Low Battery While Flashing - Known Workarounds
#21
Posted 02 November 2012 - 04:43 AM
i tried all the above methods, but no luck.
then found a thread that said to try it this way...
worked like a charm
#22
Posted 06 November 2012 - 11:33 PM
Also, you could not have tried all the methods I had listed. If so, the factory cable would have worked. The jumper cable does work as well. These methods always work, provided you do them correctly.
#23
Posted 09 January 2013 - 01:40 PM
#24
Posted 12 January 2013 - 04:27 PM
#25
Posted 17 March 2013 - 04:17 PM
I got tripped up trying to unbrick that part went smooth then the battery got to low trying to reflash JB in recovery. I can start the process in recovery but it wont complete. So I wait.
My question is & it might be stupid. Do I just leave the phone off till the adapter gets here or should I plug in and keep it at the M boot screen? I didnt know if it would matter if it ran all the way down or if keeping it plugged into the wall was kinda holding its battery level but not charging. I have just turned it off and am gonna wait. I dont know where TBH is but I got it shipped priority, so it should be here in 3-5 days.
#26
Posted 17 March 2013 - 04:31 PM
- dpd653 likes this
#27
Posted 17 March 2013 - 04:51 PM
#28
Posted 21 March 2013 - 07:34 PM
#29
Posted 22 March 2013 - 09:50 AM
- dpd653 likes this
#30
Posted 22 March 2013 - 11:36 AM
#31
Posted 22 March 2013 - 11:49 AM
I am moving this to the How-to section and pinning it for future reference and help to others with battery issues
#32
Posted 30 March 2013 - 08:12 PM
#33
Posted 30 March 2013 - 08:30 PM
Also, thank you everyone that has sent in likes and messages in PM. However, if you find a certain method working that came from another site, please go to those sites and thank the posters there! Also many kudos to the guys that tirelessly work in the chat room. This guide would not have happened if I didn't have the support from the awesome community here when I had these battery problems myself!
- cmh714 likes this
#34
Posted 30 September 2013 - 02:55 PM
hi i chose to get the cable i followed the instructions as i understood i have run the razr restore but am still back to no boot this is how it ran "[*] Simple Razr Restore
[*] Windows Version
[*] Created by mattlgroff
[*] Before continuing, ensure your Razr is in the
[*] "AP Fastboot" mode and connected via USB.
[*]--- Also press the keys after the screen flashes back on when asked---
[*] IF YOUR PHONE SAYS STATUS 1 UNLOCKED EXIT NOW AND EMAIL ME
[*] YOU HAVE AN UNLOCKED BOOTLOADER! ! ! ! !
[*] mattlgroff@gmail.com
sending 'mbm' (512 KB)... OKAY [ 1.016s]
writing 'mbm'... OKAY [ 0.460s]
rebooting into bootloader... OKAY [ 0.183s]
Press any key AFTER the screen comes back on
sending 'mbmloader' (42 KB)... OKAY [ 0.032s]
writing 'mbmloader'... OKAY [ 0.281s]
sending 'mbm' (512 KB)... OKAY [ 0.460s]
writing 'mbm'... OKAY [ 0.472s]
rebooting into bootloader... OKAY [ 0.203s]
sending 'devtree' (512 KB)... OKAY [ 0.619s]
writing 'devtree'... OKAY [ 0.510s]
sending 'system' (262144 KB)... OKAY [ 64.767s]
writing 'system'... OKAY [ 24.441s]
sending 'system' (262144 KB)... OKAY [ 68.939s]
writing 'system'... OKAY [ 21.309s]
sending 'system' (130816 KB)... OKAY [ 34.691s]
writing 'system'... OKAY [ 10.566s]
sending 'boot' (8192 KB)... OKAY [ 3.204s]
writing 'boot'... INFOPreflash validation failure
FAILED (remote: )
sending 'recovery' (9216 KB)... OKAY [ 4.316s]
writing 'recovery'... OKAY [ 1.842s]
sending 'preinstall' (262144 KB)... OKAY [ 61.888s]
writing 'preinstall'... OKAY [ 22.229s]
sending 'preinstall' (262144 KB)... OKAY [ 73.821s]
writing 'preinstall'... OKAY [ 22.009s]
sending 'preinstall' (98304 KB)... OKAY [ 31.460s]
writing 'preinstall'... OKAY [ 8.380s]
sending 'radio' (21900 KB)... OKAY [ 6.491s]
writing 'radio'... OKAY [ 2.607s]
It is recommened to wipe data, especially if you were on a custom rom.
If you don't you will probably bootloop and have to wipe anyway...
Press any key to Wipe the phone's data (NOT SDCARD(S)) or exit the utility.
erasing 'userdata'... OKAY [ 0.743s]
erasing 'cache'... OKAY [ 0.090s]
sending 'radio' (21900 KB)... OKAY [ 6.106s]
writing 'radio'... OKAY [ 1.698s]
rebooting into bootloader... OKAY [ 0.128s]
You are now on stock 6.16.211. Please boot normally by holding down power.
Please make a selection or hit ENTER to return:'PLEASE HELP
#35
Posted 30 September 2013 - 03:03 PM
[*] Windows Version
FAILED (remote: )
Please make a selection or hit ENTER to return:'PLEASE HELP i held down power but still in the same no booting up
#36
Posted 30 September 2013 - 05:23 PM
#37
Posted 02 October 2013 - 09:11 AM
Yeah, I don't think this is on topic for the Low Battery issue.
- jl90 likes this
