locked hd safestrap info
52 replies to this topic
#1 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 28 September 2013 - 03:08 PM
For the unfortunate people stuck with a locked bootloader I thought I'd try to put a helpful guide together. For safestrap installation and instructions I'm gonna link you to hashcodes blog cause he built it and has the most thorough instruction IMO .
Now after you've completed that step and READ all the directions on how to  create ROM slots and install roms, what Roms can you install? All stock based Roms should work on safestrap. For other Roms look for anything posted around march 2013 and prior. I hope this helps.
Also when you flash a ROM successfully please post here what ROM you flashed.
  • neckchop, ibolski, zooyork0721 and 5 others like this
sig made by
Rinkle McBally
#2 caveman921
caveman921
  • 7 posts
  • Twitter:caveman921
  • Locationout of my mind
Posted 07 October 2013 - 02:00 PM
Nexesque
Running well so far but just installed it today.
RageHD 2.3
I ran this one for a couple days.  Restored a bunch of apps from titanium and screwed something up.  Will try again soon and let google install them this time.
White Widow
Inverted apps.  No issues after letting google reinstall my apps.  Didn't try titanium restore yet.
BlurryRom
Installed today and loving it!  May stick with it for a bit.  Lots of goodies built in.
I'm trying all the different roms I can for the foreseeable future so I'll post more soon.  I'm downling BlurryHD now.
  • qss247, shane1, elfor and 1 other like this
#3 sipple31
sipple31
  • 9 posts
  • LocationWisco
Posted 07 October 2013 - 03:12 PM
Nexesque
RageHD 2.3
White Widow
Did you get Nexesque to work on SS 3.60 (the latest)?
Sent from my iPad using Tapatalk HD
#4 caveman921
caveman921
  • 7 posts
Posted 07 October 2013 - 03:48 PM
Did you get Nexesque to work on SS 3.60 (the latest)? Sent from my iPad using Tapatalk HD
I did not try Nexesque with it.  I'm using 3.12.  I had one fail (don't remember which rom) a few days ago the first time I tried 3.60 so I switched back.
#5 caveman921
caveman921
  • 7 posts
Posted 08 October 2013 - 02:06 AM
Getting a binary error with RageHD and BlurryRom with 3.60.  Both installed fine with 3.12.  Trying BlurryRom now.
#6 sipple31
sipple31
  • 9 posts
  • LocationWisco
Posted 08 October 2013 - 03:40 AM
Yup... I think SS 3.60 is hosed.  I found the apk for 3.12, installed it, and now nexesque installs and runs great.  Guess I'll stick with it.  Thanks!
#7 deboyz1014
deboyz1014
  • 115 posts
Posted 04 November 2013 - 12:48 PM
Do you have the link to the 3.12 apk by any chance?
#8 fyby
fyby
Posted 05 November 2013 - 01:24 AM
Also tried RageHD 2 weeks ago, but it started to be very unresponsive and slow sometimes.
Changed to Blurry and Im happy with it. Using now for almost week and no problem at all.
#9 caveman921
caveman921
  • 7 posts
Posted 05 November 2013 - 12:54 PM
Looks like he took it down. :(
#10 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 November 2013 - 01:01 PM
Goo.im has been down
sig made by
Rinkle McBally
#11 cmh714
Posted 05 November 2013 - 01:26 PM
I dont see any safestrap versions under Hashcode on goo anymore.....
#12 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 November 2013 - 01:29 PM
Goo is off line
sig made by
Rinkle McBally
#13 cmh714
Posted 05 November 2013 - 04:00 PM
works for me :)
#14 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 November 2013 - 04:10 PM
Just came back on today and not everything is back up yet. Its been down since Saturday I think. Upgrade week lol
sig made by
Rinkle McBally
#15 livinginkaos
Posted 05 November 2013 - 04:13 PM
I haven't used goo in a while. I can always find it faster else wise.
Sent From My DEV X
  • shane1 likes this
#16 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 November 2013 - 04:15 PM
Hopefully that will be fixed after this upgrade they are doing is complete :)
  • livinginkaos likes this
sig made by
Rinkle McBally
#17 livinginkaos
Posted 05 November 2013 - 04:16 PM
The concept is good I think it just grew way to fast.
Sent From My DEV X
  • shane1 likes this
#18 mikew7458
mikew7458
Posted 13 November 2013 - 10:12 AM
Has anybody had any luck with Nexesque on SS 3.6 yet?
#19 mikew7458
mikew7458
Posted 13 November 2013 - 10:31 AM
Actually I just got it to work. Here's the directions I followed:
Delete your first rom-slot (by creating second slot and then deleting first). Re-create first slot with 2 GB partition. Wipe the data, cache, and dalvic cache of the first slot. Only select system under the mount options. Install. Reboot.
I kept getting the "no md5 file found" error, however I don't know what that affected.
Hopefully that works for anyone else.
#20 Devilalwayscries
Devilalwayscries
  • 93 posts
  • LocationUpstate NY
  • Current Device(s):droid razr maxx hd, og droid razr
Posted 19 November 2013 - 09:04 AM
You will get that a lot... Md5 is a list of numbers its basically a way to Check if you have a bad download most ROMs don't have one built in so you get that error... Some devs post a md5 on the website so you can use an app that will generate an md5 that you match with the md5 they provided you
