[KERNEL][GPL][N4] franco.Kernel - r182 - JWR66V/JSS15J
franciscofranco
, Sep 09 2013 06:54 PM
3 replies to this topic
Posted 09 September 2013 - 06:54 PM
Hey all. I hate bloated OP's so this is a simple one.
Changelog is somewhere in a link below.
It works in all roms.
Download:
Milestones (4.2.2 only):
Server 1:
Server 2:
Nightlies:
If you're on CM10.2 or any JSS15J AOSP rom please download the JSS tagged version below instead of the regular one
Server 1:
Server 2:
How to flash the Kernel:
fastboot flash boot image_name
or
flash the zip in the recovery
AOSP 4.3
fastboot flash system system.img
fastboot flash userdata userdata.img (if you flash this it will wipe your entire device SDCARD included. Flashing this is not needed if you're on 4.3 already)
fastboot flash boot boot.img
flash gapps in the recovery
For root flash supersu zip (search XDA) in the recovery
Source:
Kernel changelog:
4.3:
Don't bother asking for this as I will ignore you:
- GPU overclock
- Lower UV limit (default is 700mV)
- Lower CPU frequencies (minimum is 384MHz)
- sleep2wake
- Stupid governors
- MIUI support
F.A.Q. - Read this before complaining!
1. My phone exploded, HALP!
A: I don't answer to problems without a log. The log file is in /proc/last_kmsg. Paste it on pastie.org and link it on your post. Logcats are useless for Kernel purposes, don't bother posting them.
2. This kernel works on Y or X rom?
A: This is one of the worse questions you can ask on my threads. This is a Nexus, it works on every rom you can possibly imagine.
3. OMG BETTARY SUCKZ, IT DEAD IN 45 MINUTAS, HALP!
A: As you can imagine I don't build kernels to decrease battery life. All the battery life problems come from your apps, either Facebook, or Maps, or some Location Service being enabled etc etc. Check your damn wakelocks and fix them, the kernel is not responsible for them.
4. How do I flash this?
A: Reading the OP, theres a reason why I added instructions on it.
5. What is a data loss? Did I just had one?
A: Data loss is simply having the connection cut for X periods of time, usually few seconds. Grey bars means the device is not connected to Google services for some weird reason, but you'll still have internet connection.
6. OP is arrogant, I'm gonna call the Internet Police?
A: Deal with it.
7. Touch Control doesn't work in rXXX release, you suckas, fix plixe!
A: I don't know who you are. I don't know what you want. If you are looking for a fix, I can tell you I don't have the solution. But what I do have are a very particular set of skills; skills I have acquired over a very long career. Skills that make me a nightmare for people like you. If you leave now, that'll be the end of it. I will not look for you, I will not pursue you. But if you don't, I will look for you, I will find you, and I ignore you.
8. My Wi-Fi is borked, doesn't turn on, haz gray bars, drains battary and killed my parrot. Fix plz."
A: This Kernel has stock Wi-Fi drivers, same as stock Kernel. The problem is YOU and YOU alone. Probably installed some wtf Kernel with some wtf Wi-Fi drivers. News flash, fix your derp and stop spamming this thread with nonsense. By the way, gray bars only means you're not connected to Google servers, but your Wi-Fi works just fine.
- Memnoch73, hadeshorn9, Platy87 and 8 others like this
Posted 09 September 2013 - 07:04 PM
From all the staff welcome to DroidRZR
- Memnoch73, livinginkaos and vdubdan87 like this
Posted 09 September 2013 - 07:35 PM
Awesome franco's here!
Sent from my Nexus 4 using Tapatalk 4
- soocold likes this
Posted 10 September 2013 - 03:39 AM
Dang glad to have you here Franco! Nice to have you in the neighborhood rather than down the street so to speak.
No stupid governors huh? Okay any smart ones? J/J! Well done !
