Best Answer johnthehillbilly , 27 September 2013 - 07:22 AM
If you need updated RSDlite you can get it here https://db.tt/QqwBC2kA Or like Sam said.... try House of Moto.. . HD tappin' .... hillbilly style!! Go to the full post
Posted 26 September 2013 - 10:00 AM
So major noob mistake. I flashed over my stock rom. I knew i did it the second i hit the button. Well when I did the flash something did not install right and now I am stuck in fastboot mode. I normally just use safety strap for roms since I am not knowedge able to get any deeper. Can someone point me in a direction to get a stock or custom rom installed using RSD or fastboot. Tried CM10 and PAC though RSD and not luck there.
Posted 26 September 2013 - 04:55 PM
You need a .xml to flash in RSD. Plus, PAC and CM are not compatible with a locked bootloader and they're designed to be flashed in recovery anyway. I don't believe Matt's utility will work on the latest update, but you can use the .xml from here
and flash it in RSD. The latest update is the second choice down (78-1).R. Long: Pixel 5
Posted 27 September 2013 - 04:18 AM
I will give that a try. I must not of been loading the right .xml file cause I had tried to do that to get it to work. Thanks for the direction. Will let you know if I get it up and running.
Also i ment to say I tried CM and PAC through fastboot and a stock through RSD. Did not realize you needed to be unlocked as well as rooted for those to work.
Posted 27 September 2013 - 05:25 AM
Got a failed flash again. It failed on the system.img.
Posted 27 September 2013 - 06:21 AM
Are you using the most up-to-date RSD?
Posted 27 September 2013 - 06:25 AM
Try my House of Moto with your FXZ. Flash it in fastboot snapdragon mode.
Posted 27 September 2013 - 07:21 AM
RSD v5.7
Posted 27 September 2013 - 07:22 AM Best Answer
Posted 27 September 2013 - 07:24 AM
The HoM has 6.1.5 built in as a private copy of RSD. So that's another option.
Posted 27 September 2013 - 07:32 AM
Did that but getting a no valid PIV block in SP for system error
Posted 27 September 2013 - 08:17 AM
There are two possibilities. Your FXZ files are wrong. Or you're not using the original USB cable that came with your phone. Rectify whichever issue it is and try again. Also make sure your phone is fully charged.
Posted 27 September 2013 - 08:19 AM
Ended up working with the updated RSD. Never even thought to check if there was an updated on. Thanks for the help.
Posted 27 September 2013 - 08:23 AM
Excellent.
Posted 28 September 2013 - 12:13 PM
Cant get out of dead droid with "!" out of his chest or ap fastboot mode...I flashed the wrong ROM and device wont show on computer with usb....im stuck
Posted 28 September 2013 - 12:17 PM
Posted 28 September 2013 - 12:23 PM
AP Fastboot Flash Mode (S)
10.9B(*) (sha-1e9f557, 2013-05-24 14:49:34)
eMMC Info:size 8GB
Battery OK
Connect USB
Data Cable
Failed to hab check for boot: 0x56
Fastboot Reason: Boot Failure
usb connected
Posted 28 September 2013 - 12:31 PM
yes
Posted 28 September 2013 - 12:32 PM
thats how it all started....tried to install beanstalk not knowing its a rom that CANT be flashed sucessfully
Posted 28 September 2013 - 12:39 PM
