{ROM} GZR Presents Validus13
9 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 19 September 2013 - 12:39 PM
    Latest CM Bells & Whistles
    Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
    Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
    Turn screen on when plug/unplug the USB cable as an option in settings;
    Reboot Menu Enable by default;
    Brightness control sliding through status bar;
    Custom Carrier Label;
    Status Bar Transparency and Custom Colors;
    Status bar network speed indicator with option to custom colors;
    Option to auto hide network speed indicator when there is no traffic;
    Status bar quick peek;
    Notification drawer + Notification row Transparency, custom Colors and custom image;
    Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
    Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
    Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
    Appbar from ChameleonOS;
    Lockscreen based on gestures from ChameleonOS;
    HALO 2.0 by ParanoidAndroid;
    BlackUI (Darkness), TRDS from Slim Roms;
    LCD density changer
    Option to enable notifications light even with screen on;
    Option to enable lock screen rotation;
    Open tiles in floating window;
    QS tile fast charge;
    Powerwidget toggle fast charge;
    Speed up statusbar / notification drawer;
    Alternate default app picker;
    Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
    Floating window from notification drawer (Long press);
    Option to show Wifi name in notification drawer;
    Option to flip tiles in simple press;
    Listview Animation;
    Listview Interpolator;
    SlimRoms Nav bar
    SlimRoms PIE
    Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
    More to come........
      1. Follow normal flashing rules
      2. Use only 4.3 Gapps
      3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
dustinb(beautiful themes)
JaeKar99
DrDevs
CM Moto team
SlimRoms
And many more :)
Download:
Custom Wallpapers:
  • benji84 likes this
#2 llawen
llawen
    android tweaker
  • 551 posts
  • Twitter:@llawen
  • LocationGlenn hieghts, Texas
  • Current Device(s):razr maxx hd
Posted 21 September 2013 - 05:03 PM
Woot last.
Sent from my Razr HD using Tapatalk 2
#3 sickkside13
sickkside13
  • 12 posts
  • Locationchicago
  • Current Device(s):MB886
Posted 23 September 2013 - 08:22 AM
I can't download the ROM it says not found
#4 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 23 September 2013 - 11:46 AM
OP link updated apologies
#5 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 15 October 2013 - 05:28 PM
10/15/13
The original v13 is back :)
Integrated xposed and greenify
Thanks to dustinb v13 now includes 3 of his awesome cobalt themes
I tested mms after build worked fine for me
Updated with the latest cm commits
Smooth and dependable.. Enjoy
#6 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 18 October 2013 - 04:50 PM
op updated 10/18
mms still broken(best to use 3rd party for right now)
added battery level around lockscreen icon
latest cm commits
#7 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 21 October 2013 - 07:51 AM
Build updated 10/20
Removed Greenify in settings (caused a few conflicts when trying to upgrade still imbedded in
Added Omni's Multi-Window granted still WIP but i liked it :)
And yes MMS is working
  • P20KILLER likes this
#8 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 27 October 2013 - 05:23 PM
10/27
Building with -03 Flags for a lil extra linaro smoothness
Traffic Meter in Statusbar option
Misc. Fixes
Dunno about mms i'm trying and i dont wifi tether so your guess is as good as mine
All the latest cm commits
#9 Joseberga
Joseberga
  • 36 posts
  • Twitter:djjosemix
  • Google+:+JoseBaez990
  • LocationArgentina - Formosa
  • Current Device(s):Motorola Razr HD XT925
Posted 30 October 2013 - 02:38 PM
Looks good.. I will try this rom.. Thanks!
Sorry for my English ^^
#10 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 02 November 2013 - 04:24 AM
Op Updated More Stability
and new gapps package
