't have parts from CM or AOKP in it... starting from scratch!
same with the toggles... I will be looking into adding more options soon. Wifi Tether is built in as stated in the OP...
#11 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 24 June 2012 - 06:15 PM
Sounds good. I'll give it a go later tonight. Thanks for all the hard work.
#12 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 24 June 2012 - 06:19 PM
You probably need to add in OP that gapps are required. I flashed without and play store no where to be found :D
#13 jb_alphamale
jb_alphamale
  • 251 posts
Posted 24 June 2012 - 06:24 PM
I just discovered this. I'm tented do do it now but I decided to do it tomorrow morning to avoid mistakes . Can't wait.
#14 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 24 June 2012 - 06:28 PM
I wonder if you can just use the download from Arctic.
#15 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 24 June 2012 - 06:31 PM
That's what I used. You just need to point it out to crackflashers at OP or you'll have to answering the question. Where is play store :blink:
#16 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 24 June 2012 - 06:35 PM
I meant to add that! sorry guys!!! I'll update the op right now!
#17 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 24 June 2012 - 06:37 PM
Smooth rom so far. Gotta test the battery life on it tomorrow and will report :)
#18 Erp
Erp
  • 264 posts
Posted 24 June 2012 - 06:38 PM
Haha this happened to me too. Luckily I had gapps on my SD card from previous roms.
#19 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 24 June 2012 - 06:40 PM
OP updated! thanks for the heads up... feed back is always welcome!
#20 mdowns989
mdowns989
  • 211 posts
  • Twitter:@mdowns989
  • Google+:+Michael Downs
  • LocationCentral Coast Cali.
Posted 24 June 2012 - 09:23 PM
My calendar keeps crashing...
Edit: Fixed never mind... running like butter...
Also tagged with one or more of these keywords: ics, roms, deodexed, init.d, modded
9 user(s) are reading this topic
0 members, 9 guests, 0 anonymous users
