phone bricked encryption unsuccessful and reset button will not work
26 replies to this topic
#21 Gloomfrost
Gloomfrost
  • 9 posts
Posted 12 August 2014 - 12:14 PM
Tried - just gives "partition_signed" -> phone returned fail. fastboot just gives the remote-device error.. =\
#22 livinginkaos
Posted 12 August 2014 - 12:52 PM
Are you using a fxz from the sbf website.
sent from my G3
#23 Gloomfrost
Gloomfrost
  • 9 posts
Posted 12 August 2014 - 02:22 PM
Yes. Using Blur_Version.98.21.122002.XT925.RCI.en.CA
from
Device before was 4.1.2 on Fido (not rogers) but I don't think that should matter. Either way I think I also tried the xt926 for the verizon US version, but everything fails the same way.
#24 SamuriHL
  • 44,375 posts
Posted 12 August 2014 - 02:26 PM
Um.  You basically bricked your phone doing something that you "didn't think should matter".  There's no fixing that.
#25 Gloomfrost
Gloomfrost
  • 9 posts
Posted 12 August 2014 - 02:45 PM
Thanks but AFAIK it's the same package just different logo. Why would that brick it? Also, I haven't had one successful flash, and the phone still boots up (past the motorola badge with the waves), and even shows the clock/boot logo/battery status for a split second then goes into 'Encryption Unsuccessful' (which btw where this started from), so no change from what I can tell.
#26 SamuriHL
  • 44,375 posts
Posted 12 August 2014 - 02:54 PM
I'll let you do the research on why flashing an FXZ not made for your phone is "a bad idea™".  Basically, there's nothing I can do to help you in this current situation you're in.
#27 Gloomfrost
Gloomfrost
  • 9 posts
Posted 12 August 2014 - 03:09 PM
The flash failed so it's still an XT925 with XT925 firmware..
