help please no signal
help bionic no signal reboots
11 replies to this topic
#1 beeverpine
beeverpine
  • 7 posts
Posted 02 September 2013 - 05:58 PM
I have been having a lot of trouble with my bionic.A little while ago it lost all signal, so I thought it was something I did. It would reboot after 3 mintutes of no signal. So I tried flashing it again I used the house of bionic method 246 fxz, and everything reset and I erased all data/cache. When it came back up still no signal. so i thought sim card. I put the sim card in another phone and it worked fine. So I just flashed the 4.1.2, and no luck still.
#2 jayrod
jayrod
  • 6,525 posts
  • LocationWilmington NC
  • Current Device(s):Taimen
Posted 02 September 2013 - 06:47 PM
Sounds to me like the radio is bad. I never had this issue with my bionic but I do remember seeing a few others with the same issue. I'm not sure if the HOB still has a radio portion or not.. Might want to do some checking over in the FAQ
Sent from my Platyraptor extreme ultra maxxxx 4gLTE/GSM/ABC/123 Nick Knack Pattywack Ermegherd GED, MD,RNA,DNA,YMCA Edition S4! Via the 4th dimension....NOW RUNNING ECLIPSE
#3 beeverpine
beeverpine
  • 7 posts
Posted 02 September 2013 - 06:49 PM
Thanks I will give it a try
#4 beeverpine
beeverpine
  • 7 posts
Posted 02 September 2013 - 07:32 PM
I looked through it and couldn't find anything
#5 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 02 September 2013 - 09:23 PM
See last post here
Google pixel 32 gig....
#6 beeverpine
beeverpine
  • 7 posts
Posted 03 September 2013 - 11:31 AM
So that means its dead?
#7 transmissiontech
transmissiontech
  • 7,484 posts
Posted 03 September 2013 - 12:49 PM
Did you try flashing the radio from within the FXZ? If you did and it don't work afterwards then I would say its dead.
#8 beeverpine
beeverpine
  • 7 posts
Posted 03 September 2013 - 06:03 PM
I am not sure how to flash just the radio
#9 SamuriHL
  • 44,416 posts
Posted 05 September 2013 - 03:06 PM
Put the phone in AP Fastboot mode, open a cmd prompt in the HoB directory and type the following:
.\utils\moto-fastboot flash radio 98.72.22_FXZ\radio.img
.\utils\moto-fastboot reboot
Note that 98.72.22_FXZ should be whatever directory name you used to install the FXZ into.
#10 beeverpine
beeverpine
  • 7 posts
Posted 09 September 2013 - 02:21 PM
I am pretty sure I did everything right, but it didn't work. I also noticed that when I switched my sim card to my other phone. The phone didn't say anything about the sim card being missing.
#11 SamuriHL
  • 44,416 posts
Posted 09 September 2013 - 02:43 PM
Then you're looking at a hardware failure.  It happens.
#12 beeverpine
beeverpine
  • 7 posts
Posted 10 September 2013 - 07:07 AM
Is there any way to replace the hardware for cheap? Or is that whole sim card section one solid piece?
Also tagged with one or more of these keywords: help, bionic, no signal, reboots
