{ROM} GZR Presents Validus13
125 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 19 September 2013 - 12:37 PM
  • Latest CM Bells & Whistles
  • Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
  • Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
  • Turn screen on when plug/unplug the USB cable as an option in settings;
  • Reboot Menu Enable by default;
  • Brightness control sliding through status bar;
  • Custom Carrier Label;
  • Status Bar Transparency and Custom Colors;
  • Status bar network speed indicator with option to custom colors;
  • Option to auto hide network speed indicator when there is no traffic;
  • Status bar quick peek;
  • Notification drawer + Notification row Transparency, custom Colors and custom image;
  • Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
  • Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
  • Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
  • Appbar from ChameleonOS;
  • Lockscreen based on gestures from ChameleonOS;
  • HALO 2.0 by ParanoidAndroid;
  • BlackUI (Darkness), TRDS from Slim Roms;
  • LCD density changer
  • Option to enable notifications light even with screen on;
  • Option to enable lock screen rotation;
  • Open tiles in floating window;
  • QS tile fast charge;
  • Powerwidget toggle fast charge;
  • Speed up statusbar / notification drawer;
  • Alternate default app picker;
  • Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
  • Floating window from notification drawer (Long press);
  • Option to show Wifi name in notification drawer;
  • Option to flip tiles in simple press;
  • Listview Animation;
  • Listview Interpolator;
  • SlimRoms Nav bar
  • SlimRoms PIE
  • Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
  • More to come........
      1. Follow normal flashing rules
      2. Use only 4.3 Gapps
      3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
dustinb
DrDevs
JaeKar99
CM Moto team
SlimRoms
And many more :)
Download:
Custom Wallpapers:
Our G+
  • karthakon likes this
#2 x60centenergyx
x60centenergyx
  • 45 posts
  • LocationAtlanta, GA
  • Current Device(s):XT907
Posted 19 September 2013 - 12:54 PM
Awesome! I'm downloading now...
  • somber73 likes this
#3 kendog
kendog
  • 234 posts
  • LocationMillville, NJ
  • Current Device(s):droid bionic
Posted 19 September 2013 - 03:00 PM
Something is chewing up my battery haven't even been on phone in 5 hours it went down 50%
#4 BwingG
BwingG
  • 140 posts
  • LocationSeattle
  • Current Device(s):RazrM
Posted 19 September 2013 - 05:17 PM
congrats OSE!  will be trying this shortly
#5 kyanil
kyanil
  • 14 posts
  • Current Device(s):Droid Razr M XT907
Posted 20 September 2013 - 10:27 AM
Works fine for me i have been on it almost since they released and no issues. Battery life lasts longer than a few other 4.3 roms out there (at least for me).
#6 lowvolt
lowvolt
  • 478 posts
Posted 20 September 2013 - 10:34 AM
Man oh man. Ask and ye shall receive! This one plus Droid concepts, makes two new ROMs for the M. I for one am loving it.
#7 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 20 September 2013 - 06:42 PM
only seems to be missing option for adding menu as a nav button.  does have the side dot option for menu but i prefer the other.  all in all been running great!  great job guys
#8 L3van
L3van
  • 16 posts
Posted 21 September 2013 - 01:15 AM
so, no issues with this ROM like any other 4.3 roms? :o
#9 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 21 September 2013 - 03:26 AM
that's in the works cheif though I could have sworn we had menu over flow in there I'll have to check the code. Glad to see its working out
Sent from my Droid RAZR M using Tapatalk 2
#10 kyanil
kyanil
  • 14 posts
Posted 21 September 2013 - 06:03 AM
hey just wanted to post a bug i found. when sending a text to a friend of mine my phone went through a 5 minute force close loop of the phone app (didnt know phone and messaging worked together) and the contact names for phone numbers stopped showing for a few minutes after. i dont know what exactly caused it but i think it may have been me sending this Æ symbol. nothing major just wanted to give a heads up that the symbols might be bugged. another note is that it caused that text message to never send. thanks for the rom im loving it. thats the first and only downside or hiccup ive seen since the release and its not important at all. keep up the good work OSE team!
\\ just went and sent just the AE symbol (u do this by holding down the a key while in caps) and it crashes again. its definitely that symbol crashing com.android.phone
#11 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 21 September 2013 - 06:34 AM
will have a look thanks :)
#12 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 29 September 2013 - 02:24 PM
Updated to stable build 2 added
AOKP animations
Floating Windows
Active Dispay
and the latest cm commits
#13 hyro864
hyro864
  • 34 posts
Posted 29 September 2013 - 06:38 PM
AOKP animations
Floating Windows
Active Dispay
So far, so good. Ring, notification, and music Volume seems lower on this release.
#14 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 29 September 2013 - 06:44 PM
Ok prolly the cm source i'll look into ty
#15 hyro864
hyro864
  • 34 posts
Posted 29 September 2013 - 07:42 PM
No worries. I replaced the sound file from build 1. All is loud again. Lol.
#16 lowvolt
lowvolt
  • 478 posts
Posted 30 September 2013 - 03:06 PM
is that the file in system-etc
Sent from my Razr M using Tapatalk 4
#17 hyro864
hyro864
  • 34 posts
Posted 30 September 2013 - 03:31 PM
Yes. The folder that says snd_soc_msm
  • lowvolt likes this
#18 trebills
trebills
  • 73 posts
Posted 04 October 2013 - 06:38 PM
somber73, on 05 Oct 2013 - 01:36 AM, said:
Not the link for Validus. I'm friends with the team but i do not appreciate other rom links posted on my op.
I know it's not for Validus and I am glad you have friends. It is a link for OSE ROM. I can download it but I can't find a thread on it to subscribe to and communicate with others that might like and use the ROM, so I was asking on here. I deleted the links that I could. Good Day.
#19 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 04 October 2013 - 07:17 PM
There's an OSE team thread running around here somewhere.  It would probably be best to post there.
#20 kendog
kendog
  • 234 posts
Posted 06 October 2013 - 12:20 AM
The newest build is running great so far :-)
