phone bricked encryption unsuccessful and reset button will not work
26 replies to this topic
#1 droidrazrhd
droidrazrhd
  • 7 posts
  • LocationUSA
  • Current Device(s):droid razr hd
Posted 25 September 2013 - 06:55 PM
well basically it says it in the title i got a Droid Razr HD and i tried to root it and it worked ok for a few days then it failed.
i tried to do a master reset through android system and still fails..
it still boots into the latest safestrap and still will not work..
anybody got any ideas please help
#2 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 25 September 2013 - 06:57 PM
The answer is you do not have a DROID RAZR HD or the files are wrong, that is why these are failing each and every time.
If you need pictures of the devices...
#3 droidrazrhd
droidrazrhd
  • 7 posts
  • LocationUSA
Posted 25 September 2013 - 06:59 PM
i have a droid razr xt926 that is my physical phone xt926
#4 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 25 September 2013 - 07:02 PM
Don't know what to tell ya... it is failing pre-flash validation. That means it's not for your device or device's secure version #.
"Remote Fail" can mean your battery is completely dead and you need a factory adapter to flash the files; once you use the correct ones.
#5 droidrazrhd
droidrazrhd
  • 7 posts
  • LocationUSA
Posted 25 September 2013 - 07:05 PM
so i cant even use the correct power cord i need this adapter..
ok so then what do you recommend to do dude..i do have an xt926
its the factory power cord and i do have the right files
#6 droidrazrhd
droidrazrhd
  • 7 posts
  • LocationUSA
Posted 25 September 2013 - 07:08 PM
so your saying that could be the cause is that my phone is not picking up the battery
even though when i boot into safestrap it saying its picked up the charge and the percentage of the battery show its progress
#7 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 25 September 2013 - 07:09 PM
"Remote Fail" could mean many things, that is just one of them.
  • johnthehillbilly likes this
#8 johnthehillbilly
Posted 25 September 2013 - 07:13 PM
Boot into AP Fastboot..... what does it tell you there .... also... what OS are you using? ....and are you using a USB 2.0 or 3.0..... and did you completely install the Motorola drivers before starting?
#9 droidrazrhd
droidrazrhd
  • 7 posts
  • LocationUSA
Posted 25 September 2013 - 07:16 PM
in Ap Fastboot it gives me the regular options, i had the stock rom 4.1.2 jelly bean..
the latest safestrap and i have all the drivers installed
#10 droidrazrhd
droidrazrhd
  • 7 posts
  • LocationUSA
Posted 25 September 2013 - 07:17 PM
would you recommend buying the adapter and flashing those files
#11 johnthehillbilly
Posted 25 September 2013 - 07:21 PM
Regular options?.... APFastboot has no options....
Yes.... its always a good idea to have a TBH adapter or cable on hand ....
  • mattlgroff likes this
#12 droidrazrhd
droidrazrhd
  • 7 posts
  • LocationUSA
Posted 25 September 2013 - 07:26 PM
in Ap Fastboot it says
ap fastboot flash mode
10.98(#) (sha-1e9f577, 2013-05-25 01:04:26)
emmc info size 16gb
Device is LOCKED Status Code: 0
battery ok
connect usb
data cable
fastboot reason: boot menu selected
#13 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 25 September 2013 - 08:21 PM
emmc info size 16gb
battery ok
connect usb
data cable
I'm not sure, but does it always show the BL info when you're in fastboot mode (it is the BL info on the third line, right?)?  I don't remember seeing that last time I was in fastboot on my phone.
#14 johnthehillbilly
Posted 25 September 2013 - 08:25 PM
Ya know Rik... now that you mention it, I can't remember seeing that either, on any of mine.... going to have to go to AP fastboot to see ....
#15 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
  • Current Device(s):DROID RAZR M
Posted 28 September 2013 - 09:27 PM
The bootloader status is always shown for me, on my m, in fastboot, but mine says UNLOCKED Status Code 3. :)
  • RikRong likes this
#16 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 29 September 2013 - 12:18 AM
Cool, yeah, I couldn't remember if it showed or not.
#17 planarbox
planarbox
Posted 22 February 2014 - 02:31 PM
Alright, so I seem to be having a similar issue with the xt912.  Encryption Unsuccessful, but I can't actually get into fastboot because my device is similarly locked.  How exactly was this fixed?  Is it the adapter that solved it?  I think I may have a different issue however because my is similar but states the batter is OK.  Any help would be appreciated.  I don't know if this thread is too old, but it sounded really similar to mine and didn't want to start a new thread if I didn't have to
#18 johnthehillbilly
Posted 22 February 2014 - 02:38 PM
You don't have to be unlocked to be able to boot into AP Fastboot ....you can get to AP Fastboot by powering completely off.. then hold vol down and vol up and power... use vol down to highlight Fastboot and then vol up to select it........ have you tried Matt's utility for your 912?
Tapadriving.... hillbilly style!!!
#19 Gloomfrost
Gloomfrost
  • 9 posts
Posted 11 August 2014 - 11:33 PM
Was there ever a solution to this? I have the identical problem as seen above. Further, using Matt's 1.21 utility (option 2) shows:
Failed to hab check for recovery: 0x56
preflash validation failed for recovery
#20 livinginkaos
Posted 12 August 2014 - 08:22 AM
Try SamuriHL's RSD flasher or House of Moto.  Matt's utilities haven't been updated.
