Vanishing Storage
internal storage
18 replies to this topic
#1 JMG
JMG
  • 11 posts
  • Current Device(s):XT907
Posted 17 September 2013 - 01:09 PM
I have a year-old Razr M (XT907), running Android 4.1.2.  Loaded lots of apps with no problems for months.  Then, I think after the last Android update, I began to get low-storage-space warnings.  I deleted a bunch of apps, cleared the cache, deleted data, went back to the original version of apps, but kept getting the warnings.  Now, it says I have 457MB of internal storage, but if I try to install even a very small (2MB) app, it says there's insufficient storage to do the install.  Any ideas would be much appreciated.
#2 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 September 2013 - 01:31 PM
Do you have a lot of photos?
sig made by
Rinkle McBally
#3 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 17 September 2013 - 02:30 PM
Do you have a bunch of apps backed up in Titanium Backup?? Also have you made any back-ups in recovery??
#4 themrgoats
themrgoats
  • 137 posts
Posted 17 September 2013 - 02:44 PM
I have heard that there is a virus that makes fake duplicates of stuff to eat up your memory. Not sure if it's true but u might consider it and get an antivirus app if u can
#5 JMG
JMG
  • 11 posts
Posted 17 September 2013 - 03:55 PM
Thanks. All photos are on the SD card.  Don't use titanium backup and haven't recovered any backups.  I have scanned with Avast, and it says it's OK.
#6 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 September 2013 - 04:04 PM
Check your download folder. Are you rooted, unlocked, using safestrap?
sig made by
Rinkle McBally
#7 JMG
JMG
  • 11 posts
Posted 17 September 2013 - 05:37 PM
Download folder has a couple of tiny pdf's.  Not rooted, unlocked or using safestrap.
#8 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 September 2013 - 06:47 PM
Weird I'd just keep browsing through folder see if anything is taking a lot of space, if you don't find anything you could move all your personnel stuff to SD and do a factory reset. Just a thought.
sig made by
Rinkle McBally
#9 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 17 September 2013 - 10:14 PM
Also, try clearing cache on any app that you use to view photos/videos, like Twitter, Vine, TheChive, etc.  These apps build huge caches.  I noticed my Chive app temp DL's all of the pics I view.
#10 jco23
jco23
  • 414 posts
Posted 18 September 2013 - 04:23 AM
careful, although the system says "SD card", it's really internal storage.  you want the photos saved to your mnt/external1 folder.  make sure that your camera settings are set to save photos/videos there.
ROM: OSE KitKat 4.4.2
#11 JMG
JMG
  • 11 posts
Posted 18 September 2013 - 05:08 AM
All caches have been cleared.
#12 JMG
JMG
  • 11 posts
Posted 18 September 2013 - 05:36 AM
Pictures and music are on the external SD card.  Internal storage shows 448MB available, but I still can update or install anything.
  139.28KB   16 downloads
#13 jco23
jco23
  • 414 posts
Posted 18 September 2013 - 06:23 AM
ah, I bet I know what it is.... do you sync Google Play Music?  if so, I think it stores all of the music to the internal storage.
start by going to "manage apps", and then sort by size.  for me, Google Play music is at the top with 1+ GB
#14 JMG
JMG
  • 11 posts
Posted 18 September 2013 - 06:37 AM
Google Play Music is 3.16M for the app and 266K for data.
#15 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 18 September 2013 - 07:00 AM
I've read somewhere that the app size you see on the Play Store only represents the package installer size.  After it installs, it "unpackages" and takes up its true size.  Your app actually might take up that storage after it's installed. .
  • jco23 likes this
#16 jco23
jco23
  • 414 posts
ok, I'm 0-for-2 so far...  what app is the largest for you, and how many do you have?
#17 johnthehillbilly
Posted 18 September 2013 - 07:40 AM
Try following this
[How-To]-Free-up-Space-On-Internal-Storage#entry305008 ... it may help you with your storage issues....:)
  • jl90 likes this
#18 JMG
JMG
  • 11 posts
Posted 18 September 2013 - 10:19 AM
Largest app is Chrome (61.89 app, 18.58 data); then Facebook (28.12, 13.28).then Google Search (29.88, 414K).  68 downloaded apps in all (used to have 20+ more before I started getting the low storage warnings).
#19 Someolddude
Someolddude
  • 426 posts
Posted 09 October 2013 - 03:33 AM
I've had this issue before. Wish I could remember exactly what I did to fix it. One thing was clear data for the play store app which may have been the issue one time. Another time I just waited till the next day and had no problem. Google play does have some bugs I've noticed.
Also tagged with one or more of these keywords: internal, storage
