This seems to be the best fix
Thank you very much for your excellent work. Sorry about the insult..didnt intend it to sound like that.
Posted 07 July 2012 - 04:11 AM
Posted 07 July 2012 - 07:53 AM
+++++ Factory reset also worked for meI had the same problem...so I did a factory reset and it worked.
Posted 07 July 2012 - 05:05 PM
Posted 07 July 2012 - 06:25 PM
Posted 07 July 2012 - 08:21 PM
I thought it was impossible to go back to GB after ICS.
Posted 08 July 2012 - 08:00 AM
Posted 08 July 2012 - 10:09 AM
Posted 08 July 2012 - 10:20 AM
ok i need some help. when i press #3 to root and click ok for debugging being on. it just stayes at waiting for device.
i installed the Motorola 64 bit drivers on the computer. it in mtp mode with ap flash on and the debugging mode on. when my device is plugged in it says mot single adb interface on the computer. i wiped the device.
windows 7 machine.
Posted 08 July 2012 - 10:59 AM
boot into moto recovery and do a complete factory reset and try againok i need some help. when i press #3 to root and click ok for debugging being on. it just stayes at waiting for device.
windows 7 machine.
Posted 08 July 2012 - 01:13 PM
how do i get her in moto recovery and rest her.boot into moto recovery and do a complete factory reset and try again
Posted 08 July 2012 - 01:50 PM
1. Turn off phonehow do i get her in moto recovery and rest her.
i ran #2 and that ran just fine but #3 wont work just say waiting for device.
Posted 08 July 2012 - 02:03 PM
Posted 08 July 2012 - 03:48 PM
Posted 08 July 2012 - 03:56 PM
You need to select zip file you copied to SD card not some file inside ithow do i fix my phone. i try going to the recovery menu and clicking on recovery, then both vol buttons when the guy with the red thing on hit chest. and going down to the update from sd but i don't know what file to click on there is a lot in the 211 file.
Posted 08 July 2012 - 04:06 PM
Try taking the unextracted zip file for the utility and put it on your C: drive, use WinRAR to extract there.
Posted 08 July 2012 - 05:00 PM
do not extract the .211 fastboot file! this has been made clear in numerous posts, including the OP. If you extract the files from the .211 zip file, your update will fail, and then you'll be back here posting (like a lot of users already have done) trying to figure out what you did wrong. Take the time to read the OP (and other posts if you still don't understand fully) before modding your phone; there are directions there for a reason. The dev (matt) didn't put them there for decoration, didn't put them there to waste your time, and didn't put them there for people not to read. If half the users that have simple problems actually took the time to read OP and follow the directions, they wouldn't be having the problems they're having.
Quit selling yourselves short people... you're obviously intelligent individuals, so quit selling yourselves short and educate yourselves.
Posted 08 July 2012 - 05:27 PM
windows 7 machine.
Posted 08 July 2012 - 05:56 PM
Ummm I was talking about the Utility in my post, which you clearly quoted so.......lol talk about needing to read haha.
Posted 09 July 2012 - 07:29 AM
Posted 13 July 2012 - 07:10 AM
