[ROM] [XT926] [4.2.2] LiquidSmooth 2.9/3.0
127 replies to this topic
#1 Deadman96385
Deadman96385
    LiquidSmooth Dev/Maintainer
  • 52 posts
  • Google+:http://goo.gl/vL4USh
  • LocationMinnesota
  • Current Device(s):Galaxy Note 2, HTC Mytouch 4g
Posted 04 September 2013 - 09:17 AM
WE TAKE NO CREDIT FOR ANY WORK THAT COMES ASSOCIATED WITH THESE BUILDS UNLESS SPECIFIED OTHERWISE. ALL CREDIT GOES TO CYANOGENMOD, AOKP, SLIMROMS, PARANOID ANDROID & THOSE WHO HAVE CONTRIBUTED!
OFFICIAL DISCLAIMER
 * Your warranty is now void.
 * I am not responsible for bricked devices, dead SD cards,
 * thermonuclear war, or you getting fired because the alarm app failed. Please
 * do some research if you have any concerns about features included in this ROM
 * before flashing it! YOU are choosing to make these modifications, and if
 * you point the finger at me for messing up your device, I will laugh at you.
ABOUT US
LiquidSmooth is an aftermarket firmware based on the Android Open Source Project.
Dedicated to providing users with smooth, stable and fast ROMs. A Lightweight modified AOSP base, and then add the features you crave!
While we make every effort to test these builds as much as possible, we are not responsible for anything that may happen to your device.
We ask that you do your part to know your device and know how to recover from problems before you flash!
MEMBERS
Deadman96385
Aways
Dhacker29
Jdkoreclipse
Liquid0624
Liquidzgrl
OldDroid
FEATURES
       Linaro Prebuilt 4.74 Toolchain
    -O3 Strict-Aliasing & ISO C++11 Mode
    ARM Optimized String Handling Routines
    Linaro and Code Aurora Optimaztions
    Customizable lockscreen buttons/sliders
    Chronus clock widget
    Customizable hardware and software keys
    Transparent navbar and status bar
    Customizable navbar ring
    Navigation bar widgets
    Customizable power menu
    Notification power widget
    Customizable quicksettings panel
    Statusbar mods
    Theme engine
    Quiet hours
    Volume rocker music controls
    Full Rotation
    Customizable battery and notification light
    And way more then this...
CHANGELOGS
SOURCECODE
DOWNLOAD
  • neckchop, livinginkaos, shane1 and 1 other like this
#2 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 04 September 2013 - 09:22 AM
LiquidSmooth 3.0 Beta
Android 4.3
Use 4.3 Gapps and do a data wipe before flashing.
Known Issues:
1. Bluetooth
2. Halo notifications
First boot will take a little while (five minutes+).
If you loose root access
1. Go to superuser >settings
2. Change Superuser Access to "Apps and Adb"
3. If that doesn't work then also check the "Declared Permission" box
4. Still have trouble try reading this
Downloads:
  • shane1, Techn9ne1730 and bjoostema1933 like this
#3 ripper2860
ripper2860
  • 137 posts
  • Current Device(s):Motorola Droid Razr HD Maxx
Posted 04 September 2013 - 10:01 AM
Very nice.  Thank you.
Motorola Razr HD Maxx
Root and Unlocked Bootloader | Blurry 1.2 HD  | Nova Launcher | CrossBreeder MOD
#4 PILLMUZIK3600
PILLMUZIK3600
  • 34 posts
  • Twitter:PILL_KOZBY_
Posted 04 September 2013 - 01:19 PM
Does this have the low call volume bug?
Sent from my XT926 using Tapatalk 4
#5 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 04 September 2013 - 01:44 PM
That hasn't been reported, so i would say no.
#6 sunkim50
sunkim50
  • 58 posts
Posted 04 September 2013 - 03:31 PM
Dropbox as your host? Are you going to hit your quota? Anyone willing to get a mirror up?
Sent from my Droid Razr HD using Tapatalk 2
#7 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 04 September 2013 - 03:55 PM
For the 3.0 yes, quota wont be hit cause its only posted on this site.
If it gets close, i will upload it somewhere else.
#8 mbar9607
mbar9607
  • 38 posts
Posted 04 September 2013 - 06:00 PM
Love 3.0 but have an issue where when making a phone call the volume is all the way down and still loud and I can hear myself echo, just wondering of that's normal for the time being since it is a beta
#9 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 04 September 2013 - 06:16 PM
Yes the beta has a fair amount of bugs atm, the echo and high volume is one them.
#10 mbar9607
mbar9607
  • 38 posts
Posted 04 September 2013 - 06:27 PM
ok, cool..so far out of what i use them are the only ones i notice so far but other than that i like it and will run it for a while and wait for an update
  • Deadman96385 likes this
#11 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 05 September 2013 - 06:10 AM
Changed LS 3.0 download to my new Android Host
#12 bjoostema1933
bjoostema1933
  • 122 posts
  • LocationNorth Carolina
  • Current Device(s):Razr HD Maxx /Nexus 7
Posted 05 September 2013 - 12:11 PM
Running 2.9, absolutely amazing so far! Will report any bugs if encountered, so far it's only the GPS icon staying on after use, even if it's not running.
#13 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 September 2013 - 01:12 PM
Im having issues sending  text messages in the included messaging app. I receive them though .
sig made by
Rinkle McBally
#14 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 05 September 2013 - 01:13 PM
In 3.0 or 2.9
Sent from my XT1080 using Tapatalk 4
#15 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 September 2013 - 01:16 PM
2.9 I'm flashing 3 now.
I thought 3 was out but link is still 2.9 lol
Haha I found 3 smdh
sig made by
Rinkle McBally
#16 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 05 September 2013 - 01:17 PM
Did you clean flash 2.9?
#17 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 September 2013 - 01:23 PM
Yes I did with the gapps you linked
sig made by
Rinkle McBally
#18 Deadman96385
Deadman96385
  • 52 posts
  • LocationMinnesota
Posted 05 September 2013 - 01:26 PM
Strange, try out 3.0
#19 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 05 September 2013 - 06:58 PM
I've been running 2.9 for about two hours now, haven't had any issues yet. Thanks, I'm enjoying the hell out of the experience.
#20 PILLMUZIK3600
PILLMUZIK3600
  • 34 posts
Posted 05 September 2013 - 10:18 PM
does 3.0 have the low call volume issue
