[BOOT ANIMATION] DROID Ultra Boot Animation for DROID RAZR XT912
No replies to this topic
#1 dubsx
dubsx
  • 400 posts
  • Twitter:dubs_x
  • LocationThe OH
Posted 27 September 2013 - 08:12 PM
OPTIMIZED FOR DROID RAZR
*Should work on any RAZR ROM (see installation instructions below).
**ADDED: 2 DROID Ultra-inspired wallpapers also in the downloads section
--Nitroglycerine33, for the server space
--artur0588, for the Ultra system dump found
This package includes:
- Boot Animation
INSTALLATION:ULTRA Boot Animation-FLASH-RAZR-XT912.zip
-boot into safestrap
-wipe cache/dalvik
-flash zip
-REBOOT
-ENJOY ;)
MANUAL INSTALLATION:ULTRA_bootanimation.zip
-use a file manager with root access (ES file explorer) to copy and paste bootanimation.zip into the system/media folder (or data/local).
-rename to bootanimation.zip (rename the original boot animation to bak_bootanimation.zip in case you want to go back)
-REBOOT and enjoy
AS ALWAYS...I AM NOT RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR PHONE AS A RESULT OF USING THIS CONTENT, JUST AS IT IS NO ONE ELSES FAULT FOR ANY DAMAGE I MIGHT DO TO MINE. IF YOU DO NOT KNOW THE RISKS INVOLVED, YA MIGHT JUST BE BETTER OFF STICKING WITH STOCK. It's not that complicated, just do a little research. Plenty of knowledge floating around...
DOWNLOADS
Don't be afraid to use the THANKS/LIKE button ;)
  • wof02021986 and yungbl00d like this
