Need to turn on USB debugging
Ooof. Thanks. My brain wasn't registering that I needed to enable it AFTER installing ICS.
Posted 29 June 2012 - 06:03 AM
Posted 29 June 2012 - 10:30 AM
Posted 29 June 2012 - 11:07 AM
so im having issues.
I downloaded the .211 update
downloaded both the 1.6 and 1.7 utility
checked all with md5 check sum (all was good)
put the update on the root of my SD card
booted into AP FB
opened the 1.7 utility
booted up and when it said "press any key to continue" i pressed enter and the screen closed.
I added to the system path like it says to in the OP (pic attached)
so i then tried to boot up 1.7 and again when it tells me to press any key, it just closes.
I tried using the 1.6 utility and it too just closes after "press any key"
Thats as far as ive gotten
Any ideas?
Posted 29 June 2012 - 11:15 AM
Use WinRAR to extract the zip file.
Posted 29 June 2012 - 11:18 AM
This is how i have it on my SD card. If i try to unzip it, it would be multiple files
And I havnt even gotten to that point because I cant get the utility to work past "press any key to continue"
Posted 29 June 2012 - 11:26 AM
Let me rephrase. Extract the Utility.
Posted 29 June 2012 - 11:27 AM
Posted 29 June 2012 - 11:33 AM
Posted 29 June 2012 - 12:01 PM
\Droid was unexpected at this time.
Posted 29 June 2012 - 12:34 PM
Ok so i took a video of my opening the utility and pressing any key to continue.. a screen flashed real quick and then closes..
so i went frame by frame and this is what it pops up with for a fraction of a second before closing.
Any ideas???
Posted 29 June 2012 - 12:43 PM
Posted 29 June 2012 - 01:28 PM
Just taking a stab here since I haven't read back to all of your previous posts, but you might try extracting (or moving) the utility and all it's subfolder to the a folder on the root of your C; drive (ie. C:\DRU17). I'm thinking you may have some characters in your path that are giving the script a hard time.
Can't hurt to try.
Posted 29 June 2012 - 03:13 PM
Posted 30 June 2012 - 09:20 AM
Posted 30 June 2012 - 09:40 AM
Alright fellas....I need a little bit of assistance. This is what I've done so far and where I'm having an issue:
Any ideas? Thanks in advance for the help guys....not sure else what to do.
- I rooted my device using v1.6 of your utility for GB (I was on v1.81) successfully
- Installed VooDoo OTA Rootkeeper, created a SU backup successfully
- Installed ICS v.211 via OTA. Install was fine
- Attempted to restore root via Rootkeeper. It says it succeeded, but I do not have root. Refreshing within rootkeeper does not show root. None of my root apps have root access.
- Superuser.apk is still installed and "su" is still located within /system/bin. busybox is located within /system/xbin
- I uninstalled Motorola v5.2 of the x64 drivers (previously had a Bionic)
- I Installed the included driver for my system (x64 - I'm running Windows 7) in the Drivers of the zip you've provided
- Go to Settings > Developer Options > Enable USB Debugging
- Plugged in USB and in the notification/pulldown menu. Choose the USB Mode as MTP.
- Run option 3 on the 1.7 Utility "Ice Cream Sandwich 4.0.4 Root"
- It says "Waiting for device" and the utility never finds my phone.
- Rebooted my device/laptop numerous times to no avail. It still hangs at "Waiting for device"
Posted 30 June 2012 - 09:44 AM
Double check usb debugging. That's usually what wait for device means
Posted 30 June 2012 - 10:28 AM
Posted 30 June 2012 - 12:33 PM
Posted 30 June 2012 - 01:38 PM
