Droid Razr Utility 1.7 Help Thread
314 replies to this topic
#121 Guest_BDH_*
Guest_BDH_*
Posted 30 June 2012 - 01:41 PM
got a question for you all. took the official ota today but made sure i had voodoo and did a backup root. installed the ota fine and rooted and all is good. now trying to install bootstrap from the utility and seems like it just gets hung up and doesnt do anything. any ideas. usb debugging is on too
Why install bootstrap? Safestrap is the only supported recovery.
#122 Mr.Rzr
Mr.Rzr
  • 102 posts
  • LocationThe InterWebz
Posted 30 June 2012 - 01:44 PM
oh ok didn't know that. maybe thats why it wasnt working ha. so just install it the same way?
#123 Guest_BDH_*
Guest_BDH_*
Posted 30 June 2012 - 01:46 PM
Yep, install the app, open the app and install the recovery.
#124 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 30 June 2012 - 01:47 PM
just tried it again and nothing. when i push enter it doesnt do anything. no app installed
#125 Guest_BDH_*
Guest_BDH_*
Posted 30 June 2012 - 01:54 PM
Are you rebooting after you install the app?
#126 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 30 June 2012 - 01:55 PM
no. ill try that right now
#127 Guest_BDH_*
Guest_BDH_*
Posted 30 June 2012 - 02:02 PM
If it doesn't work, let me know and I'll upload the apk for you.
#128 Mr.Rzr
Mr.Rzr
  • 102 posts
nope same thing. didn't install
that would be sweet!!^^
#129 Guest_BDH_*
Guest_BDH_*
Posted 30 June 2012 - 02:05 PM
Give me about 5 minutes
#130 Guest_BDH_*
Guest_BDH_*
Posted 30 June 2012 - 02:08 PM
Safestrap Mirror:
#131 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 30 June 2012 - 02:17 PM
Safestrap Mirror:
right on thanks a lot! never really used safe strap do i just go to install recovery?
#132 Guest_BDH_*
Guest_BDH_*
Posted 30 June 2012 - 02:19 PM
That's it, then follow this post I literally just made on how to use it properly:
  • Mr.Rzr likes this
#133 topdog031382
topdog031382
  • 131 posts
Posted 30 June 2012 - 02:22 PM
Ok this is just a general question, I have already rooted using the utility 1.7 and I was on the Soak test no issues and actually this post really isnt for me I am just trying to prove a point to someone else. Has anybody recieved the Official OTA not the leak or soak (yes I know they are the same) and rooted the OTA using the utility?
#134 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 30 June 2012 - 05:16 PM
thanks a lot man!
#135 Eusibius2
Eusibius2
  • 13 posts
Posted 30 June 2012 - 07:15 PM
I've tried this, but adding ;C:\Windows\System32 doesn't work. So I tried the modded211 unstuck and the link you posted doesn't exist. Any help?
Utility closes when I press enter at the Batman
  • Please Login or Register to see this Hidden Content
  • See the above link. add
    ;C:\Windows\System32to the end of your PATH.
  • If still these did not fix you and you can open previous utilities like 1.6, just run option 1 in 1.6, then option 3 in my modded 211 unstuck to install ICS recovery.
  • After you use function 3 in the modded211 unstuck, reboot into Motorola Recovery (how is listed below), and wipe cache (suggested data too). Then install the 211 update from your external storage. Enjoy.
#136 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 30 June 2012 - 07:19 PM
Looks like someebody broke my unstuck from rombot!
#137 engbob
engbob
Posted 30 June 2012 - 07:25 PM
I was wondering if you could tell me what i was doing wrong.
I used utility 1.4 to get me back to stock 2.3.5 (or 2.3.6, sorry don't remember). I had to do this because i had a rooted phone,and was unable to update to ICS. After going back to stock, i did 2 OTA updates to get me to 4.0.4 ICS. At this point i am looking to re-root. I downloaded Utility 1.7,i have re-downloaded the motorola drivers, and wiped the cache on my phone. However, everytime i try to root my phone (using option 3), i get "waiting for device". I have tried using different USB ports, and re-booting, but haven't had any success. Any ideas?
#138 Eusibius2
Eusibius2
  • 13 posts
Posted 30 June 2012 - 07:28 PM
Cool - ok, thanks. Now I can't get Motorola Recovery to start. I can get AP Fastboot Flash Mode (S)... device is locked, status code 0. Then nothing. Any suggestions how to proceed? I think I'm in a bit of a pickle...
[update] Ok - 2 hours later... I had to run and re-run 1.6 about 3 times in order to get my phone back to android recovery. finally got my ICS back on my phone. Would be nice to follow up with how to get 1.7 to work again, though.
#139 HouseMD
HouseMD
    Vicodin Addict
  • 294 posts
  • Twitter:DSLRVideoGuy
  • LocationCharlotte, NC
Posted 01 July 2012 - 10:09 AM
What's wrong with 1.7 for you?
If you feel the need to buy me a beer, or help pay my bills, here's the link:http://bit.ly/O4ZnLW
#140 Eusibius2
Eusibius2
  • 13 posts
Posted 01 July 2012 - 10:23 AM
I couldn't get it to load. I've tried the solutions that Matt posted originally, but they still didn't work. :-(
