[ROM][Unofficial][4.3][JFLTEVZW] AOKP - Updated 12/01/2013
ROM Rage AOKP Team usmcamgrimm 4.3 Android Best
12 replies to this topic
#1 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 22 September 2013 - 03:14 AM
     If coming from another ROM you will need to do a full wipe
     Use TWRP or CWM to flash the ROM
     Flash RAGE Gapps
     Reboot
  • TeamRage and jl90 like this
#2 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Spoiler
#3 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 22 September 2013 - 03:21 AM
Very very cool!!! Glad you got it posted. ;)
  • stewie griffin and usmcamgrimm like this
#4 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 03 October 2013 - 12:57 AM
Updated 10-03
  • jl90 likes this
#5 Ch83
Ch83
  • 18 posts
Posted 04 October 2013 - 12:42 PM
Is the kernel included in the rom if coming from a dev edition device or does that need to be flashed separately on this one?
#6 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 04 October 2013 - 02:09 PM
Should work but I recommend this kernel: http://forum.xda-dev...d.php?t=2294083
Future builds will have it included
Sent from my SCH-I545 using Tapatalk 2
  • jl90 likes this
#7 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 04 October 2013 - 11:49 PM
Link has been fixed! Thank you Ch83 for bringing that to my attention
#8 Ch83
Ch83
  • 18 posts
Posted 05 October 2013 - 03:24 PM
I am getting an Error Status 7 when trying to install the rom from external SD. I did a clean wipe of system, flashed kernel, then attempted in flash the ROM in that order. Did I miss a step?
thanks
#9 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 05 October 2013 - 04:48 PM
The ROM has to be flashed first, then the gapps. Reboot the phone, then reboot back into recovery. Flash kernel, wipe cache/dalvik, fix permissions and reboot.
Sent from my SCH-I545 using Tapatalk now Free
#10 Ch83
Ch83
  • 18 posts
Posted 05 October 2013 - 06:35 PM
I tried flashing the rom first and get the same problem
assert failed: getprop("ro.product.device")  == jfltevzw
                     getprop("ro.build.product")  == jfltevzw
With the developer phone, do I need to flash the kernel first for the rom to recognize the device? I have not disregarded your assistance about flashing the rom first, just trying to clarify.
thanks
#11 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 05 October 2013 - 10:13 PM
Try a fresh download and then wipe a couple of times to ensure you are starting clean. Then reflash
Also, what recovery are you using?
#12 Ch83
Ch83
  • 18 posts
Posted 06 October 2013 - 05:08 AM
Thanks I will try that. I am using Philz 5.15
#13 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 23 November 2013 - 03:59 AM
Updated 11/21
Also tagged with one or more of these keywords: ROM, Rage, AOKP, Team, usmcamgrimm, 4.3, Android, Best
