I have my safestrap @v3.11 and I have a 2 gigabyte slot running my rom and I need more space. Anyway that I can increase the size of the slot to give me enough space?
Re-Partition
zackdmack
, Sep 07 2013 04:51 PM
2 replies to this topic
Posted 07 September 2013 - 04:51 PM
Posted 07 September 2013 - 05:10 PM
I haven't upgraded yet but I would assume you could do a back up of your rom in slot one, delete slot one, recreate slot one as a 3gb slot, then do a restore of your backup.
- jl90 likes this
Posted 08 September 2013 - 07:04 AM
I haven't upgraded yet but I would assume you could do a back up of your rom in slot one, delete slot one, recreate slot one as a 3gb slot, then do a restore of your backup.Sent from my DROID BIONIC using Tapatalk 2
You absolutely can do that...I have once or twice ....just make your back up to sd-ext...then delete the current slot you are on and create a new one at 3gb....restore your backup and boom.....you are all set.
