Which slot# # for pacman ROM?
Posted 08 September 2013 - 02:20 PM
Posted 08 September 2013 - 04:42 PM
Generally its Slot 1
- Sh0rty 140 likes this
Posted 09 September 2013 - 12:47 PM
Based on XDA:
Says to use Slot 1
Posted 10 September 2013 - 11:53 PM
Posted 22 September 2013 - 02:50 PM
Will pac rom work on 98.72.22? It worked before I did the JB update. Just asking.
@ this point I am enjoying Raging Bionic.
- jl90 likes this
Posted 22 September 2013 - 08:23 PM
Posted 23 September 2013 - 04:08 AM
Its a kexec rom, it doesnt matter what you are on the stock side. Pac-rom is now on 4.3 nightlies.
On a side note, pac rom does work with the JBX kernel also (for oc), its like a better than new phone haha
Edit
not sure if SS 3.5+ still requires roms to be in certain slots, or if pac rom requires a certain slot, i dont think it does now that i think about it
Posted 12 October 2013 - 09:49 PM
I downloaded PAC but the file I downloaded has an extension of .man, I don't know what to do with it. Would have posted this on the XDA site but I don't have permission to do so.
Posted 18 October 2013 - 12:23 AM
Then you have the wrong file. You need .zip file. They keep all their build logs in the same folder as the builds and if one build fails there will be the log but not the build, so you might have picked that up by accident.
