Best Answer livinginkaos , 17 September 2013 - 11:11 AM
If you have installed the July OTA update and have 9.18.78 on this device, you will not be able to flash backwards in OS. You will need to use THIS FXZ file.
Go to the full postBest Answer livinginkaos , 17 September 2013 - 11:11 AM
Go to the full postPosted 17 September 2013 - 10:04 AM
I am trying to return my Droid Razr M back to stock ICS.
Computer is using Windows 7.
I loaded Motorola Drivers.
I am using RSD Lite 6.1.5 with MTK patch.
I have tried using two files:
VZW_XT907_4.1.2-9.8.1Q-66_1FF.xml
and
VZW_XT907_4.0.4-7.7.1Q-144_SMQ_S1-36-10_CFC.xml
In both cases, I get an error message:
1/19 (or 1/22) flash partition "gpt_main().bin" phone returned fail.
What do I do to get around this error message?
Posted 17 September 2013 - 10:36 AM
and
not sure about your error message, but 4.1.2 = JB. 4.0 = ICS.
what version are you on now? is your bootloader unlocked?
ROM: OSE KitKat 4.4.2
Posted 17 September 2013 - 11:11 AM Best Answer
file.
Posted 17 September 2013 - 12:25 PM
Problem resolved. Thanks for your help!
Posted 17 September 2013 - 12:29 PM
No problem.
Posted 20 November 2013 - 02:22 PM
thanks it is ok
Posted 16 August 2014 - 03:33 AM
file.
plz upload file again .. file error
Posted 16 August 2014 - 05:35 AM
Posted 25 January 2015 - 10:25 PM
plz new link 4 this file plz plz
Posted 26 January 2015 - 05:35 AM
