[ROM][StockJB] Revolution-Unleashed Ver 1.2 [10-11-13]
Bionic ROMS
147 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 12 September 2013 - 05:07 PM
This is another great project that I decided to take on.
Based off of JB update 98.72.22 Deodexed posted By jp1044.
This is a pre-themed ROM with a lot of Extra tweeks.
Safestrap 3.11 and 3.60 compatible, So load it up and ENJOY.
Version 1.2 Screenshots
Special Thanks going out to the ones listed below.
For Keeping the Device Alive, For Help, Advise, Scripts, Tweeks, Addons, Testing, and Some Images used.
HashCode, Dhacker, Nitroglycerine, Rootuser94, BDH, T3, JP1044, Jayrod, JL90, BDAZZG1, Eye_Dea,
DLuke, MarkusMcNugen, B.E.McAllister and Mrlolli.
If I forgot anyone else please feel free to let me know and I will add you HERE
For his KickA$$ Bootanimation work JaeKar99
More can be found
What is in the Goodies.
Themed framework (((It is Dark)))
Themed SystemUI
Themed Settings
Themed Phone
Themed Contacts
Themed Calculator
Themed Gmail
Themed Hangouts (The theme will break on Update)
Theme PlayStore
Themed Apollo Music
Themed Power Toggles
Themed Notification Toggles
Bloat Free (All addtional apps are in Data. feel free to delete)
DSP Audio Enhancements
Init.d Script Driven
OverClock scripts (2 version, see OC installations) See Changelog.
Memory Tweeks
Data and WiFi tweaks
WiFi Tether Hack
Additional Modules and Scheduler
What Works
EVERYTHING
#Version 1.2 Changelog#
Baked in Apps into Settings Menu.
(AOKP Performance app, Easy OverClock app, DSP Manager and Phone Info)
30 step volume mod for Music and Bluetooth (I had a
eye-dea moment, Thanks Man)
Deleted some scripts and added some new ones.
Invisible Carrier Label
Duel primary and secondary text color.
Notification LED color change
Updated the System Apps
Fixed some bug issues
MOTO-M Launcher with kicka$$ Circle Widgets.
OverClock instructions.
The Easy OverClocking App that is included in this ROM was given to me
from eye-dea. This App was Originally setup and used for the MOTO-RAZR.
I have modified the values in the scripts used and change some strings to match the adjustment.
The scripts being used are Profile settings scripts based on Screen on and Screen off.
It has one click then reboot setup for OverClocking this Beast. There is 1 setup for the
4-Slot devices and 2 setups for the 5-Slot devices. USE AT YOUR OWN RISK!!!!!!
I have included a backout if anything goes wrong, see additional MODs below.
The AOKP Performance app is a Modified version that you will see in the AOKP ROMs. I
Stumbled across it from
  Everything I have used on it works with the exception of
CPU Voltage control due to not having a custom kernel.
This doesn't mater on which SS recovery you are using.
Installation will have to be on a fresh ROM Slot. I have tested
with just formatting system, data, cache and dalvic without issues, but
it is always better to Start Out Fresh............ 8)
Also there has been some bugs with using SS 3.11. I have evolved and updated to 3.60 version and haven't
had any issues loading this with that version.
UnleashedMods Directory will be created on Internal Storage.
Install in Recovery Only. No wipe needed.
Whats inside the Directory.
Clean_Slate.zip (use to undo the OverClock Settings)
RestoreStocktheme.zip (use this to undo the New Theme if it is too much for ya... HA HA HA)
Transparent-HomeScreen1.zip (The only way I could get the Transparent App drawer to stick)
Download Section
I switched server host on this one, because I was hearing way to much feed back with download speeds and corrupt downloads.
This New server should work out just fine with everyone.
The Goodies.
And No you have to fresh install this Beast... To Many Changes... TY
I don't normally ask for Donations and I will not start now, but if you feel the need then it will be greatly appreciated
  • Bama, matjmonk, B.E.McAllister and 6 others like this
#2 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 12 September 2013 - 05:08 PM
Mine. Mine.
#3 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Mine too
#4 shep419
shep419
  • 242 posts
  • Twitter:@shep42o
Posted 12 September 2013 - 05:16 PM
Download won't work for me.
#5 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 12 September 2013 - 05:21 PM
Try it now. I thinks I messed something up on it, but it works fine now.
#6 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 12 September 2013 - 05:34 PM
Great looking ROM!!! Very very cool. :D
  • nobe1976 likes this
#7 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 12 September 2013 - 05:35 PM
Nice work! Hit me up if you ever need help adding things to this beast.
#8 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 12 September 2013 - 05:41 PM
PM me I will add ya on hangouts....
$3π+ £®m€ ×X× BiOπI¢ oπ $ø|/|£ťhïñğ ¢ű$ț¤|/|
#9 shep419
shep419
  • 242 posts
  • Twitter:@shep42o
Posted 12 September 2013 - 05:57 PM
Still getting unsuccessful download
#10 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 12 September 2013 - 06:10 PM
Are you using your phone or PC???
#11 jayrod
jayrod
  • 6,525 posts
  • LocationWilmington NC
  • Current Device(s):Taimen
Posted 12 September 2013 - 06:18 PM
I see you changed the name...I kinda liked the original one!
  • camoxjeep likes this
#12 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 12 September 2013 - 06:25 PM
I did to but politically correct I changed it. Could add the pole anywhere.
#13 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 12 September 2013 - 06:28 PM
Downloaded on phone just fine. You might need to clear out some stuff on internal storage if you don't have at lease 500m free.
  • shep419 likes this
#14 Bama
Bama
    Needs Beer
  • 582 posts
  • Locationsalem,al
what me no hangouts?lol
#15 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 12 September 2013 - 06:32 PM
Pop a pm bro... I'll add ya too.
  • Bionic likes this
#16 cgillie92
cgillie92
  • 129 posts
Posted 12 September 2013 - 09:50 PM
Might be a dumb question but what do you rename the overclock to?
#17 shep419
shep419
  • 242 posts
  • Twitter:@shep42o
Posted 13 September 2013 - 12:15 AM
I'll give that a try thanks.
#18 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 13 September 2013 - 02:21 AM
You will have to rename the one you want to use 99oc or something like that. Make sure that the settings are right for your phone. I just went over this last night and I thought the 2nd one I added only OC to 1.2, but turned out to OC to a lighter 1.25. I will look into putting a patch together to get those switched out or add a 1.2 script in there.
#19 davenvick
davenvick
Posted 13 September 2013 - 02:25 AM
Download not working.
#20 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 13 September 2013 - 02:33 AM
Try it again. I was modifying the OP and it might have been the issue. I just checked and the link is still good. TY
