Droid Razr Utility 1.7 Help Thread
#261
Posted 01 September 2012 - 06:40 PM
#262
Posted 01 September 2012 - 07:14 PM
Sent from my Simplified Droid Razr
#263
Posted 01 September 2012 - 08:09 PM
having the EXACT same problem as jmlenz. I've done everything he has. I've followed the instructions perfectly. I've used the help thread. I've googled until I'm cross-eyed. My phone has never been rooted and I still have all the bloatware. I was even able to use 1.6 to restore to factory (just for kicks) and I can't OTA or sideload. I get stuck with a failure on OTA and a I get the exact error as jmlenz.
updating LTE...
asset failed: motorola .motoflash("/tmp/lte.img")
E: Error in /tmpsideload/package.zip
(Status 7)
Installation aborted
Are we just doomed? I spent 12 hours on this yesterday doing it every way I can think of. Different computers, different cables.. wipe before running utility, wipe after utility, booting GB, then going back to recovery, wiping before running ICS sideload. Same results every time. It's incredibly maddening.
bought a bad esn xt912 off ebay with hope to be reflashed to other network. stuck on lte.img as well. any remedy for the issue here?
#264
Posted 18 September 2012 - 06:12 PM
Why not just try the simplest and easiest route and use RSD Lite to flash the sbf file
SBF file for your phone can be found here:
RSD Lite can be found here for download in the first post:
#265
Posted 27 September 2012 - 02:51 PM
#266
Posted 27 September 2012 - 07:23 PM
lol this happened to me yesterday literally. i filed a claim yesterday and said i lost my phone, paid whoever their 100 dollars and they sent me a new phone which i got today. thats what you probably should have done. idk what to tell ya man, connect it to your comp and attempt to get into AP fastboot (may be difficult without a screen, do it from memory) and flash the stock .211 from matts utility. i forgot how to root my phone? can you help me lol/ eh ill figure it out, run matts utility root exploit 4.0.3?? and i forgot how to install safestrap and all that jazz, ill just hit up youtube in a few days.Broke the screen on my rooted droid razr. Can't see anything but cracks. Replaced with new droid razr & rooted it. Now I have to send my old phone back. Should I worry about restoring it or unrooting it? If so, how can I do it since I can see the screen?
#267
Posted 28 September 2012 - 09:49 PM
You replaced it for a cracked screen, which made it unusable. That has nothing to do with rooting, so you probably shouldn't worry about it. If you scramble it by half unrooting, you'll be no better off. You might be able to use HDMI or a third party app to see what you're doing on another screen.
FWIW, they can tell if it was rooted, even if you return it to stock. And frankly, fraud claims for water damage or abuse are more likely to cause issues (since they are fraud, which is not condoned by this site or any other android development site of which I am aware).
Sent from my DROID SPYDER using Xparent Blue Tapatalk 2
#268
Posted 02 October 2012 - 02:35 PM
#269
Posted 24 October 2012 - 11:01 AM
#270
Posted 02 December 2012 - 08:54 PM
I attempted to use the Droid Razr Untility (1.8) following all the settings and pre-condition steps and now my phone will not boot. It shows something similar to the AP Fast Boot screen with the following:
The following is the output I got while using the utility's Fast Boot Restore (Option 1)
...any ideas?
#271
Posted 02 December 2012 - 11:21 PM
Yup... you were on Gingerbread. You cannot use 1.8+ with Gingerbread....any ideas?
Use this to unbrick.
#272
Posted 04 December 2012 - 10:46 PM
Thanks for the link.
I definitely had ICS not Gingerbread.
Unbricked, but the "package file is invalid" problem remains.
I tried all the fixes that I could find but no luck. Seems I have a dodgy phone.
#273
Posted 05 December 2012 - 05:21 AM
sent from my DROID RAZR tapadriving....
#274
Posted 25 December 2012 - 06:24 AM
i cannot get past this part to root my phone... help?Try doing "adb kill-server" in the CMD before running the utility.
#276
Posted 25 December 2012 - 07:07 AM
#277
Posted 25 December 2012 - 07:08 AM
#278
Posted 25 December 2012 - 07:16 AM
says ads isnt recognized as an internal or external command.. been tryn to figure out how to kill server in cdm but no luck
so..... you have the utility downloaded and unzipped on your desktop? ...... also which utility are you trying to use ?
#279
Posted 25 December 2012 - 07:21 AM
#280
Posted 25 December 2012 - 07:23 AM
