WE TAKE NO CREDIT FOR ANY WORK THAT COMES ASSOCIATED WITH THESE BUILDS UNLESS SPECIFIED OTHERWISE. ALL CREDIT GOES TO CYANOGENMOD, AOKP, SLIMROMS, PARANOID ANDROID & THOSE WHO HAVE CONTRIBUTED!
OFFICIAL DISCLAIMER
Posted 04 September 2013 - 09:14 AM
OFFICIAL DISCLAIMER
Posted 04 September 2013 - 09:22 AM
LiquidSmooth 3.0 Beta
Android 4.3
Use 4.3 Gapps and do a data wipe before flashing.
Known Issues:
1. Bluetooth
2. Halo notifications
First boot will take a little while (five minutes+).
If you loose root access
1. Go to superuser >settings
2. Change Superuser Access to "Apps and Adb"
3. If that doesn't work then also check the "Declared Permission" box
4. Still have trouble try reading this
Downloads:
Posted 04 September 2013 - 04:19 PM
I downloaded the 3.0 link but the file name is still LS 2.9 08142013-I am guessing you didn't change the name -
Posted 11 September 2013 - 10:27 AM
Ok just getting aroung to flashing this I noted the bt bug- which is a biggie for me but neverless wanted to get it loaded up so I would be able to dirty flash upcoming releases - Many Thanks for sharing hoping to see some more folks here soon
Edit: Ok I got it setup and running I hadn't found any issues on my end and b/t over exteranl speaker is working fine for me Gps lockedin under 5s very impressive O yeah its Liquid Thanks
Posted 14 September 2013 - 09:23 PM
Hello,
I received my XT925 (UK version) yesterday, unlocked the bootloader, rooted, and installed TWRP v2.2.2.1. I am trying to flash Liquid Smooth v2.9 onto the phone however it has been stuck on "Verifying filesystems" for over 20 minutes, is this normal? I did a factory reset but didnt format system as i understood the rom formats it anyway. Should I still wait for it to finish verifying or is there something else i should do?
Many thanks in advance.
